Like Tree4Likes
 Old 06-01-2011, 05:17 AM   #41
MSFer87's Avatar
Posts: 1,162   (View Stats)
MSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the world
Groans: 83
Originally Posted by mituc View Post
As the OP suspects it's most probably the clutch pressure plate. The disk and flywheel did not like that either, but unless he goes to a car shop and have that checked by a professional... what we're doing here guessing is like peeing on a darts board with the wind blowing from a side (yeah, some may pee their shoes too in the process).
A while ago there was another member on this forum who shifted back to 2nd instead of 4th after going in 3rd up to red line. No engine damage was done in that case, and so in this case. The clutch is a lot less expensive than a motor. So just go have it checked and eventually replaced.
You are correct sir, and I crawled under it yesterday to see if I was dealing with a cracked tranmission case or broken RMM or anything of that nature. Everything checked out good. On to the next step of tearing this thing apart on a lift, and getting a new clutch hopefully that will be the extent of my problems. Oh yeah UPDATE!! Car will no longer go into reverse.
-#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo
-1970 Chevelle - Needs full resto
MSFer87 is offline   Reply With Quote
 Old 06-01-2011, 08:08 AM   #42
sick_role's Avatar
Posts: 815   (View Stats)
sick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the world
Groaned at 6 Times in 3 Posts
dun dun dunnnnnnn (the plot thickens)
"Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb
Oh you mean dogs. Yeah I like dogs. I drive a Hyundai.
sick_role is offline   Reply With Quote
 Old 06-01-2011, 09:35 AM   #43
Boother's Avatar
Posts: 139   (View Stats)
Boother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant future
You have likely bent the pressure plate torque straps due to the large backwards force that a clutch should never see. They are the 3 (only 2 pictured) silver straps on the outside of the pressure plate and are only designed to pull, not push! Bending them has forced the pressure plate outwards and it is not fully releasing anymore. See here for a broken strap.. http://www.elisetalk.com/forums/show...19&postcount=3
Boother is offline   Reply With Quote
The Following User Says Thank You to Boother For This Useful Post:
MSFer87 (06-02-2011)
 Old 06-01-2011, 10:08 AM   #44
supraman's Avatar
Posts: 238   (View Stats)
supraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the worldsupraman is the leader of the world
SHITS ABOUT TO GET NSFW
next time tell her to buckle the fuck up..
...see big boobs in seat belts can be sexy..
::edited so nobody gets fired::
supraman is offline   Reply With Quote
The Following 4 Users Say Thank You to supraman For This Useful Post:
DaleNixon (06-01-2011), I Love Brownies (06-01-2011), kgb (06-02-2011), MSFer87 (06-02-2011)
 Old 06-01-2011, 10:53 AM   #45
sick_role's Avatar
this thread is officially NSFW now
 Old 06-01-2011, 10:53 AM   #46
trf5000's Avatar
Posts: 2,290   (View Stats)
Yea It didnt help that I just opened it up while shootin the shit with my boss........
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 2 Users Say Thank You to trf5000 For This Useful Post:
 Old 06-01-2011, 11:19 AM   #47
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
Groaned at 15 Times in 12 Posts
Lol, my coworker just stopped by my desk as well. I just scrolled down.... "Welp, thats the internet for you."
Cool sig coming soon.
LuczOr is offline   Reply With Quote
The Following User Says Thank You to LuczOr For This Useful Post:
 Old 06-01-2011, 12:07 PM   #48
sick_role's Avatar
mods need to update title in this biotch
 Old 06-01-2011, 01:44 PM   #49
darth vader's Avatar
Posts: 665   (View Stats)
Most modern cars...including this one, have a synchro first gear. It's not Muncie M22 time any more....
 Old 06-01-2011, 01:56 PM   #50
03scgt's Avatar
Posts: 400   (View Stats)
03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world
i cant help you but op thats my buddys actual dog in your avatar lol
03scgt is offline   Reply With Quote
The Following User Says Thank You to 03scgt For This Useful Post:
 Old 06-02-2011, 04:24 AM   #51
MSFer87's Avatar
Groans: 83
This thread just got way better thanks for all the fail pics, big tittie seatbelt pics, and to the people that may have actually helped with the problem. HAHA No sarcasm at all, and technically it's still safe for work right? I mean a tit isn't a tit until there is actually a nipple involved am I right? And to not add to my already apparent fail I'm going to refrain from purchasing a very tempting organic ACT clutch on ebay for $400, and spend an extra couple hundred or so for a six puck.
 Old 06-02-2011, 05:19 AM   #52
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Thank fuck for mobile spankwire on iPhone. I'm going to snap one off at work here in a few minutes.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-02-2011, 05:29 AM   #53
MSFer87's Avatar
Groans: 83
Free is the way to go
 Old 06-03-2011, 10:37 AM   #54
supraman's Avatar
edited my post, sorry guys who opened at work
Ok, who fucked up? AtTheDriveIn Mazdaspeed3/6 General Discussion 6 03-31-2011 09:12 AM
Fucked son...fucked! meeker13 MazdaSpeed 3/6 - Turbo Induction 13 06-05-2010 12:09 PM
My car is fucked also. 08JD Mazdaspeed3/6 General Discussion 50 05-27-2009 03:30 AM
my car is fucked...... wisniaPl MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 04-14-2009 01:09 PM
Page generated in 0.33992 seconds with 28 queries
