-   -   Anyone Running an Air-Oil Separator (http://www.mazdaspeedforums.org/forum/f10/anyone-running-air-oil-separator-72698/)
metajew 02-17-2011 10:01 PM
Hi guys,
I just picked up a 2009 MS3 GT with under 12k miles. I've read around about the MZR and many other direct injection engines having issues with blow by, oil in the intake, and ultimately carbon buildup on the intake valves.
I started off thinking that I would just buy one of these oil catch can kits, but then I got to thinking about the maintenance and hassle involved in inspecting/draining it periodically, and how the climate will affect the fill rate. (More water condensation in the colder months, and the possibility of it freezing.)
Keeping this in mind, I then started checking around on the other forums and found Crawford's air-oil separator for the WRX/STi. This seems like a good compromise as it should separate oil from the air, hopefully allow moisture to recirculate through the intake, and recirculate the oil back to the crank case. Sounds great to me. Less oil consumption, no draining of the can required, etc.
The only "problem" is that to the best of my knowledge, no one makes an air-oil separator for our cars as a kit. Crawford sells a universal AOS, Ixiz sells their version of an AOS (except it looks like they don't have a clue how to spell, the website isn't especially professional looking, etc), and Grimmspeed claims that they're still in the development stage for one for our car. (For reference they do sell this for the Subaru engines.)
Is anyone here familiar with someone who has installed and documented their experience with an AOS on the MZR DISI 2.3? Thoughts? Product suggestions? Etc.
Edit: Just to compile more information, here's a thread from 2008 discussing the Ixiz AOS: New Alternatives to OCC's being adapted for MS3!
nyghtryder 02-18-2011 01:16 AM
i dont think anyone runs them on this platform. most run single or dual cc setups. matt damon makes a kit on here for a great price.
the biggest downside to a aos is that they dont hold much. i empty my can weekly in the winter or about every 300 miles.
SgtP 02-18-2011 01:58 AM
not much of a hassle turning a screw and letting it drain for a few minutes. I do it every few weeks or so.
FamiliaGT 02-18-2011 09:05 PM
I see no problems with a properly installed Oil Catch Can. Draining it doesnt have to be a hassle if mounted correctly. Theres a good number of options for them. Im currently testing a prototype that seems to be working great (Collected about 4 ounces in 300 miles, cold wet weather).
metajew 02-19-2011 03:17 PM
I already mentioned Matt Damon's kit in my original post.
As for your second comment, that doesn't make any sense. The AOS recirculates the oil it collects back to the crank case. It does not collect oil into a container to be drained later.
As for the ease of draining an OCC, that's not the point of discussion. I don't want that added maintenance, and I don't want to have to worry about my OCC freezing in the winter. The point of discussion is if there's any documentation on running an AOS on the MZR 2.3 DISI.
senor blanco ms3 02-19-2011 03:21 PM
speedie6 has the crawford one on his ms6
bombdotcom 02-19-2011 06:49 PM
isnt grimmspeed developing one of these for us? searcht the forums im almost sure it was brought up at some point.
BigjohnB20 02-19-2011 07:23 PM
I think you are right. Cobb put one on when they were building up his car, said it was common with subies they do. I am actually curious how this is working for him. I hope he chimes in.
metajew 02-19-2011 07:41 PM
Yes. There was a thread on this forum posted back in July 2010 where a Grimmspeed rep mentioned they were developing these.
In my OP I mentioned this. I also shot Grimmspeed an email to check on their progress/availability. Here's what they told me:
Originally Posted by Sales @ GrimmSpeed to me, Feb 16, 2011
Hey,
We are still working out the kinks on this one but I assure you the minute we are ready to release we will let everybody know haha! Thanks for the interest man! BTW I would say roughly a couple months yet, however we will update everyone when we know more!
Will
I'd like to hear his results, and how he installed it. Hopefully, he'll see this thread.
bombdotcom 02-19-2011 07:54 PM
ok for sure. sorry didnt see that
metajew 02-20-2011 03:40 PM
Could someone shoot Speedie6 a PM and ask him to check out this thread? I don't have a high enough post count to send PMs. :(
06Speed6 02-20-2011 09:19 PM
The crawford is a good unit. Mann-hummel makes the provent which I think is a better one.
