60-100 psi!!!?? Just wondering what if your shits and giglles I set the standback to 60- 100 psi? would the turbo over spool on start up? thoughts.. |
lol it wont spool on startup/no load regarless what it set at, you need load. |
wonder what wold happen when you floor it in first? remeber with the standback you don't get the boost cut feature in first gear.. |
I tell you exactly what happens. I know because the vacuum line on my MBC popped off and the waste gate stayed closed. The car lurches and the turbo starts making a horrible rattle noise. I dont know what would happen if you did it for more than just few second. Bad things me thinks. |
To quote this document: http://www.accessecu.com/accessport/...ks%20v1.00.pdf "If you run a turbocharger beyond its compressor efficiency range, it will turn into a flame thrower" |
sweet maybe we could utilize the turbo and turn it into some sort of flame spewing weapon |
| All times are GMT -7. The time now is 07:11 AM. |
