Like Tree4Likes
 Old 05-31-2011, 10:34 AM   #1
MSFer87's Avatar
Posts: 1,162   (View Stats)
MSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the world
Groans: 83
Default 1st.....2nd......1st BAMMM (fucked up clutch)?
So me being a dickhead I tried showing off to my friend the powa of the MS3. So I launched it and did a big burnout.........through 1st, then quick to 2nd and at the top of 2nd threw it back in first instead of 3rd at whatever is at the top of 2nd my guess is 50-60 mph idk. My fucking girlfriend never wears a seatbelt and bounced her head off of the dash. I caught it almost immediately and pushed the clutch back in from the roll maybe about a half second. After my shitty driving I then went to a stop and noticed the tranmission felt weird. Now the clutch was releasing earlier and won't go into gear as easy.
The more I drove it I noticed it will only go into certain gears after the rpms go down after shifting into each gear. I also noticed that with the clutch fully pushed in when I try to put it into gear the rpms jump up a little bit as if I don't have the clutch fully disengaged. Unfortunately I had to drive it to work like this and now it's having a hard time going into first with the clutch fully pressed in, and the car shakes from going from a stop (not the clutch pedal thank god.)
So my question is.........besides it being the clutch/pressure plate, could it also be the shiftfork, motor mount or something else?
I just installed the TRZ mount after work I'm going to check if everything is still intact with that. Thanks for input ahead of time.
Bucker likes this.
-#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo
-1970 Chevelle - Needs full resto
MSFer87 is offline   Reply With Quote
The Following User Says Thank You to MSFer87 For This Useful Post:
claytonmk (06-01-2011)
 Old 05-31-2011, 10:36 AM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
moral of the story.....
trying to impress chicks always results in fail.
fycn
The Following 6 Users Say Thank You to rodrigo For This Useful Post:
IshiKage (06-01-2011), locorasta (06-01-2011), ms3speeed (05-31-2011), NoRegrets (06-01-2011), nycMS3 (06-01-2011), Stealth01 (05-31-2011)
 Old 05-31-2011, 10:42 AM   #3
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
Fucking win. Did her giant tits absorb most of the impact or no?
MS33SM is offline   Reply With Quote
The Following 4 Users Say Thank You to MS33SM For This Useful Post:
IshiKage (06-01-2011), predapio (05-31-2011), spoolin00 (05-31-2011), wette460 (06-03-2011)
 Old 05-31-2011, 10:46 AM   #4
SRTie4k's Avatar
Posts: 1,715   (View Stats)
Do the same thing in reverse: From a stop, do a burnout in 2nd, shift quickly into 1st keeping it pinned, then shift back into 2nd and smash your GF's face against the dash.
Should fix your problem.
The Following 9 Users Say Thank You to SRTie4k For This Useful Post:
Bucker (05-31-2011), emag remrofni (05-31-2011), ms3speeed (05-31-2011), NoRegrets (06-01-2011), predapio (05-31-2011), rodrigo (05-31-2011), ScarMS3 (05-31-2011), sellers (05-31-2011), wette460 (06-03-2011)
 Old 05-31-2011, 10:47 AM   #5
HLR Element's Avatar
Posts: 2,477   (View Stats)
HLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the world
Groans: 109
lol, stupid for not wearing a seatbelt... and how did your tranny work to go into 1st... my first sucks, i can't go into it unless i'm going less than 10mph
OneBAMFpog likes this.
Mk7 GTI
HLR Element is offline   Reply With Quote
 Old 05-31-2011, 10:47 AM   #6
MSFer87's Avatar
Groans: 83
I was thinking i broke off a few teeth on the pressure plate, or maybe fucked up the clutch master cylinder/slave cylinder Idk
 Old 05-31-2011, 10:48 AM   #7
kyzomo's Avatar
Posts: 133   (View Stats)
kyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant futurekyzomo has a brilliant future
my guess is ur syncro is fucked uo
MAZDASPEED 6 - COBB AP Stage 1 +SF v108 (tuned by myself), COBB SRI, SU Test Pipe, MUFFLERS DELETE, SURE R6 RMM, PROSPORT BOOST GAUGE, LED Tail Lights, 35%/20% Tint, 18x8.5 Gram Lights 57s
kyzomo is offline   Reply With Quote
The Following User Says Thank You to kyzomo For This Useful Post:
 Old 05-31-2011, 10:50 AM   #8
MS33SM's Avatar
Groans: 132
Damn, your girl's grill must be effed. Did you break off any of her giant tits?
