Like Tree20Likes
 Old 05-23-2016, 10:58 PM   #161
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
I replaced both because why not and me and my mechanic noticed the passenger side had a little side to side when mounted onto the joint connection that's bolted to the block that the passenger outer axle connected to but we didn't see if the OEM passenger axle (was still in good condition) had any give like the DTA passenger axle. So far 3mo of plenty of abuse on low power and still holding strong.
2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning
 Old 05-24-2016, 06:54 AM   #162
ryguy 3's Avatar
Posts: 353   (View Stats)
ryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond repute
So did your DTA axles looked smaller than the oem units aswell?
Sent from my SPH-L720 using Tapatalk
ryguy 3 is offline   Reply With Quote
 Old 05-24-2016, 07:00 AM   #163
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
I thought they looked thicker.
Sent from my HTC6535LVW using Tapatalk
2 slo pu likes this.
SnailTune in progress
 Old 05-24-2016, 07:34 AM   #164
865ms3's Avatar
Posts: 2,602   (View Stats)
865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world
Mine were smaller.
We will see how they hold up to 570hp launches on drag radials this weekend
Brent
Mazda Dragon Camp - Event Coordinator
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
865ms3 is offline   Reply With Quote
The Following User Says Thank You to 865ms3 For This Useful Post:
xfeejayx (05-24-2016)
 Old 05-24-2016, 07:37 AM   #165
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Originally Posted by 865ms3 View Post
Mine were smaller.
O rly??
Good luck sir!
865ms3 likes this.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 05-24-2016, 07:57 AM   #166
865ms3's Avatar
Originally Posted by WetzMS3 View Post
O rly??
Good luck sir!
Never been to the track. So don't expect anything but embarrassment lol.
Brent
Dragon Slayer Setup
FreekTuned
WetzMS3 (05-24-2016)
 Old 05-24-2016, 08:11 AM   #167
WetzMS3's Avatar
Groans: 430
What radials?
2013 MS3 Black Mica
 Old 05-24-2016, 09:19 AM   #168
865ms3's Avatar
What radials?
Just some nt555 drag radials
Brent
Dragon Slayer Setup
FreekTuned
 Old 05-24-2016, 09:37 AM   #169
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Well I shot DTA an email about ms6 rear axles. We'll see what they say.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 05-24-2016, 09:53 AM   #170
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
I can't confirm the passenger side, but the driver side was identical. Here's a side-by-side.
The axle held up for track day #1 with no issues. I'm going to try to re-build the OEM so I have a backup (and for shits and giggles).
As John found out, the only issue noted so far is that the inner joint is only held together by the boot. I take care when installing so you don't have that joint fall apart.
[IMG][/IMG]
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
 Old 05-24-2016, 10:27 AM   #171
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Yeah, you literally need to bungee cord or strap the hub to the LCA while putting the strut and everything back together, just an FYI. The inner joint comes apart super easily.
Like ChaunceyM I have had zero issues with mine so far otherwise. When I had mine side-by-side, they were identical length.
2007 Mazdaspeed3 GT
 Old 05-24-2016, 10:31 AM   #172
865ms3's Avatar
I guess I should clarify. My passenger side was smaller.
Brent
Dragon Slayer Setup
FreekTuned
 Old 05-24-2016, 10:35 AM   #173
WetzMS3's Avatar
Groans: 430
Get it guuurrrllll
2013 MS3 Black Mica
865ms3 (05-24-2016)
 Old 05-25-2016, 12:05 AM   #174
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
[IMG][/IMG]
Was the oem inner joint only held together by the boot?
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
 Old 05-25-2016, 05:15 AM   #175
MD1032's Avatar
Groans: 143
Probably because these axles are cheap as fuck.
2007 Mazdaspeed3 GT
 Old 05-25-2016, 07:24 AM   #176
ChaunceyM's Avatar
No, the OEM inner joint is held together quiet firmly. I just yanked on the axle itself to pop it out of the tranny.
I've never done an axle swap before, but from what I've read/heard, that is not always the case. Often they are only held together by the boot as there is not supposed to be any strain applied in that direction. Only to get it out of the tranny.
