-   -   anybody using a HPS cai (http://www.mazdaspeedforums.org/forum/f10/anybody-using-hps-cai-30776/)
huffentuff09 06-23-2009 07:44 PM
I was looking @ CAi and Sri.. I came across the HPS cai for the 07-08 MS3 I am sure it will work on the 2009 correct. I can get a good price under $200 for the CAI .. my next choice is the CP-E cai or NANO just wondering if anyone on here has one... Saw a dyno result and it was impressive!!:woohoo:
glocK23 06-23-2009 07:50 PM
Nothing wrong with it, but I don't think it comes with an air straightener.
I TAKE IT BACK, IT'S A PIECE OF SHIT (THANKS SCATT).
If money is an issue, go Cobb SRI or CP-E Inlet, if not, get with Mark @ Streetunit and get the CP-E CAI.
Streetunit.com man, go. NOW.
Scatt Nasty 06-23-2009 07:53 PM
friend bought this, helped him install it.
the clamp for intake to inlet heated up and melted some ecu wires
dont buy shit for your car off ebay.
2008speed3 06-23-2009 08:24 PM
check out the CPe nano SRI
fit and finish great, price excellent
it takes about 20 minutes to install or to remove for a dealer visit if thats an issue
the best bang for your buck and less money than a cai
similar hp gains as a cai and no worries about the problem of hydrolock which sometimes happens to cai
give palerider a PM and he will hook you up.
huffentuff09 06-23-2009 09:02 PM
forum rules, I need to post somemore before I can PM anyone. Thanks for the input guys, that's why I am here!!!
2008speed3 06-23-2009 09:19 PM
also, don't forget to swap out your rear MM
stock one will eventually fail and cause problems
what year and how many miles on your MS3
glocK23 06-23-2009 09:40 PM
StreetUnit.com - Premier MAZDA/MAZDASPEED SPECIALISTS
mark will def take care of u
huffentuff09 06-24-2009 06:09 AM
Good feedback OTAY the HPS is off the list, I think I am down to the CP-e NANO sri and the CP-e X-cel cai and WTF is a MM .... Is that short for Mickey Mouse
I just figured it out (Motor Mount) how does that help in the drivability sector???
huffentuff09 06-24-2009 06:10 AM
whoo whoo 13 posts Hi my name is Dennis and I am a POST WHORE!!
2008speed3 06-24-2009 06:38 AM
the rear motor mount on this car will eventually fail
the mm is quick and easy to install and will improve drivability
huffentuff09 06-24-2009 06:47 PM
Back forth back forth in out in out , I am ready to burn one:phillyb: another newbie question about the MM , I was at the Street unit side saw a Streetunit Rear MM for $129 then I saw the Cp-e for $139 and in the discripstion it just said MM and not REAR MM what is the right one .. Are there different brands ??? Now, I was all set to get the NANO SRI now I am thinking about the added benifit of cooler air and looking at the CAI What the FUCK . Then I get this E-Mail back from the seller on FLEABAY ( I asked a Question) about the $169.00 HPS and he tells me , he doesn't have one for the 09MS3 Clear the air is the 09 and 08 exactally the same and use the same cai ??? HELP I've fallen and need more Power:Thinkingof_:
fbpem1 06-24-2009 07:34 PM
yeah the rear motor mount will break at and the trans mount will break both in under 1000 miles :)
unless you drive normally and without monsterous tires and 20 psi :P
2008speed3 06-24-2009 08:16 PM
i am currently using the CPe nano sri and a CPe 75 duro rear MM
i installed both at my 5k oil change
no issues yet with my car
i'm coming up on 10k and will be adding a bpv, inlet and maybe a test pipe
i'm only doing bolt on stuff because it easy to remove for a dealer visit
you have sufficient post to pm, so give palerider a shout
i have never bought anything from any forums before but this guy is straight up
Page generated in 0.17455 seconds with 11 queries
