bad clutch??? long story short i was at wot and had to come to a quick stop so i down shifted.after coming to a complete stop,my car started to idle at a higher rpm then normal,so when im about to engage the clutch the pedal starts to vibrate,when its fully engaged it stops. |
Clutch pedal vibration....ZZB? Lets not cut to conclusion, how bad are the vibes? And are they still present? |
Pretty confused how you can downshift at WOT, but a vibrating clutch pedal is a good indicator that you bent a rod. If you care about your car I would do a compression and piston height check before driving it anymore. |
I highly doubt is a bent rod it would of been audible. The vibration is only present when your engaging to the clutch. The pedal starts to vibrate which never happened before . I'm fully bolted even with a bigger turbo but never changed the clutch. I'm at 60 k. |
| All times are GMT -7. The time now is 07:20 AM. |
