Block comparability. Tried searching and came up with no actual answer. I have a 06 mazdaspeed6 which blew up, it's now built and I have extra parts which just need a block now. Would the ford focus 2.3l block be the same as my 2.3l block? Can it be used? Same bore? Same main bearings? What's different on it? I've seen those blocks and they look exactly the same. Also seen them push 500+ hp. Thanks ahead of time guys. |
your welcome |
No, the 2.3 Duratec & Zetec are not the same block. You are welcome. |
Whats a stage 3+? |
would this work? http://www.ebay.com/itm/03-04-05-06-...02bc20&vxp=mtr looks EXACTLY the same it the DOHC not SOHC |
You can't take a hint can you.....smh |
fine, thanks guys. |
that took a bit but I think he finally got it. |
YOUR FACE IS DUMB |
I still don't think he gets it. :dunce: |
Wrong section!:buttkick: |
| All times are GMT -7. The time now is 07:23 AM. |
