![]() | | #1 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
(Thread Starter) | Not Ranked : 0 score Big thank you to Chad, Kurt, and Randy. We did this with a jack and jackstands, and a large assortment of tools. Hand tools would work, but the power/air tools we used definately cut down on time. At first, the clutch engagement was at the very bottom (all the way depressed). It was kinda awkward at first. Through the course of the 60 mile drive home, it started to settle in. The pedal engagement is slightly stiffer, but in the middle of the throw. I like the feel and engagement alot. The lightweight flywheel is definately noticable. The engine free revs and drops noticably quicker. As i said. More to come. -Sean
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 Last edited by socks; 03-22-2009 at 08:02 AM. |
| The Following 8 Users Say Thank You to socks For This Useful Post: | 06Speed6 (03-22-2009), 802MS3 (03-23-2009), FCmaniac (03-25-2009), gsrtype1 (03-22-2009), phailerider (03-22-2009), Phantom (03-22-2009), phillyb (03-23-2009), SharkDiver (03-22-2009) |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score Nice work.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score Awsome dude did you get the puck or street? Can you do some vid of the enigine reving etc?
__________________ Last edited by gsrtype1; 03-22-2009 at 06:08 AM. |
![]() | | #4 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score i got the 6 puck sprung. Ill work on the vids. i cant find the card for my camera.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
![]() | | #5 | ![]() |
Groans: 102
| Not Ranked : 0 score Cool, I sent in my puck disk for s a street disk cuase of what everyone said about pucks being to impratical and chattering. Whats your opinion is there a bunch of chatter?
__________________ |
![]() | | #6 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score no chatter, but i dont know if the noise will appear til its "broken in" the worst thing right now is my exhaust. the joint at the cobb cbe and cpe dp isnt the friendliest. im going to have to figure something out.
![]() | | #7 | ![]() |
Groans: 102
| Not Ranked : 0 score Cool hopefully its works out!
![]() | | #8 | ![]() |
| NEC ![]() Join Date: Mar 2008
Rep Power: 473 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score You guys tore through that install... I don't know how you do it.
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* Last edited by subparpunk03; 03-22-2009 at 08:08 AM. |
![]() | | #9 | ![]() |
![]() Join Date: May 2008 Location: NOVA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
Groaned at 47 Times in 40 Posts
| Not Ranked : 0 score it will chatter, and regardless your going to get noise with the deletion of a dual mass. the noise will come when its broken in, when you slip the clutch a bit to get it going. sounds like rurrrrr.
__________________ a built motor is not a built motor without being sleeved |
![]() | | #10 | ![]() |
![]() Join Date: Jul 2008 Location: The Ocean State
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
| Not Ranked : 0 score 4hrs to install a clutch and flywheel on jackstands? impressive makes me think putting the flywheel in with the stock clutch might not be that big a waste of time
__________________ 07 CB Speed3 COBB AP S2+, MS CAI (shorty w/ straightener), RPMC inlet, ETS 3.25", Devils Own S2 Alchy Injection, PG Manifold V2, TXS DP (with Cobb highflow cat soon), TXS mid, MS CBE, HKS Plugs (1 step colder), Fidanza Flywheel, KMD CDFP internals, COBB Sways, Koni Dual Adjustable Shocks, AWR 88 trans mount, Hawk HP+ pads (F+R), Motul RBF 600 brake fluid, 18x8 +50 weds sa70's 245/40 falken rt-615's, V1 hardwired, Autometer ES Gauges (boost/vac, water, oil pres), Dashhawk, stock turbo with modified boost control system |
![]() | | #11 | ![]() |
Rep Power: 1791 ![]() Thanks: 2,239
Groans: 62
Groaned at 156 Times in 148 Posts
| Not Ranked : 0 score Sean dude take pictures! Too late now though. lol. |
![]() | | #12 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score yea. sorry. it was a last minute deal. We were sitting at chili's for dinner and i threw it out there, and we went back to Chad's to put er in.