I was the one who trashed the idea of a grimmspeed seperator on this engine because our oil fill cap is in a direct line with the timing chain and there is no way it is going to gravity drain with oil shooting straight into it. On the subby engine, the cap is not in a direct line with anything that throws oil around.
metajew 02-20-2011 10:50 PM
Interesting, I wonder if Grimmspeed has considered this for whatever they're developing for the MZR.
Have you seen any documentation specific to installing the Crawford AOS on our engine? I'm curious where the oil return line is routed to, if they delete the PCV, etc.
Tomas 02-20-2011 10:56 PM
wrong.
Most do collect the oil and have drain valves. Even the cheap ones used for air compressors.
An AOS has a fine brass mesh filter that traps the oil particles in the air circulating through it. When the particles on the screen accumulate and get big enough they form into droplets which fall down into the container. An AOS isn't a lot different than an OCC as long as the OCC has a baffle. An OCC without a baffle is pretty useless.
metajew 02-20-2011 11:24 PM
Originally Posted by Tomas (Post 738648)
wrong.
Uhuh. An AOS with a drain valve is an OCC. Of course it has baffles or mesh-- otherwise how do you intend to separate the atomized oil from the air flow? The difference being that one condenses and returns the oil to the crank case, and the other condenses and collects oil, water vapor, etc. which must be periodically drained.
Now, it has been noted in several threads, mostly on Subaru forums, that the AOS still may have freezing issues depending on climate. Crawford's most recent AOS has an additional inlet/outlet that they run engine coolant through to heat up the ambient temperature in the canister. People have suggested that this might also help water and fuel vapor to be returned to the intake, but I can't verify those claims. If that were the case, our cars might run even richer. ;) While interesting, I'm not sure if the idea of adding additional coolant lines to my engine bay is really desirable. This sounds like another place for something to fail/introduce air leaks/or spew coolant over the engine bay. And the idea here is to attempt to improve reliability/reduce longterm maintenance while minimizing additional complexity.
Crawford answers the 10 most common questions about Air-Oil Separators: (Note that one or two of these questions are Impreza specific)
Top 10 Questions about Air Oil Separators
10. How does it fit the '02 with cruise control in the way? - On the 02 or most of the cars which don’t have the throttle by wire, the top mount AOS lives in the same location as the cruse control unit. Our current TMIC AOS for the 04 to 07 will fit on the 02 but you will need to remove the cruse control unit. This is not ideal for some owners but currently that is the answer.
9. Are there any negative effects of not running the PCV?- Here is a good read on a generic PCV system, they have a decent explanation about question #9. Positive Crankcase Ventilation (PCV) Running the top line from the AOS to the vacuum source within the intake has the same effect on evacuating the blow as the PCV.
8. What is the effect of the Air/Oil Separator on ignition timing? – Our AOS has no immediate effect on ignition timing unless your motor is detonating from the blow by oil passing through the intake system. Once the AOS is installed and the blow by oil is no longer passing through the intake, your ECU will automatically advance the ignition timing because of the cleaner / more controlled burn in the combustion chamber. That said, the ECU will only advance the ignition to the parameters within the settings of the MAP.
7. Is the Air/Oil Separator suitable for a stock/daily driver?- Yes... You can pull the intercooler off your new car with only 500 miles on it and find oil inside of it. The purpose of the AOS is to remove this oil from the intake system to lessen the possibility of detonation which is the main cause of broken ring lands on the stock pistons. As you increase your HP, the amount of blow by passing through your breather system increases as well. This scenario also increases the need for our AOS.
6. Why go with a Crawford Air/Oil Separator, rather than a catch can? - With our AOS your oil will stay in the crankcase instead of outside the motor in a catch can. This will avoid the unpleasant surprise of finding out you do not have enough oil in your motor to properly supply the bearings. Because our motors are horizontally opposed, they are susceptible to pushing oil out the valve covers unlike an inline or V shaped motor. Our AOS pulls a vacuum on the crankcase creating a more efficient motor which equals more power from the same setup. A catch can cannot do this. Our customers say their motors run smoother after removing their catch can and installing our AOS.
A catch can needs to be emptied of its hazardous waste on a regular basis. Our AOS needs ZERO maintenance. A catch can emits the unpleasant smell of the crankcase fumes. Our AOS doesn't smell and is emissions friendly. Most catch can systems end up leaking or spewing oil in/on your engine bay while our AOS keeps everything clean and tidy.
