-   -   2010 ms3 motor in a 2007 ms3 (http://www.mazdaspeedforums.org/forum/f10/2010-mazdaspeed-3-motor-2007-mazdaspeed-3-a-141563/)
holeinmypocket 03-28-2013 10:18 PM
What's the difference if there is a difference between the genpu and genwon motors...
I'm looking to get a 2010 engine for my 2007 ms3. By engine I mean intake manifold,turbo,pulleys, exhaust manifold etc.
himurax13 03-28-2013 10:24 PM
In other words, you want a long block for a Genpu.
The main difference is the pistons, rods, and the valve cover(oil fill cap).
The only thing that I can think of that might be different is the valve cover breather location.
Sent via stocked out for a while ...
Sid3wayS 03-28-2013 10:34 PM
You would need to swap out your power steering pump and use your wireing harness for the ground at the top of the pump, the pu's harness does not have it. Other then that its a direct fit.
Only other physical differences that matter are like stated before.
holeinmypocket 03-28-2013 10:54 PM
I have a 2007 ms3 not a 2010...I am looking at a 2010 long block for my 2007 ms3
CosmicArkie 03-28-2013 11:03 PM
LKQ Corporation - Location Search
phate 03-30-2013 11:09 AM
The gen2 long block will work just fine in a gen1. The block and accessory mounting positions didn't change. I did a swap like this last year with a brand new long block from mazda (2012 long block).
mzr0818 03-30-2013 12:01 PM
I haz. It works...
holeinmypocket 03-30-2013 12:08 PM
So I don't need to switch out power steering pumps?
mzr0818 03-30-2013 12:09 PM
Nope
The only thing I transfered was the VC and even that is workable. I just liked mine better.
holeinmypocket 03-30-2013 12:21 PM
How are the rods and pistons different that was mentioned above somewhere?
Sid3wayS 03-30-2013 12:26 PM
Originally Posted by mzr0818 (Post 1976672)
Nope
Gen 2 blocks dont have a pump at all, only a triangular mount with a pulley. The gen 1 have a full pump with lines running to and from.
If he is dropping a gen 2 block in he will need to take his pump from his original motor and put it on the new block.
If this is wrong then someone please explain why?
Only the face of the piston is different, its made to burn the fuel cleaner but the size and shape are identicle.
phate 03-30-2013 12:43 PM
Long blocks don't have accessories, so he will have to use all of his.
mzr0818 03-30-2013 12:58 PM
^^^ this
He said long block so everything will transfer.
Genpu long block looks like this
http://img.tapatalk.com/d/13/03/31/gugetahe.jpghttp://img.tapatalk.com/d/13/03/31/ruvaja7e.jpg
mzr0818 03-30-2013 01:15 PM
My understanding is the rods are the same but the pistons have a dish built in on the top of the piston in a pu to devert some of the fuel back away from the rings reducing shearing
holeinmypocket 03-30-2013 03:05 PM
I'm getting a long block w manifolds, turbo, pumps, alternator, pulleys pretty much anything that is attached to the block from a 2010 ms3
Sid3wayS 03-30-2013 04:48 PM
^Thats what I had understood and the reason for my argument. Obviously a long block with no accessories you would use your own
In the op he says engine not long block.
mzr0818 03-30-2013 06:57 PM
He's looking at a complete engine.
Complete engine > Long block > short block > bare block.
holeinmypocket 03-30-2013 07:20 PM
Yes complete engine
Page generated in 0.18877 seconds with 11 queries
