-   -   AFR not reading, system too lean at idle (http://www.mazdaspeedforums.org/forum/f10/afr-not-reading-system-too-lean-idle-162523/)
Boost Addict 01-12-2014 11:45 AM
On my AP my afr constantly reads 29.95 and will occasionally read normal for just a second than go back to 29.95. Could this just be a bad connection or could the sensor have came unplugged?
Boost Addict 01-12-2014 12:25 PM
Car runs and drives completely normal also
Agent_Orange 01-12-2014 12:47 PM
3 years here and you make a troubleshooting thread without posting logs? Shame on you.
Your primary o2 is probably toast.
btstarcher 01-12-2014 01:25 PM
Well it may be disconnected, but it's not as likely as a failed primary O2 sensor. RockAuto has them for a little over $100.
Tokay444 01-12-2014 01:34 PM
primary o2. 100%
Boost Addict 01-12-2014 02:15 PM
Log for what? It will read 29.95 the entire time.
Boost Addict 01-12-2014 02:25 PM
Link to part? Im coming up with about 5 different ones, and not sure which one is the primary o2
Tokay444 01-12-2014 02:28 PM
NTK 24357
Agent_Orange 01-12-2014 04:37 PM
Your right, logs are way overrated. :ugh2:
Good luck with your sensor fag.
Page generated in 0.17122 seconds with 11 queries