The Following 2 Users Say Thank You to MS33SM For This Useful Post:
emag remrofni (05-31-2011), HLR Element (05-31-2011)
 Old 05-31-2011, 10:57 AM   #9
MSFer87's Avatar
Groans: 83
How'd you know she had big tits? Haha actually she hit her forehead and messed up the rear view mirror in the process. Fuck I hope it's not the syncros it that was the case it would be for all gears.
 Old 05-31-2011, 10:58 AM   #10
MS33SM's Avatar
Groans: 132
I was waiting for you to confirm it. Now post em up.
The Following 7 Users Say Thank You to MS33SM For This Useful Post:
Chriscote (05-31-2011), Darksun280 (05-31-2011), Dre (06-03-2011), kgb (05-31-2011), manelscout4life (05-31-2011), NoRegrets (06-01-2011), predapio (05-31-2011)
 Old 05-31-2011, 11:00 AM   #11
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
 Old 05-31-2011, 11:09 AM   #12
skiptowncat's Avatar
Posts: 1,592   (View Stats)
skiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the world
Groans: 49
Groaned at 34 Times in 25 Posts
skiptowncat is offline   Reply With Quote
 Old 05-31-2011, 11:11 AM   #13
MSFer87's Avatar
Groans: 83
In my defense it was 3:30am and I was tired
 Old 05-31-2011, 11:12 AM   #14
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i dont think anything can be in your defense.
The Following 3 Users Say Thank You to bova For This Useful Post:
Angr-E1 (06-01-2011), Darksun280 (05-31-2011), NoRegrets (06-01-2011)
 Old 05-31-2011, 11:14 AM   #15
captain slow's Avatar
Posts: 5,559   (View Stats)
captain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the world
Groans: 398
Groaned at 50 Times in 34 Posts
Yeah I have to ask the same thing as HLR Element. How the fuck did you put it into first at 50-60 mph?
captain slow is offline   Reply With Quote
The Following User Says Thank You to captain slow For This Useful Post:
kgb (05-31-2011)
 Old 05-31-2011, 11:16 AM   #16
Groans: 49
That takes a real special skill to do!!
The Following User Says Thank You to skiptowncat For This Useful Post:
kgb (05-31-2011)
 Old 05-31-2011, 11:16 AM   #17
Stealth01's Avatar
Groans: 201
That actually makes it worse. This is you:
Stealth01
2006 Mazdaspeed6 GT
The Following 2 Users Say Thank You to Stealth01 For This Useful Post:
emag remrofni (05-31-2011), volodya84 (06-01-2011)
 Old 05-31-2011, 11:18 AM   #18
MSFer87's Avatar
Groans: 83
Whatever shit happens and I can't take back that FAIL. So whatever I'm just asking what people can possibly think it is.
 Old 05-31-2011, 11:19 AM   #19
sick_role's Avatar
Posts: 815   (View Stats)
sick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the world
Groaned at 6 Times in 3 Posts
though it may not be very receptive, just force it in...it'll go
"Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb
Oh you mean dogs. Yeah I like dogs. I drive a Hyundai.
sick_role is offline   Reply With Quote
 Old 05-31-2011, 11:19 AM   #20
MSFer87's Avatar
Groans: 83
As gay as that sounds that's what happened
 Old 05-31-2011, 11:35 AM   #21
MSFer87's Avatar
Groans: 83
If that was me I would have bigger problems then my car being fucked up
 Old 05-31-2011, 11:59 AM   #22
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
I still don't see how you guys can shift into 1st at speed. My car NEVER let me go into first unless I was almost sitting still.
The Following 6 Users Say Thank You to DaleNixon For This Useful Post:
Chriscote (05-31-2011), JmkC (05-31-2011), manelscout4life (05-31-2011), memin (05-31-2011), ScarMS3 (05-31-2011), wette460 (06-03-2011)
 Old 05-31-2011, 12:03 PM   #23
fywdyl's Avatar
Posts: 370   (View Stats)
fywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the world
Groans: 52
In for pics of gf's big tits.
