 Old 04-20-2011, 02:43 PM   #1
Justin Lee's Avatar
Posts: 150   (View Stats)
Justin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond repute
Groaned at 32 Times in 15 Posts
Default Adding Transmission Fluid
Is there a separate place to fill the diff at or does it fill all of it from where the main plug is?
Justin Lee is offline   Reply With Quote
 Old 04-20-2011, 03:03 PM   #2
ScarMS3's Avatar
Posts: 2,088   (View Stats)
ScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the world
Groans: 97
Groaned at 31 Times in 25 Posts
Search, there are how to articles. Drain is obviously at the bottom, fill is not the angled bolt, but it's on the front of the trans.
ScarMS3 is offline   Reply With Quote
 Old 04-20-2011, 03:05 PM   #3
mroclimbr's Avatar
Posts: 245   (View Stats)
mroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond repute
Groaned at 30 Times in 14 Posts
if your dipstick is reading low, I'd just pout some down the tube where you check it. It obviously goes to the right place. Of course, I'd just add a little at a time, because overfill is a bad thing.
mroclimbr AEM CAI, OCC, Turbosmart BPV, CP-e turbo downpipe, JBR rsb, JBR 80 duro rmm, 3" CNT CBE, upgraded hpfp, Guardian Angel, JBR heavy knob, Cobb ap, currently stage two on 93 octane, blose speakers and amps all replaced and upgraded, dash daq, full replacement shifter, new ko4 compliments of Mazda at 48k miles.
mroclimbr is offline   Reply With Quote
 Old 04-20-2011, 07:20 PM   #4
ScarMS3's Avatar
Groans: 97
What dip stick?
The Following 3 Users Say Thank You to ScarMS3 For This Useful Post:
easy (04-20-2011), justint5387 (04-25-2011), karl-hungus (04-21-2011)
 Old 04-21-2011, 05:11 AM   #5
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
transmission doesn't have a dipstick bud
 Old 04-21-2011, 08:36 AM   #6
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
no dipstick, but beware the angled bolt of death!
 Old 04-21-2011, 02:49 PM   #7
Justin Lee's Avatar
so there's NOT a separate location to fill the diff?
 Old 04-21-2011, 06:20 PM   #8
ScarMS3's Avatar
Groans: 97
Do you have a three?
 Old 04-21-2011, 08:27 PM   #9
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
^word. we don't have a differential that needs filling. just a top fill bolt and a bottom drain bolt. there is a great how to for changing transfluid on here. search!
howver, if you have a 6, good luck, i'm not sure what's available.
transmission fluid change ottoblotto CX-7 > Engine, Transmission & Driveline 35 09-25-2017 07:31 AM
Gen 2 transmission fluid consensus paradigme 2010 MS3 - Engine, Transmission & Driveline 15 07-10-2010 07:21 PM
Windshiled fluid GQ_WhiteMS3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 06-26-2009 01:24 PM
Autoblog Maintenance 101: Transmission fluid and filter Haltech Automotive News 0 05-25-2009 08:40 PM
Chevy Suburban Transmission Fluid, Using CO2 to Fill a Tire, How To Unclog Windshield Wiper Fluid Spouts, Dead Battery A Haltech Automotive News 0 05-15-2009 03:10 PM
Page generated in 0.29045 seconds with 25 queries