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
 Old 05-25-2016, 01:00 PM   #177
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Groans: 29
I had them on the k04. You'll still spin the hell out of em.
The Following User Says Thank You to Cheapspeed For This Useful Post:
WetzMS3 (05-25-2016)
 Old 05-29-2016, 09:27 PM   #178
865ms3's Avatar
Pass side does not like a dead hook launch
Brent
Dragon Slayer Setup
FreekTuned
thrisnospork (05-29-2016)
 Old 05-29-2016, 10:39 PM   #179
Nitro's Avatar
Is that passenger side alot smaller in diameter than the oem 865ms3?
Stratified Tune
 Old 05-29-2016, 10:42 PM   #180
865ms3's Avatar
Yup
Nitro likes this.
Brent
Dragon Slayer Setup
FreekTuned
 Old 07-12-2016, 12:10 PM   #181
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
I was on sellers eBay store and noticed that they now have a driver side axle listed specifically for Gen2's but it's almost $40 more. Any of the Pu's that installed the drivers side are you having issues? I wonder what could possibly make it $40 more...
I have a torn boot and a bad wheel bearing on the drivers side so I figured I'd replace this when I do the wheel bearing.
daafisch is offline   Reply With Quote
 Old 07-12-2016, 12:44 PM   #182
MD1032's Avatar
Groans: 143
@daafisch; you can just call them up and ask. They've been very helpful and informative the few times I've called them.
2007 Mazdaspeed3 GT
 Old 07-12-2016, 02:12 PM   #183
daafisch's Avatar
Groans: 58
Maybe, I sent them a message on eBay and they just told me "the techs said it deserved a different listing"
 Old 07-12-2016, 03:25 PM   #184
ryguy 3's Avatar
Make sure you get the DTA MZ 2313 driver side axle and the DTA MZ 2302 for the passenger side.
I was sent a DTA MZ 2301 which is for a Mazda 3 not the speed3.
The Following 2 Users Say Thank You to ryguy 3 For This Useful Post:
daafisch (07-12-2016), Franky-5-Fingaz (08-30-2017)
 Old 08-21-2016, 09:28 AM   #185
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
This is bullshit.
Also what would like to know what the difference is. The gen1 and gen2 axles should be exactly the same no?
 Old 08-22-2016, 02:28 PM   #186
ChaunceyM's Avatar
I'm sure they are, but they needed a way to charge more. From the listings I saw, the "Gen2" axles were sold as singles and the same price as a pair of "Gen1" axles. Which is why I have a brand new DTA passenger side axle sitting in a box in the garage.
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
The Following User Says Thank You to ChaunceyM For This Useful Post:
MD1032 (08-22-2016)
 Old 08-29-2016, 09:32 AM   #187
daafisch's Avatar
Groans: 58
I did the same thing. Bought the pair and now have a passenger side sitting in the box.
 Old 08-29-2016, 09:11 PM   #188
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
I would buy someones pass axle for the gen 1
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 08-29-2016, 09:38 PM   #189
BLKspd5's Avatar
Posts: 65   (View Stats)
BLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really nice
I noticed that too, but I spent the extra $40 and it fit fine on my 13' PU. Sorry a little late on the response.
Engine/Exhaust/Intake
Corksport:Injector Seals, OCC, EBCS, HPFP Internals, Long Catted DP||Magnaflow:CBE||HTP:3.5" Intake & 51r Tray||JBR:Boost Tubes, Recirc. Hose||CP-E:TMIC||Cobb:Accessport V3(Freektune)||Forge:V2 BPV(Blue Spring)||Damond Motorsports:Full EGR Delete||NGK 6510
Suspension/Chassis
Corksport:Camber Plates, FSB/RSB, Endlinks, Short Shifter||JBR:Rear Camber Arms||CP-E:RMM||H&R:Street Performance Coilovers||Damond Motorsports:PMM, TMM
BLKspd5 is offline   Reply With Quote
 Old 11-18-2016, 11:20 PM   #190
va7kpt's Avatar
Posts: 35   (View Stats)
va7kpt is a jewel in the roughva7kpt is a jewel in the roughva7kpt is a jewel in the rough
I'm in need of a passenger side axel as well.
