Like Tree6Likes
 Old 05-15-2014, 10:31 PM   #41
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Car is running! But I have no idea how fast I'm going. Speedometer is stuck at 0. So I guess either a sensor is bad or harness or (hopefully) I need to do something with my tune.
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
CosmicArkie (05-16-2014), udntknw (05-16-2014)
 Old 05-16-2014, 06:27 AM   #42
Jeff23spl's Avatar
Posts: 2,238   (View Stats)
do speedo rely on abs sensor ? do you have re-connected both or could you have break a wire or sensor by knocking on the hub or something ?
did you updated your gear ratio with ATR ?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-16-2014, 12:06 PM   #43
btstarcher's Avatar
Groans: 112
I'll be checking all connections, harnesses, sensors, and grounds after I leave work tonight. It's possible that something was knocked loose while bleeding the brakes or bending the dust shield. In ATR I used a spreadsheet I found here for gear ratios.
Catastrophic Dyno Results Elvisrosales88 2010 MS3 - Dyno Sheets/Discussions 56 04-13-2018 10:12 PM
Zero Motors announces small recall for potentially catastrophic motor failure Haltech Automotive News 0 04-07-2014 05:00 PM
Video: The definition of catastrophic failure Haltech Automotive News 1 01-25-2011 01:34 PM
Cobb PCV Fix Documented Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 32 05-07-2010 10:21 AM
GM responds to more Camaro transmission failure talk on enthusiast forum Haltech Automotive News 0 12-04-2009 04:20 PM
Page generated in 0.24168 seconds with 22 queries