2010 Black Mica MS3
Mods to date:
Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071
Mods to come:
Driver Mod || Snow Performance Meth Kit
fywdyl is offline   Reply With Quote
The Following 5 Users Say Thank You to fywdyl For This Useful Post:
Chriscote (05-31-2011), DaleNixon (05-31-2011), Darksun280 (05-31-2011), jack_hammer (05-31-2011), predapio (05-31-2011)
 Old 05-31-2011, 12:11 PM   #24
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
1 Dumb, and you can't undo dumb
2 Bring the car in to the dealer and act dumb, which should come naturally, (see number 1)
3 Post noodz of gf and all will be forgiven
CoolMs3 likes this.
What a lovable bunch we are!!
The Following 8 Users Say Thank You to predapio For This Useful Post:
86AmishMs3 (05-31-2011), Angr-E1 (06-01-2011), atvfreek (06-01-2011), bwspeed (05-31-2011), DaleNixon (05-31-2011), Darksun280 (05-31-2011), manelscout4life (05-31-2011), wette460 (06-03-2011)
 Old 05-31-2011, 12:16 PM   #25
anthony8488's Avatar
Posts: 140   (View Stats)
anthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond repute
The syncros in all gears wouldn't be messed up, you can mess up only certain gears. Had an older car the syncro in 3rd was messed up so any shift over 3500 rpms you would here a quick grind, and could feel resistance in the shifter.
I heard it is cheaper to swap trannys then to fix individual synchronizers, that was a few years back so correct me if im wrong.
COBB AP | COBB SF | COBB TIH |HKS SSQV RECIRC | Autotech HPFP Internals | TURBO XS DOWN PIPE | TURBO XS RACE PIPE | HKS HI-POWER CATBACK EXHAUST | DENSO ITV-22 PLUGS | CXRacing FMIC | SURE 90D RMM | MATT DAMOND OCC KIT | JBR ADJ SHIFT PLATE + HEAVY SHIFT KNOB
anthony8488 is offline   Reply With Quote
The Following User Says Thank You to anthony8488 For This Useful Post:
MSFer87 (05-31-2011)
 Old 05-31-2011, 12:29 PM   #26
Next time, have her wear a seatbelt.
Chriscote (05-31-2011), DaleNixon (05-31-2011), fywdyl (05-31-2011), MSFer87 (05-31-2011)
 Old 05-31-2011, 01:00 PM   #27
Posts: 20,650   (View Stats)
Groans: 1,443
Were you trying to race a Civic Si while drunk?
Beanfab / Tuned by Nishan
The Following 3 Users Say Thank You to doubleflusher For This Useful Post:
kgb (05-31-2011), MSFer87 (05-31-2011), predapio (05-31-2011)
 Old 05-31-2011, 01:06 PM   #28
MSFer87's Avatar
Groans: 83
Haha no I was just trying to act like a badass to my friend that never seen the car. Thank god I got far enough down the street for him to not see me do it only hear me. The car is no longer under warranty so no stealership visits for me.
stupidslow_ms3 likes this.
 Old 05-31-2011, 01:09 PM   #29
Spirry's Avatar
Posts: 700   (View Stats)
Spirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the world
Groans: 31
Groaned at 28 Times in 15 Posts
Sounds like the clutch isn't releasing.
Spirry is offline   Reply With Quote
The Following User Says Thank You to Spirry For This Useful Post:
 Old 05-31-2011, 01:11 PM   #30
MSFer87's Avatar
Groans: 83
I meant to say it wouldn't be all gears the sychro would be to an individual gear set my bad. I know this because my CRX has shitty 3rd and 4th gear synchros (not my fault) it's common with Honda B series cable transmissions
See about post for explanation ^
Last edited by MSFer87; 05-31-2011 at 01:11 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-31-2011, 02:07 PM   #31
DaleNixon's Avatar
Groans: 91
Found a pic of OP's GF.