Seems like they're sold in pairs, and the passenger axel isn't available on it's own. There are some vendors that claim to be selling the ms3 passenger axel, but say it also fits the regular 3
I already purchased the drivers axel on it's own last year when the boot started leaking.
va7kpt is offline   Reply With Quote
 Old 12-02-2016, 04:03 PM   #191
shamie's Avatar
Posts: 952   (View Stats)
Just put a driver's side on. We'll see how it handles the track.
 Old 04-05-2017, 12:36 PM   #192
va7kpt's Avatar
Any update on this axel?
 Old 04-06-2017, 10:34 AM   #193
shamie's Avatar
I thrashed on it 3 track days (11 twenty minute sessions) last month (March) and its holding up fine. It does rust faster than the OEM but who really cares?
3 more track days planned later this month (April).
Performed fine again. They seem to be legit.
dagrimey1 and va7kpt like this.
 Old 08-14-2017, 09:37 AM   #194
shamie's Avatar
Update - 15 track days (over fifty 20 minute sessions) and going strong. 8 more track days this year - knock on wood.
If it does go I may try the one on Rock Auto (SURTRACK/TRAKMOTIVE MZ8171) - even cheaper!
The Following 2 Users Say Thank You to shamie For This Useful Post:
Franky-5-Fingaz (08-30-2017), nindoja (08-14-2017)
 Old 08-30-2017, 10:18 AM   #195
Franky-5-Fingaz's Avatar
Posts: 25   (View Stats)
Franky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the rough
Good to see that most people's DTA axles are still holding up. I plan on purchasing the pair for my 2012, not going to spend the $40 extra for the Gen 2 version if it's the exact same thing.
Franky-5-Fingaz is offline   Reply With Quote
 Old 08-30-2017, 11:53 AM   #196
shamie's Avatar
Go VIP - there's a pair in the FS section.
thrisnospork likes this.
The Following User Says Thank You to shamie For This Useful Post:
thrisnospork (08-30-2017)
 Old 09-18-2017, 08:10 AM   #197
shamie's Avatar
I found out how many licks to the center of the tootsie roll pop;
19 track days (over seventy 20 minute sessions) and the inner boot ripped and sprayed grease everywhere. It still got me home 60 miles away with minimal noise.
I ordered this one from Rock Auto (SURTRACK/TRAKMOTIVE MZ8171) to replace it. We shall see how it holds up.
 Old 06-13-2018, 03:27 PM   #198
tdale's Avatar
Posts: 23   (View Stats)
tdale has a spectacular aura abouttdale has a spectacular aura abouttdale has a spectacular aura about
My turn! Haha. If the pu axel for 118 isn't any thicker than the set for 140 I'll be buying the set for my pu. I have my clicky clicky clicky when turning left and after I put a tire with more meat on it i def noticed it got louder. Thankfully the speed isn't my daily and i can park.
Before i buy tho any of you want to sell your dta pass on your shelf?
Sent from my SM-G955U using Tapatalk
tdale is offline   Reply With Quote
 Old 06-15-2018, 03:10 PM   #199
tdale's Avatar
I emailed the axelstore and they told me the passenger RH 2010 to 2013 is half an inch longer then the one in the set for 140.
Can a gen 2 guy confirm this is a lie?
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/1st-2nd-will-fit-gen-mazdaspeed-3-a-177109/
My first build. - DFW Mazdas This thread Refback 07-13-2015 11:58 AM
Broken L/H Rear drive shaft This thread Refback 10-16-2014 02:49 PM
Best option for fixing this (CV boot/axle) stratman MazdaSpeed 3 - Engine, Transmission & Driveline 17 11-03-2015 05:23 PM
rear axle replacement 2006MS6 MazdaSpeed 6 - Engine, Transmission & Driveline 20 02-14-2014 06:02 PM
New York: 2014 Subaru XV Crosstrek Hybrid finally adds gas-electric option to the brand [w/video] Haltech Automotive News 0 03-28-2013 03:50 PM
Lotus Esprit replacement delayed to 2011, hybrid on option Haltech Automotive News 0 07-29-2008 01:00 PM
Page generated in 0.56244 seconds with 38 queries
