 Old 08-25-2016, 01:16 PM   #1
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Default ARP's crank bolt?
Been digging around and I want to use an ARP crank bolt, trying to find the exact one for our motor, and the only thing I've found in old posts is part number: 251-2501 but they weren't 100% sure, has anyone bought one and know the correct part number for it?
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 08-25-2016, 01:58 PM   #2
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
I do not know the part number.
Why are you going with ARP over OEM?
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 08-25-2016, 04:09 PM   #3
HaXiR's Avatar
I just assume its better to go with a stronger bolt since its all apart anyways
Current:
 Old 08-31-2016, 02:06 AM   #4
wyeto's Avatar
Posts: 465   (View Stats)
wyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the world
I'm sure ARP would be fine but I dont think anyone has found any problems with the stock ones as long as you buy new and you know that will be the right one... If it aint broke why change it
wyeto is offline   Reply With Quote
 Old 08-31-2016, 05:13 AM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
How do you know ARP is stronger? Is that just an assumption because it's an aftermarket part, therefore must be "better"?
There's nothing wrong with an OEM bolt. In fact there's no reason not to go OEM
Blue Pu.
The Following 4 Users Say Thank You to anavrinIV For This Useful Post:
MD1032 (08-31-2016), MS3Shadow (08-31-2016), WetzMS3 (08-31-2016), xfeejayx (08-31-2016)
 Old 08-31-2016, 08:21 AM   #6
shamie's Avatar
Posts: 952   (View Stats)
I used ARP for most of my build but still used the OEM crank and cam bolts. I just assumed the friction washers and bolts were all designed to work together. If you were keying or pinning things then the friction washer concern goes out the window.
 Old 09-02-2016, 01:27 PM   #7
CorkSport Vincent's Avatar
Posts: 163   (View Stats)
CorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the world
I agree with the majority here. The ARP one is nice but not necessary.
I was given the option to edit this. Not sure if it worked or not.
CorkSport Vincent is offline   Reply With Quote
Crank Pulley Bolt Question Jeffercise CX-7 > Engine, Transmission & Driveline 9 08-14-2016 12:03 PM
Crank Bolt and washers rusharp MazdaSpeed 6 - Engine, Transmission & Driveline 7 02-02-2016 11:32 AM
Crank bolt talk .. jracer MazdaSpeed 3 - Engine, Transmission & Driveline 103 08-05-2014 09:11 PM
Stuck Crank Pulley Bolt Please Help Ethan591 MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-05-2013 12:43 AM
Page generated in 0.26660 seconds with 25 queries
