 Old 07-12-2010, 01:20 PM   #41
Kydizzle's Avatar
Posts: 505   (View Stats)
Kydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the world
do a CS rp and dp on the stock exhaust and maybe get one of the resonators removed. should sound sweet thats what im going to do
2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs)
Kydizzle is offline   Reply With Quote
 Old 07-12-2010, 08:54 PM   #42
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
you're going to do? you already have it in your sig...
it's fun to do bad things
 Old 07-13-2010, 07:45 PM   #43
spdjnke's Avatar
Posts: 121   (View Stats)
spdjnke is a name known to allspdjnke is a name known to allspdjnke is a name known to allspdjnke is a name known to allspdjnke is a name known to allspdjnke is a name known to all
If you want a quiet exhaust with no Drone then I would say go with a DP then mate it to a racing beat CBE and your golden.
2008.5 Crystal White Pearl Mica MS3 GT
2010 Subaru Forester XT
Cobb Catback, Cobb Shift Weight, CP-E Nano w/Green Filter, CP-E Rmm 65 Duro, CP-E Tow Plate, Dash Hawk V2, ETS 3.25 TMIC Silver Black PC, Hypertech Max Energy Sport Reflash, HKS Type 0 Turbo Timer, TWM Short Shifter, TWM Shifter Bushings, TurboSmart Dual Port BOV, Denso iridium ITV22 1 step colder plugs, Mazdaspeed 6 Rims w/ Hankook V12's, JDM Visor Rain Guards, 35% front/20% rear tint, 22pc Clear Bra kit, Home Made Chin Spoiler,Debaged, Side Molding Shaved, 4500k Purple Fogs
spdjnke is offline   Reply With Quote
 Old 07-20-2010, 10:43 AM   #44
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
Originally Posted by ReD BoY View Post
and I am getting full turboback like my video with good* audio
including catback
I does not like stock exhaust... except that its a pretty good starting point
I understand where you seem to be coming from. I just hope you understand that you are going to be paying a LOT OF MONEY for sound. Those of who went with catless (or high flow catted) dp/rp combos into the stock CBE get the same performance gains as full turbo back exhausts. The stock CBE flows better than the K04 turbo's maximum exhaust flow. So the CBE changes only affect sound.
You will get a very nice performance bump by replacing the super-restrictive stock dp and the two cats, but get nothing in performance from all those big bucks you spend on replacing the CBE.
And I too, like Darth, have no smoking turbo issues from running a big catless dp/rp. I just turned 38,000 miles. No pill either. I do run Mobile 1 5w-30 full synthetic oil and change it every 3,500 miles. And I drive the piss out of this car. I mean HARD.
 Old 07-20-2010, 12:45 PM   #45
CloudX's Avatar
Posts: 154   (View Stats)
CloudX is a splendid one to beholdCloudX is a splendid one to beholdCloudX is a splendid one to beholdCloudX is a splendid one to beholdCloudX is a splendid one to beholdCloudX is a splendid one to beholdCloudX is a splendid one to behold
you can't go wrong with the corksport.. nice setup
2009 CWP Mazdaspeed 3 - Few Mods - Braced - HT Tune - TMIC soon
1998.5 Silver Frost Ford Contour SVT #5626 of 6535 - Few mods - Braced, weld-in SFCs
CloudX is offline   Reply With Quote
 Old 07-20-2010, 03:50 PM   #46
ReD BoY's Avatar
Posts: 523   (View Stats)
ReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the world
Groaned at 32 Times in 15 Posts
I know CBE doesnt do anything performance-wise but I knew I would get it eventually so getting them together was the way to go.
CorkSport TurboBack Exhaust Installed
I put it all on, check eet ouuuut
---Stupid kid can haz car.
ReD BoY is offline   Reply With Quote
 Old 07-20-2010, 06:22 PM   #47
Kydizzle's Avatar
well im going to just add the cs dp i already have done the others. just what i have now sounds good, but it could be louder so im hoping with dp the sound will be louder as well
 Old 07-20-2010, 09:03 PM   #48
ReD BoY's Avatar
it'll def make it louder... and dp is also like... 100x harder than putting the other two on. Well... getting the stock one off is the hard part
exhaust haskms3 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-05-2010 03:06 PM
Exhaust SoCalSpeed MazdaSpeed 3 - How-To's 2 11-03-2009 11:10 AM
Exhaust TheNewGuy MazdaSpeed 3/6 - Turbo Induction 8 09-03-2009 06:44 AM
custom exhaust from exhaust depot? ZoomByU MazdaSpeed 3 - Engine, Transmission & Driveline 0 08-30-2009 04:22 AM
Page generated in 0.28644 seconds with 25 queries
