Any specialist or skilled mechanic for a ms6 in NJ My motor is consuming alot of oil. when i step on the gas and give it full throttle i see black smoke out of the exhaust. I want to motor looked at and I need to know what is wrong. can anyone help? |
@SPEED6 KILLAH is your one stop mad scientist! |
Speed6 killah can you please post on here I dont have the 15 posts yet to private message you.. |
its most likely a bad turbo. can you post up some info on your car? |
Welcome to the blown stock turbo club, nice to have ya Actually I kid, if its black smoke under full throttle you probably have a sensor or tuning problem. Edit: You should post this in the ms6 section, thats where most of the real drivers and tuners hang out. |
And part outs too. |
How many mile do you have ? |
The car has 139,140 miles on it and I drive 75 miles one way to the base and I got back home and I need to add oil because it's low. There is no oil leak I took the cover off the bottom because I assumed it was a leak. There is no check engine light on either |
I don't think even a really bad tune can make oil disappear. ;) If you're losing oil, and it's not leaking out the bottom, then it is either going into the coolant (cracked head/gasket) or pushing past the pistons. If the former, you'll probably have oil floating in your coolant overflow tank. However, given your car's mileage, my money's on worn rings. Do a compression/leakdown test. There are several members in central jersey who can help with this. It's not that hard. I'd suggest posting in the Nator NJ section for help with this. Sent from my DROID2 using Tapatalk 2 |
I haven't noticed any oil in the coolant over flow tank. I will have to go on the nator nj and ask and see who can look at it.. Thanks for the help |
| All times are GMT -7. The time now is 07:24 AM. |
