![]() | | #81 | ![]() |
![]() Join Date: Jun 2011 Location: Tacoma Wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,346
| Neutral : +1 score
__________________ Blacked Out 2010 Black Mica MazdaSpeed 3 Performance: Speed Performance 10.6:1 Built motor, CP-e Exhaust Mani, GTX3071, Tial MVR EWG, JBR 3.5" SRI, Cobb AP V3, Autotech HPFP, Guardian Angel, eBay Downpipe, CP-E Triton CBE, Treadstone TR8L Intercooler, CX Racing FMIC Piping Kit, JBR Crashbar, NGK Plugs, PNP Intake Manifold, CoolingMist WMI system w/failsafe, DM Throttle Body Spacer with Dual D07 Nozzles, |
![]() | | #82 | ![]() |
![]() Join Date: Jan 2014 Location: Kissimmee FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 191
| Not Ranked : 0 score So reading thru this thread in noticing every one is talking about just the drivers side? Anything on the pass side axel? Especially considering that it was already noted that or want as very as stock part. Mine is clunking at the half shaft and need it replaced asap, but I'm afraid of that thin Axel snapping. Anybody? |
![]() | | #83 | ![]() |
![]() Join Date: Mar 2012 Location: Burnsville, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 215
| Not Ranked : 0 score Should be fine. Speedy 3 put 500 hp abuse to them. And seemed to hold up fine. I have yet to install. Probably get to it mid July lol
__________________ SOLD - 2007 Mazdaspeed3 210k Current - 2007 Mazdaspeed6 |
![]() | | #84 | ![]() |
| Not Ranked : 0 score I decided to have my half shaft rebuilt locally instead for same price as aftermarket one |
![]() | | #85 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score I've had these axles on the shelf for about a year now, as a "just in case". I recently found my driver side boot is torn, so looks like I will be doing this within the next few weeks. For all the guys that have installed the driver side, what is the best method to allow access to the axle? Pull the whole strut assembly? Or can I unbolt the control arms from the subframe and that will give me enough access? Any input would be appreciated.
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
| The Following User Says Thank You to Boost_creep For This Useful Post: | btstarcher (07-02-2015) |
![]() | | #86 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
| The Following User Says Thank You to btstarcher For This Useful Post: | Boost_creep (07-02-2015) |
![]() | | #87 | ![]() |
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning | |
![]() | | #88 | ![]() |
Groans: 112
| Not Ranked : 0 score Wait...didn't remove the hub. Left it moved over to the side, supported by something so it wasn't at a severe angle. Memory is a bit fuzzy, sorry.
![]() | | #89 | ![]() |
| Not Ranked : 0 score Haha, not a problem. Yea I've removed tons of axles on other cars, and I always just pull the strut and push the hub/control arm down and twist the hub out of the way. The problem is my bilstein struts are like bonded in my hubs and I really don't feel like pounding the crap out of them. Lol. I would rather unbolt the control arms from the back at the subframe if possible.
![]() | | #90 | ![]() |
Groans: 112
| Not Ranked : 0 score Use the scissor jack to pry it out; easy peasy. Brace it against the hub and the perch and crack away.
![]() | | #91 | ![]() |
Groans: 111
| Not Ranked : 0 score Since the Spec Stage2+ clutch wears out quite fast I'm thinking I should change the axles next time I will replace it (I chose to refurbish the OEM clutch to a specialized shop). So I ordered a set of these axles, let's see how this goes. the factory axles have about 171k kms on them (roughly 110k miles) and sometimes when I start moving the car they click even if the axle nuts are torqued properly.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI |
![]() | | #92 | ![]() |
| Not Ranked : 0 score How many miles are on yours? I'm at roughly 65k on mine, with not a hint of slipping at 400whp (knocks on wood).
