Bat temp gauge? Besides using a obd port style gauge is there any other way of having a stand alone style gauge? And how would one hook it up? (the sensor) Sent from AT&T Inspire 4G using Tapatalk. |
Yup, It's just a thermistor and gauge. A couple companies make them. Google is your friend. |
BAT's are useful in a log, but there are much better gauges to buy.. |
Where do you hook them up at? I think I've seen IAT gauges but where would you stick the sensor? Sent from AT&T Inspire 4G using Tapatalk. |
Drill a hole and thread it into the IM.. |
I was kind of looking for a easier, less hole cutting irreversible way. Sent from AT&T Inspire 4G using Tapatalk. |
Probably get a leak if you do it wrong but use the silicone coupling before the TB, tap it n use a good fitting. If you want to reverse it just pick one up here for like $20. But why would you want to constantly monitor bats if I may ask? |
| All times are GMT -7. The time now is 07:20 AM. |