5. Why is the Crawford Air/Oil Separator better than others on the market? - This is a tough question because it requires us to possibly shed negative light on our competitor's product, which is not a way we prefer to do business. Instead the answer will show how strongly we believe in our product.
Crawfords AOS was not originally designed for resale, but rather to take care of an issue we had with our race car on the race track. The final version of the original AOS was well over a year old before we started to sell the units to the general public. That decision was spurred on by our daily drivers which were getting oil in the intercoolers causing detonation. Crawfords is the only AOS with a money back guarantee, which shows how strongly we believe in this product. Crawfords AOS has the largest internal volume so it will separate more oil than any of the others on the market. Crawfords AOS also has the highest resale value which can be seen with a simple search on the boards.
4.How do you keep the Air/Oil Separator from freezing in cold climates? This is a great question and is currently relevant. Being located in Sunny Southern California, we did not know this would be an issue for some of our customers…Now we know. We have just finished our first test unit that will be heading to the frozen north for testing. It incorporates a water line from the engine to keep it at the same temperature as the engine. This should do the job and we will keep you posted on its progress. We have a production run of these AOS units currently in the system which should be ready for shipping in approximately two weeks.
3. What causes the yellow gunk? This is a mixture of oil and water. Usually when the water in the engine heats up it vaporizes and makes its way out the breather system. If it stays in vapor form it will make its way out the top of the AOS and into the intake. We have found from our cold weather customers that condensation is occurring inside our AOS as it is colder than the engine. This condensation is mixing with the oil in the AOS causing the yellow gunk. To fix this issue we have made a cold weather version that incorporates a heater inside the AOS to keep the AOS at the same temperature as the engine. With them being the same temperature, condensation will not occur leaving the water vapor to flow out the top of the AOS and into the intake system.
2. Why is it so expensive? Crawfords AOS kit costs more than most because it's a complete bolt on kit with all the engineering and testing out of the way. Also:
* It has a money-back guarantee
* It has the best resale value
* Proudly made in America by Crawford
* Largest internal "separating" volume on the market
* Re-circulates the precious oil back into the crankcase so the motor will not seize from a lack of oil.
* Pulls a vacuum on the crankcase creating better ring seal / power
* Avoids detonation which leads to broken ring lands.
* Now functions in sub zero weather
* Aesthetically pleasing
* Zero maintenance
1.What is inside the Air/Oil Separator? If you were to cut open a Crawford AOS, you would find that there are two different chambers within the AOS with the first chamber being a swirl pot. The function of a swirl pot is to swirl the incoming oil and air mixture. Due to centrifugal force against the inside wall, it removes the air from the oil so the air can be extracted through the top of the AOS. And due to gravity, the remaining oil will run down the walls of the swirl pot and collect in the bottom of the AOS. At this point the separated oil sitting in the bottom of the AOS is returned to the engine via a baffled chamber in the center of the block.
As the separated air moves up inside the AOS, it must enter a second chamber within the swirl pot before it can vent out the top of the AOS. The function of the secondary chamber is to remove any residual oil that might have made its way up the swirl pot. The secondary chamber also has a drain in the bottom to return the separated oil back to the engine. Unlike the other units on the market, the Crawford air oil separator has a hefty internal volume of .75 liters used to separate the air from the oil. This large internal volume is a must for separating the air from the oil coming out of the crankcase breathers on our horizontally opposed turbocharged engines.
Also found inside Crawford’s version 2 AOS is an internal heater. This heater equalizes the temperature inside the AOS and the engine to avoid condensation occurring within our AOS. This up grade makes sure the vaporized water leaving the motor makes its way through the AOS in vapor form instead of condensing back into a liquid inside the AOS. This is a must in cold weather and a bonus for any climate. No other AOS on the market employs this technology.
Crawford’s AOS is the largest “true” AOS as well as the only one with an internal heater on the market. This one unit has been designed to handle a stock to a fully built 750HP race motor.
Thanks for asking this group of questions!
Team Crawford
Air oil Separators 101:
Air Oil Separators 101
Air oil separators 101
Ming recently asked me to write an article for him concerning the benefits of an air oil separator system, since the general public still doesn’t have a sufficient understanding behind what the technology offers.
Part 1: How do our OEM setups handle blow-by vapor?