![]() | | #93 | ![]() |
Groans: 111
| Not Ranked : 0 score Mine has about 25k miles/40k kms on it. It doesn't slip or anything, but when I rebuilt the motor just a while ago it was like 50% worn. I'm not slipping it excessively but probably it doesn't like too much bumper to bumper traffic which I have to do quite a lot.
| The Following User Says Thank You to mituc For This Useful Post: | Boost_creep (07-03-2015) |
![]() | | #94 | ![]() |
![]() Join Date: Jul 2015 Location: Columbia, SC
Rep Power: 0 ![]() Thanks: 0
| Neutral : -1 score Hello All. My passenger side cv axle has the inside boot torn, and has started to click. I thought maybe just the inside half of the axle could be replaced, so I went to the Dealership to find out that only the d/s can be ordered in halves, the p/s is only available as one unit, and for $478. The service manager was a little horrified when he saw the price, and that the price for just the boots were $110 and $70. I guess there is a specific groove (or something?) on the oem boot that other versions don't have? So...my question for everyone is, what are the part numbers/suppliers that will work for our cars? I've found some DriveTech ones on Amazon.com. I think the DriveTech part # for the p/s is MZ2302? I think MZ8149 is the one for the n/a 3 and 5. MazdaSpeed 3 07-09 2.3L M/T Turbo D/S & P/S Front Cv Half Shaft MZ2313 MZ2302 | MacAutoParts This is the pair of cv axles, supposedly for speed3s, though the photo/part number doesn't seem right once cross referenced. Looking at the difference between MZ2302 and MZ8149 on amazon, there is a 7 lb difference in shipping weight, though the length on the MZ8149 is way wrong in that listing, so that's not too helpful... Thanks in advance everyone. |
![]() | | #95 | ![]() |
Groans: 112
| Not Ranked : 0 score Did you read the thread? Sent from my SM-N900V using Tapatalk
![]() | | #96 | ![]() |
| Not Ranked : 0 score I did. Have I missed something? |
![]() | | #97 | ![]() |
Groans: 112
| Not Ranked : 0 score Maybe not, I'm on Tapatalk. But I thought that the axles were on eBay. Sent from my SM-N900V using Tapatalk
![]() | | #98 | ![]() |
Groans: 111
| Not Ranked : 0 score The link to the axles is on the first page. So you missed something...
| The Following 2 Users Say Thank You to mituc For This Useful Post: | btstarcher (07-22-2015), darth_speeder (07-22-2015) |
![]() | | #99 | ![]() |
Groans: 112
| Not Ranked : 0 score That's what I was thinking. Sent from my SM-N900V using Tapatalk
![]() | | #100 | ![]() |
| Not Ranked : 0 score I saw the link, just not the part #. I found it though, MZ2302 and MZ2313 from DriveTech on that Ebay link. FYI Amazon has them individually for those interested. |
![]() | | #101 | ![]() |
Groans: 111
| Not Ranked : 0 score I finally received my set of axles today. I will install them in about one month when I'll also replace the clutch (Spec Stage2+ wears out a bit too fast in city driving).
| The Following User Says Thank You to mituc For This Useful Post: | ItsNox (07-24-2015) |
![]() | | #102 | ![]() |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
Groans: 430
| Not Ranked : 0 score Sorry for the bump. Is the axle still holding up well?
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
![]() | | #103 | ![]() |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
| Not Ranked : 0 score well.. my car has been down for 3 months.. so, technically... yes lol.
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! |
![]() | | #104 | ![]() |
Groans: 430
Also, check things in the next day or two, and may be pm'ing you about those spacers.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
![]() | | #105 | ![]() |
I took the car down to go twinscroll. Up nowish. still no issues with the axle. And go put batteries in that damn patriot I sent you!!! tapatalkin
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! | |
| The Following User Says Thank You to mr.speedy3 For This Useful Post: | WetzMS3 (07-30-2015) |
![]() | | #106 | ![]() |
Groans: 430
I'll get that parrot up and running. Maybe grab a video for ya!
