![]() | | #1 | ![]() |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,113
Groans: 83
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
Groaned at 83 Times in 60 Posts
| Not Ranked : 0 score in before Rodrigo's FUCK ACT!!!!! in big red letters probably
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
Groans: 83
(Thread Starter) | Not Ranked : 0 score Yeah seeing his post was actually the big reason I was deciding against one, and a couple threads about them. I also checked corksport and two people left reviews seeing it's junk but I feel like it's the same people from this website IDK
![]() | | #4 | ![]() |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score FUCK ACT!!!!!!
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following User Says Thank You to rodrigo For This Useful Post: | DONOTBUGME (06-03-2011) |
![]() | | #5 | ![]() |
| Banned ![]() Join Date: Nov 2010 Location: Tampa, FL
Groaned at 28 Times in 11 Posts
| Not Ranked : 0 score PM sent |
![]() | | #6 | ![]() |
![]() Join Date: Jul 2009 Location: Connecticut
| Not Ranked : 0 score I did the ACT 6 puck race clutch in mine and i didnt have any problems with the clutch, what i did have issues with was with the slave cylinder compensating for the extra pressure and snapping the push rod. after the install the pedal became about 6 times harder to push so i had to use an 06 maxima slave and put a new end on the hydraulic line and it fixed the issue. The pedal stilled stayed hard to press though. |
| The Following User Says Thank You to Blitzkrieg For This Useful Post: | MSFer87 (06-08-2011) |
![]() | | #7 | ![]() |
![]() Join Date: Mar 2011 Location: Medina,ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score no issues here and i've got the organic street clutch just make sure you get the new one with the heavy duty pressure plate...i have like 3-4000 miles if not more on it so far no issues love it pedal is stiffer than stocker as well.
__________________ HPS CAI , Turbo XS DP/RP, Turbo XS RFL BOV modded to Recirc, Glowshift Gauges, Stage2+SF 93 btv102 Tune, blacked out tails, ATC ZX5 HD Clutch Kit, SURE RMM. |
| The Following User Says Thank You to MS3TURBOD07 For This Useful Post: | MSFer87 (06-08-2011) |
![]() | | #8 | ![]() |
Groans: 83
(Thread Starter) | Not Ranked : 0 score I appreciate the input keep us informed because I'm sure there people that are interested to how the clutch performs.
![]() | | #9 | ![]() |
![]() Join Date: Jun 2008 Location: St. Pete, FL
Rep Power: 0 ![]() Thanks: 5
| Not Ranked : 0 score i had picked up a new ACT twin disk for my dad's Z06, haven't installed it yet but it looks well built, so when i found a factory refurbished street disk for the MS3 on fleabay i bit. seller said it was installed incorrectly and burned up in a few thousand miles. i called ACT and asked of any special instructions, they said just do what the manual says, and drive 300-600 street miles before flogging it. or several hard slips in high gear, but that is not the best method. checked with the local tranny expert, and he said definitely if it is not broken in correctly it will fail. most common issue he sees. i have about 1000 miles so far no issues. slightly more pedal pressure than stock, grabs lower in the travel than stock. i like it. stock clutch still looks like new, 35k miles on it. |
![]() | | #10 | ![]() |
Groans: 83
(Thread Starter) | Not Ranked : 0 score Thanks I ended up getting the six puck just haven't got around to installing it yet
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/act-street-organic-replacement-going-double-fail-82439/ | ||||
| Forum Mazda Performance Series - Zobacz temat - [3BK 6GG] - sprzeglo - jakie zamienniki? | This thread | Refback | 06-24-2011 08:57 AM | |
| Gilles: Chrysler done with 'Edge' look, going 'Organic' | Haltech | Automotive News | 0 | 08-20-2008 10:30 AM |
| Gilles: Chrysler design will become more 'organic' | Haltech | Automotive News | 0 | 08-20-2008 06:00 AM |
| Gilles: Chrysler design will become more 'organic' | Haltech | Automotive News | 0 | 08-19-2008 08:10 PM |
