-   -   Another engine noise thread, or something loose? (http://www.mazdaspeedforums.org/forum/f10/another-engine-noise-thread-something-loose-185244/)
Tweaek 03-05-2015 12:06 AM
What's up all. I'm wondering if any of you have heard something similar to the sound in the video. I just noticed this noise last week when idling. No KR showing up anywhere.
Sound like something is loose or something internal to the engine?
Doesn't sound like the VVT noises I've read about and listened to in other threads. I also checked my chain to make sure it was still tight and that's good. Any other ideas?
FYI I'm at 43k miles if it's relevant at all.
https://vimeo.com/121330626
frothy 03-05-2015 05:27 AM
Loose pulley maybe?
Tweaek 03-07-2015 03:44 PM
Originally Posted by frothy (Post 2826365)
Loose pulley maybe?
I'll have to get under there and see. Good idea thanks
frothy 03-07-2015 04:15 PM
http://i58.tinypic.com/33vhm4w.jpg
Tweaek 03-08-2015 09:03 AM
So just to be clear on my part, the idler is what you're thinking I should be looking at?
Also I looked at my belt and it has what looks like a crack down the center the entire length of it. Is that a sign of something being loose or normal wear and tear?
Again I'm at 42k miles so doesn't seem normal to me for the mileage.
frothy 03-08-2015 09:38 AM
The tear could be caused by either of the things you mentioned. Replace it.
While it's off, check ALL of the pulleys listed above -- not just the idler. Give 'em a spin -- see if they squeak or rattle. Check for loose or missing bolts, etc...
Tweaek 03-08-2015 12:37 PM
Thanks frothy!
ms3destroyer 03-08-2015 01:17 PM
Ive got the same noise with mine. Let me know when if you figure out what is causing the noise
Tweaek 04-03-2015 08:58 AM
So I ended up replacing my tensioner pulley and it seems to have resolved the problem.
I noticed that my serpentine belt had a split down the middle of it that ran the length of the belt which didn't seem right. When I pulled off the tensioner pulley there were small rocks stuck in it which had caused the tear and I think contributing to if not causing the noise.
Page generated in 0.17435 seconds with 11 queries