![]() | | #107 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
Groans: 67
| Not Ranked : 0 score Makes me want to break axles. $169 for both front MS6 axles that are not junk is crazy.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
| The Following User Says Thank You to aviator79 For This Useful Post: | ItsNox (11-17-2015) |
![]() | | #108 | ![]() |
![]() Join Date: Jan 2015 Location: College Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 202
| Not Ranked : 0 score Just to note: Bought and swapped driver's side DTA axle this weekend and the Axle nut is 36mm for the DTA. The stock axle nut size is OEM 35mm on the Mazdaspeed 6 (which is an odd size in itself). Luckily. I have done enough axles in my lifetime that I also had a 36mm 1/2" socket. Slightly different than a true hex/6/8 point axle nut socket, but work fine. Build quality seems great so far (all of about 50 miles lol)! |
![]() | | #109 | ![]() |
![]() Join Date: Mar 2012 Location: Warrenville, IL/Big Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,349
| Not Ranked : 0 score Little bump. In need of a new front passenger axle, anyone with a 6 get these yet? Also did we ever make any headway on getting rear axles?
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings |
![]() | | #110 | ![]() |
![]() Join Date: Aug 2012 Location: raleigh,nc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score The drive shaft shop makes 2 different sets of rear axles for the 6. Different hp ratings, can't remember what the exact hp number is |
![]() | | #111 | ![]() |
| Not Ranked : 0 score I was under the impression they only make one kind. Also, $400 per axle isn't really worth it to me if I can get a pair of new ones for $180. The rears aren't as weak as people make them out to be.
![]() | | #112 | ![]() |
| Not Ranked : 0 score You are right. They offered 2 different sets a couple years ago now they are only offering one 500hp set. |
![]() | | #113 | ![]() |
| Not Ranked : 0 score Are these OEM or aftermarket new rear axles?? If so, point in the direction of $180 OEM axles please! |
![]() | | #114 | ![]() |
Groans: 112
| Not Ranked : 0 score Did you even read the thread? LOL
![]() | | #115 | ![]() |
| Not Ranked : 0 score ![]() Ofcourse I didn't...............that's why I bought and installed a set already............ Please go back and properly read what I quoted. The way Mazdazilla made it seem was that he could get new axles for 180 a piece, hence my question. It's almost as if you didn't bother to read the string of text yourself |
![]() | | #116 | ![]() |
Groans: 112
| Not Ranked : 0 score I guess I just figured it was common sense he's referring to the DTA axles.
| The Following User Says Thank You to btstarcher For This Useful Post: | Raider (12-30-2015) |
![]() | | #117 | ![]() |
Groans: 67
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB | ||
| The Following User Says Thank You to aviator79 For This Useful Post: | RalliartRsX (12-30-2015) |
![]() | | #118 | ![]() |
| Not Ranked : 0 score I said if. As in, it would be awesome IF DTA offered rear axles for $180/pair. They do for the fronts, don't see why they wouldn't be able to for the rear.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | btstarcher (12-30-2015) |
![]() | | #119 | ![]() |
Groans: 67
| Not Ranked : 0 score They way you said "if" sounded like you were saying "im not going to pay $400 since I can get then for $180." Anyways someone message the guy and tell him we want rears. IDK if/when I will need then but would be nice to know they were available. I think I am starting to develop some play somewhere in my drivetrain that I can feel when I engage the clutch sometimes.
![]() | | #120 | ![]() |
| 6 mods and some Kool-Aid ![]() Join Date: Mar 2008 Location: Jax, FL
Rep Power: 28978 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,271
Groans: 856
I told him a year ago. He said if there is enough need, he will. So call or message them. | |
| The Following User Says Thank You to Raider For This Useful Post: | btstarcher (12-30-2015) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/1st-2nd-will-fit-gen-mazdaspeed-3-a-177109/ | ||||
| My first build. - DFW Mazdas | This thread | Refback | 07-13-2015 11:58 AM | |
| Broken L/H Rear drive shaft | This thread | Refback | 10-16-2014 02:49 PM | |
| Best option for fixing this (CV boot/axle) | stratman | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 11-03-2015 05:23 PM |
| rear axle replacement | 2006MS6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 20 | 02-14-2014 06:02 PM |
| New York: 2014 Subaru XV Crosstrek Hybrid finally adds gas-electric option to the brand [w/video] | Haltech | Automotive News | 0 | 03-28-2013 03:50 PM |
| Lotus Esprit replacement delayed to 2011, hybrid on option | Haltech | Automotive News | 0 | 07-29-2008 01:00 PM |