First off, let me explain what blow-by vapor is. Blow-by vapor is a thin stream of oil particulate that is generated in our motors under high amounts of pressure, such as when you are at WOT. This oil vapor seeps past the piston rings, and makes it's way into the crank case. The means by which our motors handle this blow-by, is by redirecting that vapor into our intake tracts, and ultimately into our motors.
The drawbacks of having blow-by vapor re-circulate back into your intake tract are two-fold. You end up with a lower effective octane, and oil consumption is increased.
The loss of octane results, because the oil is diluting the air/fuel mixture into a substantially less combustible fuel. What does this mean for the end user? This means that you are not able to combust your fuel as efficiently as before, and will result in a loss of power, and detonation/knock will be more prone to occur.
The second major issue that occurs in a re-circulation system is excessive oil consumption. All of that oil vapor that is being redirected into your intake tract, is forever lost from your motor. This means that as time progresses, more and more oil is being removed from your system. On track events, it isn’t uncommon for cars to go through a quart of oil at times.
Part 2: How does an oil/air separator work?
An air/oil separator is actually a very simple, yet extremely effective concept. Our motors have a crankcase vent on each valve cover. These two crankcase vents are connected to each other via a T (that long black pipe that you see on the front of your top mount intercooler if you have one), and are then connected directly into your factory turbo inlet. Under vacuum, the blow-by vapor is pulled out of the crank case vents, and is redirected back into your motor via the turbo inlet.
The air oil separator solves this oil consumption issue by taking those crank case vents, and separating the oil vapor from the air. The cleaned air is then injected back into the motor via a vacuum source, and the oil vapor is drained back into your crank case.
Part 3: Why can’t I just buy a catch can, doesn’t it do the same thing?
A catch can is another common item that addresses the same issue, or at least attempts to. The problem with a catch can though, is that while it does improve your octane by removing oil vapors from your intake tract, it does NOT address the overall issue of excessive oil consumption. The oil that is removed from your intake tract is stuck in your catch can, and never gets redirected into your crank case. This means that as time progresses, or under heavy track runs, you are still REMOVING oil from your motor. An air oil separator eliminates this issue by re-circulating that oil BACK into your motor where it belongs.
jax ms3gt 02-20-2011 11:55 PM
I brought this up originally awhile ago and contacted Grimmspeed. I also followed up on it earlier this year and they said they only have one engineer and haven't forgotten about us..
It has went no where since then and I ended up just getting a catch can...
let me find my thread...
here it is
http://www.mazdaspeedforums.org/foru...parator-62368/
06Speed6 02-21-2011 12:57 PM
Yeah I told the Grimmspeed guys about it.
I dont know that there is any documentation for installing it on our cars.
Brian MP5T 02-21-2011 01:50 PM
I don't mind a catch can collecting the oil rather than trying to put it back in the engine..
I check the oil once a week and drain the tank once a month..
metajew 02-21-2011 09:35 PM
I understand the logic behind it, but unless you have one of the more expensive OCCs like the E90 BMW and VW guys run, checking the level isn't an option with Matt Damon's OCC kit. And, I don't trust the Chinese knockoff catch cans on Ebay.
Next draining it once a month, while not incredibly inconvenient, what happens if it's been especially humid/cold or you forget to do it? Have you noticed fill rates varying with climate? Have you experienced any problems after installing it?
What catch can are you running, what installation procedure did you use (two OEM pcvs? pcv + check valve from Matt, etc.), what area of the country do you live in, and do you have any freezing issues? Along the lines of how did you install it-- how have you set it up to drain the can?
I'm just trying to address some of the concerns that come up when you install an OCC.
I sent Crawford an email asking if they had any solutions/products for our cars:
Originally Posted by Crawford Performance
Hi,
We would be interested in setting up an AO sep for you. We have a local
customer here that we should be able to develop an AO sep for and once that
is complete you can then order one. My thought would be, it would take about
1-2 months to have one complete.
If you have any further questions, please ask.
Cheers,
William T Knose Jr
VP Product Management
phone: 760-631-2927
fax: 760-631-2937
web parts: Crawford Performance - Subaru, Scion, Hyundai Performance
web apparel: I - S p e e d - Motorsports Apparel
I wasn't asking for a custom solution for myself in particular, and I responded as such, but this could show some promise for other options for our cars.
