![]() | | #41 | ![]() |
![]() Join Date: Mar 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 510
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score
__________________ BONE STOCK. |
![]() | | #42 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
What I am interested however, is the effect of removing the BSD on Used Oil Analysis's. With the addition of a quart of oil to the overall vehicle capacity, wear metals should DROP. If someone did a before BSD UOA, and an after BSD removal UOA, and wear metals ROSE, this could indicate that removing the BSD could have some secondary issues. By all reports though, wear metals should noticeably drop...I just haven't seen anyone do a before/after UOA report yet, which would be really interesting... | |
![]() | | #43 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score i don't care about vibes... i want to take the gear out... any negatives to this? |
![]() | | #44 | ![]() |
![]() Join Date: Apr 2008 Location: MS
Rep Power: 845 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Groans: 56
Groaned at 15 Times in 14 Posts
Plus I did the spin-on conversion and transmission flush too. But I'd say that if I had to do it again it could be done in under 2 hours for sure.
I just wasn't going to risk getting fine pieces of metal in my block. And I don't see it causing any issues being there. It might sling some oil but hell if it does then it was doing it with the BS in there as well. | ||
![]() | | #45 | ![]() |
Groans: 1,940
| Not Ranked : 0 score so clean it thoroughly |
![]() | | #46 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score id say in and out in 2 hours. 5 is a little crazy.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
| The Following User Says Thank You to socks For This Useful Post: | 802MS3 (02-28-2009) |
![]() | | #47 | ![]() |
| Banned ![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 568
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score |
| The Following User Says Thank You to darkstarmotorsports For This Useful Post: | phillyb (03-01-2009) |
![]() | | #48 | ![]() |
![]() Join Date: Apr 2008 Location: San Diego, CA
Rep Power: 493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 666
| Not Ranked : 0 score Does this actually remove the balance shaft, or just the gear that runs it? I saw on a different thread that you remove a gear and its housing. I didn't actually see a shaft. I thought the shaft ran the length of the block. |
![]() | | #49 | ![]() |
Groans: 56
(Thread Starter) | Not Ranked : 0 score There are two balance shafts inside of the assembly, or balance shaft unit, whatever you want to call it. You can't see them. |
![]() | | #50 | ![]() |
| Not Ranked : 0 score The shaft is bascially the crank, then there is a large gear that is mounted to it. The rotating gear mates to the balance shaft assembly, which then rubs you of power. |
| The Following User Says Thank You to darkstarmotorsports For This Useful Post: | BCMS6 (03-01-2009) |
![]() | | #51 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
![]() | | #52 | ![]() |
Do not leave the BS assembly in the motor if you plan on turning up the boost. The all casted steel BS assembly cannot move around like the frail aluminum block. Its a material missmatch that will eventually fail if your running higher then stock boost levels. I would like to see some UOA testing as well, but there are just to many variables with getting consistant results from something like this. If someone were to do this in one day and do back to back simiulation testing on a chasis dyno then I think those results would be fair. One street driven UOA to the next is always going to have some changes in it, be it climate or driver change in drive style you will never get a consistant test with a street driven car. | ||
![]() | | #53 | ![]() |
![]() Join Date: Dec 2010 Location: Jacksonville, FL
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score hi, i was wondering its been almost 5yrs since you posted the BSD review and i was wondering how is the car doing with it. i am a little concerned about the whole harmonic noise and if it will damage or shorten the engine life, i know that oil change and drive behaviors have to do with it but still will like to find recent info before i do the BSD on my MS6. anyone else if you have new info please share thank you!! thank you! Arthur
__________________ 06 MS6, Cobb AP, CORKSPORT 'Power Series' FMIC, Turbosmart dual port in VTA mode, EGR Delete, Corksport DP, OCC, 2.5 magnaflox catback and 2.5 SU test pipe, Oil Pan Baffle with BSD, NGK Iridium Spark Plugs |
