70% ABS PedD I have this thread over in another section but I thought I'd put it up here too. When I'm at WOT, my ABS PedD PID only goes to 70% and wont go any further. Is this normal, or is my car limited to only 70% throttle. Does anyone out there see 100% for this PID at WOT? |
i thought the fcf opened the throttle plate |
It does remap everything but this is more about the DBW input rather than the throttle itself. OP what gear? All? |
some of the DH parameters are weird.....i dont know off the top of my head but that might be the wrong one for accel pedal position..or maybe the DH just scales it weird/wrong. Sorry this isnt more helpful, lol |
OP should take a log of the pedal position and absolute throttle position as well and post it here. |
i don't think i understand anything in this thread |
This happens in every gear. I did a pull in 4th to 5500, got to 70% and wouldn't get any higher than that, even with my foot smashing the pedal to the floor. This is the pedal distance PID. ABS PedD. The Absolute throttle PID also shows it capping between 65-70%...much underneath CPE's reading of ~92% cap. I imagine it is a DH issue, but I wanted to check with you guys to see if you're seeing 100% for this PID. Because if you are, something is wrong with my DBW system. I'll do a log as well. |
im sure you're fine.... we're not even sure what the PID is measuring or if the scaling is right. |
Regarding Pedal Position, aaronc7 is right, there should a PID called "Actual Pedal Position" under the Mazda specific parameters. This should sync up to what you're actually doing with the gas pedal. |
word, i log that. shit shows 100% when you floor it. throttle plate is still closing though |
Yeah, there are a bunch...its quite confusing and I think I was wrong thinking that the ABS PedlD was the proper PID for the gas pedal. I logged every one of them except the mazda specific one on my way home (I didn't know there was one in that menu). All show caps at 60-70%....trying to figure out how to get my DH to store a log on XP (with a helpful thread)....and once I do, I'll get it up here. But I'm sure the Mazda specific one will show the 100% I am looking for. Damn, I was hoping that there was an issue and I still had 30% pedal left. Getting that back would have yielded one giant kick in the pants to the butt dyno. |
you have 30% throttle left... |
I'm not sure if I do or not based upon what others have reported. I don't think these PIDs show 100% even for those with a CPE Full Throttle Control Flash or an AP tune. If I do, I want it back from my stubborn, overprotective mother of an ECU! |
i thought it was pretty common knowledge that the throttle plate was closing early on these cars |
merge |
Confirmed... The Mazda Specific PID "Actual Pedal Position" produced a reading of 100%. Thanks for the advice. |
| All times are GMT -7. The time now is 07:21 AM. |
