 Old 10-15-2009, 02:58 PM   #1
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Default Anybody know where the solenoid purge valve is located?
I think my gas stublme rich issue witch now is a cosatant problem is caused by a leaky solenoid purge valve, this valve leaks fumes into the intake(in an controlled manner) if its messed up youll get an extreme rich condition. The valve is $90 bucks I think it might be just to the left of the tmic but im not sure what it looks like or if its close to the gas tank?
 Old 10-15-2009, 04:12 PM   #2
SSinstaller's Avatar
Posts: 3,827   (View Stats)
Groans: 51
HERE:
Soon to be installed:
ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000262 Fuel Pump : NX 15718 : Split Second AIC
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
gsrtype1 (10-15-2009), msalva2 (03-12-2012)
 Old 10-15-2009, 04:19 PM   #3
gsrtype1's Avatar
Groans: 102
Originally Posted by SSinstaller View Post
HERE:
thanks bro!
 Old 10-16-2009, 06:06 PM   #4
gsrtype1's Avatar
Groans: 102
All the symptoms pointed to the purge valve, im randomly super rich at idle witch is causing my problems. Its not though switched it out and my problem remains
 Old 10-16-2009, 06:08 PM   #5
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
damn and thats a expensive little guy. sorry man
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard"
1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action"
skeeter149 is offline   Reply With Quote
The Following User Says Thank You to skeeter149 For This Useful Post:
gsrtype1 (10-16-2009)
 Old 10-16-2009, 06:12 PM   #6
gsrtype1's Avatar
Groans: 102
Yeah bro $90 bucks... I may try to see if I can return it on monday but prob not cause its electrical.
 Old 10-16-2009, 09:36 PM   #7
skeeter149's Avatar
Groans: 91
hope they take it back cause thats a oil change and a tank of gas. man, good luck finding this little gremlin
 Old 10-20-2009, 03:43 PM   #8
robspeed3's Avatar
Posts: 477   (View Stats)
robspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond reputerobspeed3 has a reputation beyond repute
Groans: 58
Groaned at 286 Times in 281 Posts
ok look at this diagram i have a cpe cai and the wire going from the vavle to the fire wall i dont have that any anymore im assuming because i got a cai do i just need to cap that end piece off or.....???? Im lost i think this is the reason of why i keep getting a check engine light or gross leak dectect evap system or some crap like that!!
ok after reviewing some engine pics it seems i may have a vacuum leak from this vavle because my vavel doesnt connect to and hose that runs to the firewall i have a cpe cai can anyone tell me if there cpe cai is like this???
bump for help!!
Don't make me pop the trunkt!!
Last edited by robspeed3; 10-21-2009 at 01:58 PM. Reason: MSF Database - Automerged Doublepost
robspeed3 is offline   Reply With Quote
The Following User Says NO Thank You to robspeed3 For This Un-useful Post:
 Old 10-26-2009, 06:07 AM   #9
robspeed3's Avatar
Groans: 58
bump
 Old 10-26-2009, 09:35 AM   #10
YammerR1's Avatar
Posts: 109   (View Stats)
YammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud of
I had a leaking fuel injector which caused the same symptom you're experiencing. Mine was way too rich at idle and would happen randomly. Fuel trims would go into the minus 20's. If you have a leaking injector (when the injector is supposed to be off) you might want to get it replaced asap as you'll f*k up your rings due to cylinder wash down.... speaking from experience.
The affected cyinlinder's spark plug will be completely carbon fouled so a quick check of the plugs will tell you which cylinder has the problem. Your dealership can diagnose a leaking fuel injector with their diagnostic system.
YammerR1 is offline   Reply With Quote
 Old 10-26-2009, 04:23 PM   #11
robspeed3's Avatar
Groans: 58
well at idle im sitting at 14.9 14.8
 Old 01-03-2012, 01:58 PM   #12
MS3inDC's Avatar
Posts: 3,070   (View Stats)
Groans: 29
my fail...
dead thread is dead
MS3inDC is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/anybody-know-where-solenoid-purge-valve-located-40076/
Mazdaspeed 6 Purge Solenoid Valave .doc MSWord Document Download This thread Refback 09-25-2011 09:25 PM
Nitrous Purge Kit Install socks MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 06-30-2009 03:40 PM
Need a tune for my speed located in st.louis jdmjerry MazdaSpeed 3/6 - ECU Computer Tuning 6 02-28-2009 03:59 PM
First OCC Purge..... superskaterxes MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 11-03-2008 07:54 PM
Page generated in 0.31321 seconds with 26 queries