Long story short, the added maintenance of the OCC really turns me off, and I like the idea of a closed loop system with respect to ease of use, retaining oil, etc. For the people that argue "I wouldn't want that recirculating through my system." I'm fairly certain that the amount of fuel blowby that you catch in the OCC is only going to be a small portion of the fuel still diluted in your oil. Moisture content is always going to be there, etc. If you're changing your oil regularly. Say, every 3000 miles and just using the car as a DD, I suspect the AOS is superior.
However, if you're running a heavily modified car, racing, and so on-- the OCC might be the way to go.
silvapain 02-21-2011 09:44 PM
I drilled the bottom of my OCC and tapped it for 3/8" NPT, then put a small nipple on it and a ball valve. I drilled a hole in my undertray so that the nipple and valve stick through so I can just open the valve without removeing the undertray or even jacking up the car.
I usually just open it up and dump it in a store parking lot somewhere about once a week.
I'm running two PCV's, and the can is located under the driver's side headlight, right by the stock horn.
FWIW, the junk that dumps out of my OCC smells strongly of fuel, and seems to have a lot of fuel/water in it. I certainly wouldn't want it going back into my oilpan.
metajew 02-21-2011 10:30 PM
I hope you mean you drain it into a container which you dispose of at a hazardous waste facility. If you mean that you drain it onto the pavement, that is reprehensible behavior.
tddvrrn 02-21-2011 10:49 PM
werd.
and that is a great screen name.
+1 for less maint. i like your way of thinking. make it better and easier instead of just faster. holistic modding has arrived.
silvapain 02-21-2011 11:16 PM
Of course that's what I mean.
Brian MP5T 02-22-2011 06:08 AM
Well in my case I have an FS Engine in a Protege 5 so it will be set up a bit diferent but the need and reason is very much the same.
In its stock form the Stock PCV is fine, however adding any type of boost to it, seems to make it misbehave. Some people install a Mazda Millenia S PCV (Drop In Part) because it was designed to run in Boost. I did not buy an E-Bay can, It is a simple Aluminum can with Two AN6 Inlets near the top, a drain and a Filter. None of it get pumped into the intake. The intake has been Drilled, Tapped and a threaded set screw is in the hole with White Thread Lock.
Because my car was built to run 400+ Daily HP, I figured that it would be hard to find a reliable check valve that would work. I didn't want the valve closing for long periods of time every time the car went into boost and preventing the air from escaping, just to have some minor scavenging.
The way I saw it, I would rather have the engine able to regulate the pressure all the time, rather than only when off boost. On Boost would mean closing the PCV valve to prevent the boost from inflating the Engine...
metajew 02-23-2011 10:19 PM
While not irrelevant to the discussion entirely, I'm mostly interested in hearing results of these sorts of things on DI engines since ultimately the point is to limit carbon buildup on the intake valves. (And, of course, to reduce blowby and oil buildup in the intake/intercooler/etc.) But running 400 HP to the front wheels is fairly uncommon, so thanks for the details!
In other news. I got another reply from Crawford regarding them looking into an AOS install for the MS3. Not too many details, but there might be more options for our cars in a few months.
Originally Posted by William T Knose Jr
Hi,
We will start looking into it immediately.
Cheers,
William T Knose Jr
phone: 760-631-2927
fax: 760-631-2937
silvapain 02-24-2011 12:01 AM
You eliminate Carbon buildup by disabling the EGR system, not with a catch can.
metajew 02-24-2011 12:46 AM
My mistake. I'd still like to reduce the rate at which I'm coating my intake in oil. :]
oodavo 03-15-2011 04:22 PM
Does anyone vent the crankcase to the atmosphere? It seems like this would solve a lot of peoples concerns. Any negatives to this?
06Speed6 03-15-2011 04:39 PM
Your car smells like ass, but otherwise no.
dooderek 03-15-2011 04:54 PM
i do
yes if you are a hippie
pzr2874 03-15-2011 07:27 PM
^^ how do you have it vented? And what did u use??
NJSPEED3 03-15-2011 08:49 PM
If you do some searching of the forums you will find an answer to all of your questions. This topic has been covered extensively.
dooderek 03-16-2011 10:15 AM
i took the hose off and capped off the intake.
your other options are
1)keep the hose and d/c from intake
2)take hose off attach filter (not recommended)
3)run occ
Page generated in 0.22199 seconds with 11 queries