![]() | | #13 | ![]() |
| Banned ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 49
Groaned at 179 Times in 125 Posts
| Not Ranked : 0 score |
![]() | | #14 | ![]() |
Groans: 49
| Not Ranked : 0 score ps... i want to drive it again. But my impressions of it compared to the spec i got is that.... i'll keep my spec. |
![]() | | #15 | ![]() |
![]() Join Date: May 2008 Location: West Chester, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score good to see that you like the clutch Sean! ACT is definitely on my list when I need a new clutch.
__________________ 2007 Mazdaspeed3 Sport, True Red |
![]() | | #16 | ![]() |
Groans: 125
Although, the grippy engagement makes my exhaust leak even worse. lol
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 | |
![]() | | #17 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score 4 hours!?!?! damm u non T-Case guys lol
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
![]() | | #18 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score I want a new clutch too. ![]() I'd like to attempt the install also but I need to know what's involved. What's the going price on the spec and the ACT and what stage is a step up from stock? Anyone got links so I can check them out? Thanks |
![]() | | #19 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score the spec is like 599 + the cost of any upgrades. you can use this with the stock flywheel, or you can use this with the fidanza light weight flywheel. the act's are around 750 give or take the deal you find. But that includes the cost of a flywheel. the Organic full faced street disc is a good step up from stock. Their torque capacities are known to be underrated.
![]() | | #20 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score i'm a n00b...so pardon me. you put on clutch and new flywheel? that's dope. quicker revs...nicer shifting? what else are the benefits of this? |
![]() | | #21 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score errr... shifting isnt exactly nicer. drivability of the car obviously took a hit. not a horrible one, but definately a downgrade in drivability with this 6puck version. However, the revs are quicker, and i will be able to launch the shit out of it on slicks or drag radials. next. wotbox. then, back to the track.
| The Following 2 Users Say Thank You to socks For This Useful Post: | phillyb (03-23-2009), SharkDiver (03-24-2009) |
![]() | | #22 | ![]() |
![]() Join Date: May 2008 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score Shon, you are POSSESSED with the "Speed Demon...." You Need Help.. Keep us posted...
__________________ [SIGPIC][/SIGPIC] CPE-SRI - HKS-SSQV - CPE-MM - TWM SB - Cobb AP Cobb FMIC - Cobb CBE - DP 18x8 +48 HP Design 235/40/18 BFG Riken, H&R Springs |
![]() | | #23 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score HA. yea. what can i say. I see the light. Im close to the end. All thats left: Exhaust manifold ITFP NX Direct Port Wet Kit Traction Bars CPE Mounts
![]() | | #24 | ![]() |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score what is ITFP?? sorry for my ignorance
__________________ 2008.5 MS3 Metro Gray...slow |
![]() | | #25 | ![]() |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
![]() | | #26 | ![]() |
Groans: 27
| Not Ranked : 0 score your adding another fuel pump to your setup?? im a newb at this lol
![]() | | #27 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score No, ill be running a 255lph fuel pump in leui of the stock 155. I will be doing this to keep a constant supply of fuel in the low pressure fuel line, because thats where i will get my fuel source for the wet nitrous kit.
![]() | | #28 | ![]() |
![]() Join Date: May 2008 Location: Bellevue, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score Do you have any engine mounts right now? I wonder how shifting would feel if you had upgraded trans mount or TurbineTech front engine mount...? Good shit nonetheless...
__________________ '06 MS6 Black Mica Street Unit Block, CP Pistons (9.0:1), Pauter Rods, CPBoost Top-mounted Turbo Exhaust Manifold w/ Tial 38mm External Wastegate, Custom 3", CP-E FCF (No Boost cut, 3.25" MAF), CP-E PnP Standback V2, CP-E HPFP, CP-E FMIC Core w/ Custom piping, Denso Spark Plugs, Custom Inlet w/ 3.25" MAF Housing, VCTS Delete, EGR Block-off, Saikou Michi OCC, Fidanza Flywheel, HD Signature 18x8" MSR Wheels, HTR Z III's 235/40/18, BS Delete, TWM Stage 2 SS Kit, Dashhawk, Perrin EBCS. |
![]() | | #29 | ![]() |
![]() Join Date: May 2008 Location: Saint John, NB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score How is the clutch so far? Any update after a few miles on the clutch? You mentioned a video do you have that to post? |
![]() | | #30 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score Kenne bell boost a pump.... Way easier to install and feeds my wet kit just fine with no loss in rail pressure at all !! Just a thought. |
![]() | | #31 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score Id rather not. Id rather run a bigger pump, if i can find a way to get it in there.