The Following 25 Users Say Thank You to DaleNixon For This Useful Post:
Angr-E1 (06-01-2011), atvfreek (06-01-2011), BeastMS3 (05-31-2011), Darksun280 (05-31-2011), Dre (06-03-2011), FridayGt (06-01-2011), fywdyl (05-31-2011), Hoangy (05-31-2011), JmkC (05-31-2011), jracer (06-03-2011), justint5387 (05-31-2011), kgb (05-31-2011), laxplayermjd (05-31-2011), locorasta (06-01-2011), LuczOr (05-31-2011), manelscout4life (05-31-2011), MSFer87 (05-31-2011), NoRegrets (06-01-2011), predapio (05-31-2011), ScarMS3 (05-31-2011), skiptowncat (06-02-2011), turbo test (06-01-2011), volodya84 (06-01-2011), wette460 (06-03-2011), wolly6973 (05-31-2011)
 Old 05-31-2011, 08:14 PM   #32
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
Groaned at 15 Times in 12 Posts
You honestly could not have found a better picture for this thread.
I call BS, you generated that one.
Cool sig coming soon.
LuczOr is offline   Reply With Quote
The Following 2 Users Say Thank You to LuczOr For This Useful Post:
DaleNixon (06-01-2011), MSFer87 (06-01-2011)
 Old 05-31-2011, 08:18 PM   #33
Groans: 398
I can vouch for that picture being legit. I've seen that somewhere before. Hilarious.
 Old 05-31-2011, 08:26 PM   #34
unokevin1's Avatar
Posts: 161   (View Stats)
unokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond reputeunokevin1 has a reputation beyond repute
Groaned at 8 Times in 5 Posts
Holy shit ^^
unokevin1 is offline   Reply With Quote
 Old 05-31-2011, 08:26 PM   #35
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
I did it at the dragstrip, but immediately pushed my clutch in... So no damage for me! I'm driving the car with the camera in it.
The Following User Says Thank You to Fatguy729 For This Useful Post:
 Old 05-31-2011, 09:16 PM   #36
Groans: 398
I still don't know how that happens. I gotta be almost stopped before it let's me in 1st.
 Old 05-31-2011, 09:29 PM   #37
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
blah blah blah.
let's get back to what really matters:
The Following User Says Thank You to tddvrrn For This Useful Post:
 Old 05-31-2011, 09:36 PM   #38
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
BlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the world
Groaned at 32 Times in 11 Posts
this is why when i shift i am never actually holding the shift knob i just apply pressure in the needed direction.. not once have i accidently downshifted. now i have skipped up a gear before but never downshifted when i wanted to upshift. OP sorry for your FAIL but hey now you have an excuse to buy more performance parts such as a racing transmission
RichTuned
Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG
11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected
4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected
BlueDmnSpeed is offline   Reply With Quote
The Following User Says Thank You to BlueDmnSpeed For This Useful Post:
MSFer87 (06-03-2011)
 Old 05-31-2011, 09:50 PM   #39
nobrakez's Avatar
Posts: 251   (View Stats)
nobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the worldnobrakez is the leader of the world
Doubt its a synchro. Most Trannys dont have them in 1st and given the issues with engaging 1st in an MS3 it probably doesnt have one(the FSM could confirm though). Hopefully its just a clutch/pp issue.
nobrakez is offline   Reply With Quote
 Old 05-31-2011, 10:27 PM   #40
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
As the OP suspects it's most probably the clutch pressure plate. The disk and flywheel did not like that either, but unless he goes to a car shop and have that checked by a professional... what we're doing here guessing is like peeing on a darts board with the wind blowing from a side (yeah, some may pee their shoes too in the process).
A while ago there was another member on this forum who shifted back to 2nd instead of 4th after going in 3rd up to red line. No engine damage was done in that case, and so in this case. The clutch is a lot less expensive than a motor. So just go have it checked and eventually replaced.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
tpmjr2004 (06-01-2011)
Ok, who fucked up? AtTheDriveIn Mazdaspeed3/6 General Discussion 6 03-31-2011 09:12 AM
Fucked son...fucked! meeker13 MazdaSpeed 3/6 - Turbo Induction 13 06-05-2010 12:09 PM
My car is fucked also. 08JD Mazdaspeed3/6 General Discussion 50 05-27-2009 03:30 AM
my car is fucked...... wisniaPl MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 04-14-2009 01:09 PM
Page generated in 0.57862 seconds with 44 queries
