Notices
 Old 10-30-2012, 11:03 PM   #1
Jbluc4's Avatar
Posts: 77   (View Stats)
Jbluc4 has much to be proud ofJbluc4 has much to be proud ofJbluc4 has much to be proud ofJbluc4 has much to be proud ofJbluc4 has much to be proud ofJbluc4 has much to be proud ofJbluc4 has much to be proud ofJbluc4 has much to be proud ofJbluc4 has much to be proud ofJbluc4 has much to be proud of
Groaned at 6 Times in 6 Posts
Default Autotech internals ?
Sorry for making a new thread guys but ive searched and searched and I cant find a detailed set of instructions for this.. im so lost on the order, or which way the autotech internals have to go into the fuel pump and what stock, original, oem internals you have to re-use after you install the autotechs.. Pictures would be wonderful if anyone has them. I greatly appreciate any type of helpful tips/instructions anyone has to offer.
2012 BM Speed 3 (Non-Tech)
Jbluc4 is offline   Reply With Quote
The Following User Says NO Thank You to Jbluc4 For This Un-useful Post:
DONOTBUGME (10-30-2012)
 Old 10-30-2012, 11:11 PM   #2
SarcasticOne's Avatar
Posts: 415   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Check the How to section
Fuel Pump internals Install! <-- even found the thread for you!
GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP | Hyperflow TMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | SURE REM | Forge V2 BPV
Last edited by SarcasticOne; 10-30-2012 at 11:11 PM. Reason: MSF Database - Automerged Doublepost
SarcasticOne is online now   Reply With Quote
 Old 10-30-2012, 11:23 PM   #3
720-989-4238
PU Manchu's Avatar
Posts: 1,357   (View Stats)
PU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the worldPU Manchu is the leader of the world
Groans: 302
Groaned at 124 Times in 75 Posts
This is all the leftover stock parts from my autotech internals swap.
the two black "crescent" shaped pieces in your kit replace the silver disc on the end of the shaft and serve to secure the spring into place.
PU Manchu is offline   Reply With Quote
The Following User Says Thank You to PU Manchu For This Useful Post:
Jbluc4 (10-31-2012)
 Old 10-31-2012, 04:20 PM   #4
Jbluc4's Avatar
Thanks for that but it doesnt really show me what I need to know regarding the order the autotech's have to go in. I took them out of the box and layed them down piece by piece and forgot what order they came out of the box in.
Do you have a picture or anything of the way the autotech's go in the fuel pump? And thanks for that picture you already posted.
Last edited by Jbluc4; 10-31-2012 at 04:20 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-31-2012, 04:30 PM   #5
MZRSPEED's Avatar
Posts: 165   (View Stats)
MZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the world
I don't see how you can have a problem installing internals, this has to be one of the most over thought mods you can do. Stop over thinking it and just get it done, seriously.
'12 SPEED3 LSM--- / AUTOTECH HPFP / RACE PIPE / JBR SHIFTER BUSHINGS / SURE SHORTCUT /
14.195@101.47 (stock tune) Orlando Speedworld 3/27/13
MZRSPEED is offline   Reply With Quote
 Old 10-31-2012, 04:35 PM   #6
anavrinIV's Avatar
Posts: 2,084   (View Stats)
Groans: 35
Groaned at 25 Times in 14 Posts
take old internals out. put new ones in the way the old ones came out. put on spring and spring retainer, drop in clips. done.
2007 Black Mica MS3
Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping
Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers
Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM
Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion
anavrinIV is online now   Reply With Quote
Anyone want in on Autotech internals? OneBAMFpog 2010 MS3 - Fuel, Nitrous & Water Injection 545 09-30-2011 08:49 AM
Page generated in 0.29256 seconds with 24 queries
