 Old 04-07-2009, 07:52 PM   #41
phantomspeed3's Avatar
Posts: 559   (View Stats)
phantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud of
well I always floor it into every parking spot so...I NEED ONE SHUTUP
2007 MS3: HKS Hi-Power CBE with muffler cut-out, HKS CAI, TurboXS RP, Forge BPV, PTP Air Straightener, OCC, MBC(not hooked up der), Cobb AP, Denso Iridium ITV22 Spark Plugs, PG Turbo Inlet
phantomspeed3 is offline   Reply With Quote
 Old 04-07-2009, 09:26 PM   #42
Bigbody250's Avatar
Posts: 258   (View Stats)
Bigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud of
Groaned at 227 Times in 193 Posts
Whatever man... If my turbo starts smoking it just gives me a reason to go BT. I'm not going to waste my time with the stocker again
"Stock until the warranty runs out!!!" "Spent way to much money on my baby"
Bigbody250 is offline   Reply With Quote
The Following User Says NO Thank You to Bigbody250 For This Un-useful Post:
 Old 04-07-2009, 09:30 PM   #43
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
solid philosophy.. except for the stock block being allergic to bigger turbos, and by allergic i mean it sneezes rods. lol.
 Old 04-07-2009, 09:38 PM   #44
how big turbo we talking makes our little buddies sneeze rods?
 Old 04-07-2009, 09:44 PM   #45
aspiring turbo guru
08_ms3_gt's Avatar
well, considering the stock turbo does, i'm guessing a k03 could manage. lol.
IMHO you can upgrade the turbo if you go thru the proper steps - fueling, tuning, w/m, etc.
and, additionally, i think it's more the combination of turbo+ECU+fueling that = blown engines. and there aren't too many blown engines. the point i was trying to make is that, if the stocker goes bad, take the necessary precautions before throwing a big turbo in. there are guys on here with stock block that made plenty of power - laloosh, whoosh, etc.
and there's also the argument that the 2.3 DISI turbo just sucks and blows b/c, well, it sucks...
 Old 04-07-2009, 09:50 PM   #46
Bigbody250's Avatar
not sure how big i want to go but I have easy access to stock cummins turbos but if it turns out to be too much of a pain I'm eyeing the 3071r... and whatever i do its going to be low boost, untill a true way to get fuel into the motor comes about...
 Old 04-12-2009, 12:04 AM   #47
kwsmithphoto's Avatar
Posts: 1,035   (View Stats)
kwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the world
Groaned at 41 Times in 9 Posts
Diesel truck turbos are built for big diesel trucks, I'm not sure there's much of a correlation to the flyweight little turbos in our cars.
But I do agree that you should -drive- the temps down by staying off the boost and go easy on the motor before you shut it off. If you're doing a track day, the rule of thumb is that when you pull off the track you just crank the heater and open the hood while it idles for a few minutes, but there's a reason for cool down laps, so use them wisely. As soon as I see the flag I slow way down and blast the heater.
Not very practical for a street driven car though. Basically, if you've been out in your local area jamming the car around then hot foot it right up to your driveway, yes indeed, let it idle for a while. Personally, I try to plan this in advance and just drive the car gently for the last few minutes while the car is still moving, which improves cooling efficiency anyway. Then I might sit for a 15-30 seconds and finish listening to a song, checking my texts, picking up any trash, or even wipe down the interior. But that's only if I've been "bad" and drove it hard all the way to my house.
Moving air and driving gently is a lot more effective than just idling a hot motor while stopped anyway, so that's what I tend to favor, and the laws of physics are on my side. Even though the engine produces more heat off-idle, the water and oil pumps are moving more fluid, and you have the advantage of air moving through the whole engine bay, which cools everything down, not just the turbo.
It also helps that since I live in a busy urban area that the car is idling much of the time anyway while waiting for stop lights and traffic. I use that time to help cool it down too. Almost every time before I park it, the car has been running at low volume long before I shut it off.
kwsmithphoto is offline   Reply With Quote
 Old 04-12-2009, 07:06 PM   #48
Bigbody250's Avatar
My friend fabbed up a turbo from a 2000 cummins onto a datsun 280.... Ran like a champ too!
 Old 04-13-2009, 07:42 AM   #49
tuckaloe's Avatar
Posts: 53   (View Stats)
tuckaloe has much to be proud oftuckaloe has much to be proud oftuckaloe has much to be proud oftuckaloe has much to be proud oftuckaloe has much to be proud oftuckaloe has much to be proud oftuckaloe has much to be proud oftuckaloe has much to be proud oftuckaloe has much to be proud oftuckaloe has much to be proud of
Holsets off the Dodge Cummins set ups are pretty damned popular with the boosted 4 banger kids these days.....results are quite good. The turbo's can be had way cheap, they're very reliable and the results are speaking for themselves. Do a "holset" search on Hondatech if you want to see more.....
tuckaloe is offline   Reply With Quote
Redline? ptperformance MazdaSpeed 3/6 - ECU Computer Tuning 24 12-28-2008 01:09 PM
redline ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 22 09-03-2008 06:04 AM
Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails $49.99 at newegg Haltech Hot Deals Section 0 04-16-2008 09:40 AM
COOLER MASTER Real Power Pro 750W Power Supply $59.99AR at ZipZoomfly Haltech Hot Deals Section 0 04-14-2008 05:00 PM
Antec Neo Power 500 ATX12V 500W Power Supply 100Vac to 240Vac $69.99 Free Shipping Haltech Hot Deals Section 0 04-01-2008 09:41 PM
Page generated in 0.31096 seconds with 24 queries