![]() | | #32 | ![]() |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1820 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
I'm not 100% sure that the MS3 and MS6 share the same fuel bucket but if they do, be prepared to spend $130 for the tool to remove the pump from the tank and hundreds of dollars buying different drop in pumps that don't fit I have a 260lph SARD pump sitting here that is closest to fitting, but still doesn't fit. Paid $330 for it....neat paper weight
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 | |
![]() | | #33 | ![]() |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
![]() | | #34 | ![]() |
| Not Ranked : 0 score So how is the clutch doing? I have a HUGE feeling im gonna need an upgrade soon. Mine has 30k on it now and feels good as new. My last dyno showed 335ft/lbs of TQ, so with my nitrois i should be right around 400ft/lbs. I just dont think the stocker will hold it... Not long anyways. I know the ACT street kit is only rated to 365ft/lbs so that is prett useless IMO. I would need the puck clutch as well. I kinda would rather the fidanza/spec stage 3+ though. It is a full face clutch that will hold about the same power as the ACT puck design. The problem is that combo costs twice as much !!
__________________ Turbo boost + Nitrous boost = TRU-BOOST |
![]() | | #35 | ![]() |
![]() Join Date: Apr 2008 Location: Baltimore MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 199
| Not Ranked : 0 score When you say "drivability of the car obviously took a hit" what do you mean? Harder to engage clutch?... |
![]() | | #36 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score the padal is stiffer, the engagement is rough at times. Whoosh, im thinking of having a local shop make a new tank hat/bucket. Im prepared to spend some cash on it if it means i can be comfortable running nitrous.
![]() | | #37 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score how is it on stop lights at hills
__________________ 2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot Future Mods[/B] auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal! |
![]() | | #38 | ![]() |
I am interested in this clutch set up though... I just may do the same soon.
__________________ Turbo boost + Nitrous boost = TRU-BOOST | |
![]() | | #39 | ![]() |
Groans: 125
(Thread Starter) | Not Ranked : 0 score with this clutch, i am able to consistently hit 1.9 60's, on drag radials. after the 60' though, all hell breaks loose, i ordered new LCA bushings... our pumps arent proven to run at 16v currently (thank you for being a test pig tru) and by the time im there, it may very well be an option. hell, by the time im there, maybe a company will have a drop in tank upgrade... i think once i get wheelhop under control, ill be able to be a little harsher on the launch to get the 60's down. but im happy with 1.9's on drag radials for now.
![]() | | #40 | ![]() |
| Not Ranked : 0 score 1.9's is good for DRs. I run full slicks and usually get 1.8-1.9's. I also get zero wheelhop. Slicks are way better in that aspect. They hurt you down the track though. Dragging two wide ass hell half flat tires isnt exactly efficient. I have run the stock pump up to 17.5V without issue. Whoosh also had a stock pump flow tested at 16v. It isnt anything to worry about. I currently have been running mine at 15v daily for months.
| The Following User Says Thank You to TRU-BOOST For This Useful Post: | davidomalley (01-24-2017) |
| Need a New Clutch | MisterMatt | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 02-21-2009 03:44 PM |
| What clutch to get? | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 01-31-2009 10:35 PM |
| Might have f'd up my clutch? | redspeeeed3 | Mazdaspeed3/6 General Discussion | 1 | 11-12-2008 12:38 AM |
| is this my clutch? | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 08-06-2008 10:11 PM |
| clutch | MisterMatt | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 06-24-2008 12:03 PM |
