-   -   boom boom she goes (http://www.mazdaspeedforums.org/forum/f10/boom-boom-she-goes-16343/)
blackmica08 12-01-2008 01:55 PM
boom boom she goes
3 Attachment(s)
well what can i said my beloved pos mazdaspeed3 went boom boom boom, it happened saturday afternoon me and the wife getting out of massage envy which is 4 blocks from house we go through a stop sign nothing happens, next a four way stop, 1st gear all good as i engaged 2nd gear not even close to 3500 rpm we heard a big boom and i felt like something came off right off the bottom of the car, looked at the rear mirror a cloud of white smoke and the car shut off. called the tow guy and as the guy lifted the car oil pour into the street like water from a bottle. this morning i snapped these pics, the piston pin came loose and open four holes, one of them being the pvc, the oil pan and two through the block. the tech guy said that the clip that holds the piston pin slided out and cause this whole mess, he also told me that this has become a problem with the speed3s, that theres no way that clip can hold that piston pin. im the third car i see in the dealer with a blown engine due to either weak rods or piston pin problems. new engine has been ordered.
mlassek 12-01-2008 02:01 PM
they are giving you a warranty engine when you had a gt30 on the car?! or did you put everything mostly back to stock before the dealer got their hands on it?
silverspd3 12-01-2008 02:02 PM
under warranty?
gsrtype1 12-01-2008 02:02 PM
damm! sorry to hear man
MS6 Alan 12-01-2008 02:06 PM
ouch, sorry to hear man!
These motors are popping on an almost daily basis... *cringes*
Grim 12-01-2008 02:12 PM
WTF!!!!Fuck you mazda for putting such a shiity engine in this car.
y2kc0wb0y 12-01-2008 02:19 PM
Ward's Ten Best my ass.
gsrtype1 12-01-2008 02:19 PM
He was at low boost at low rpm isn't this the common lean condition? ecu to blame?
Lex 12-01-2008 02:23 PM
So the failures are turning out to be a manufacturing or design issue. Mazda should fix all these under warranty. I really hope they revised the failing part for later models - otherwise we can all pop.
Lex 12-01-2008 02:25 PM
No. This is not a load caused problem. This is a design or manufacturing issue.
gsrtype1 12-01-2008 02:29 PM
You mean cuase the mechanic told him that the pitston was the problem? how come other people have had reealy bad knock betwen 3-4k followed by boom?
Lex 12-01-2008 02:40 PM
The knock may be false or may be real - chances are it is false. The knock may or may not be related to the engine failures.
What I am getting at is that at such low load, there is VERY LITTLE the ECU can do wrong that will cause it to blow like that. In other words, it's almost impossible for the ECU to cause a condition that will result in this catastrophic failure at this engine load level.
Therefore, it is a mechanical design or manufacturing fault. The same can be said for all of those other low load failures we see. I think that blaming the ECU for these faults is barking up the wrong tree.
Lymerock 12-01-2008 02:53 PM
crap!
+1 to F U mazda!!!
im gonna go beat on my car some more and hopefully ill get the pistons hot enough to weld that pin into the rod
wtf
i guess this is another reason to get in on the upgraded rod/stock piston gb
but dang am I broke with xmas just around the corner
gsrtype1 12-01-2008 02:54 PM
You may be correct. I'm just saying ALOT of people with blown engines said they heard knock at 3500rpm getting on the freeway in top gear and then boom.
SharkDiver 12-01-2008 02:57 PM
Im glad they are fixing it but I dont think mazda will have any plans to do a recall and fix everyones pin problems since that cost would be crazy high for them.Ive never heard of so many motors blowing when they are not under any load,It makes me think these motors are somewhat crap..
blackmica08 12-01-2008 03:25 PM
i have a dashhawk and im always looking at my short and long fuel trims also im always in the lookout for knock readings, everything was good, no knock and both fuel trims were withing acceptables parameters, funny thing i was out of boost when it happened not even at 3500rpm. my wife took a shit when it happened , it made this loud cracking noise that i felt through the bottom of the car, when we both got out she goes , i told you not to sell your mustang.
mdogg 12-01-2008 03:27 PM
Definitely true about the proposed recall - it will never happen.... unless someone decides to get things analyzed properly, everything documented properly, and takes the time, effort and money involved in litigation... and even then it's only iffy at best.
while not under a true load, the ECU might have some calculated load value.... so it still, theoretically, could be an ECU thing. I don't have any hard evidence to support this, but I haven't seen much to rule it out either.
Lex 12-01-2008 03:29 PM
Did you take your car back to stock before bringing in to the dealer?
blackmica08 12-01-2008 03:49 PM
no
Laloosh 12-01-2008 04:07 PM
this is fucken bullshit...just when i begin to find some hope in this car i read another thread like this
boosted3 12-01-2008 04:14 PM
man i just got a stand back and plug and play and a fucking rpmc inlet hose now this happens.Wtf i duno if i wana own this car anymore.giving me 2 thoughts
smakdown61 12-01-2008 04:28 PM
Originally Posted by blackmica08 (Post 115429)
no
wow so you rode into the dealer with a gt30 running 18 psi? lol you got lucky my friend.
redrocketz 12-01-2008 04:28 PM
the same cylinder fails on regular 2.3 engines as well guys think it might be an oiling issue...
wisniaPl 12-01-2008 04:32 PM
Im feeling you man im thinking more and more about trade in
Laloosh 12-01-2008 04:32 PM
odd that its right by the balance shafts
gsrtype1 12-01-2008 04:35 PM
maybe its just inherently a prob with certain engines and if you make past a certain milage your ok? i'm at 47k hard miles and my engine doesn't use a drop of oil.
ptperformance 12-01-2008 04:36 PM
Freq could be playing a part in these motors going boom. Then again it could be a simple as the parts being junk. I would really like to see the head of the piston on this motor... like really bad.
ptperformance 12-01-2008 04:39 PM
Windage tray and good baffles should fix any oiling problems.
ptperformance 12-01-2008 04:40 PM
Sorry to hear that this happend. Keep us up to date on the repair and what the dealer has to say about it. If at all possible can you take a shot of the top of the piston that failed? And what cly was it (looks like #2 again)?
oskinosmee 12-01-2008 04:45 PM
Not cool damn it
LBV 12-01-2008 04:59 PM
A guy with an MS6 over on 24/7 popped his motor as well.
Grim 12-01-2008 05:04 PM
Im seeing a trend here.Maybe the BS is to blame.How many cars with the balance shaft delete have blown?zero.
smakdown61 12-01-2008 05:54 PM
I don't see why everyone is flipping a shit. Don't put on a bigger turbo without building motor. End of story. Too much pressure down low made by the gt30 will pop the pins out.
blackmica08 12-01-2008 06:11 PM
i think he said piston 1 or 2 but dont remember now, i will definately post a pic of it once the engine is down, i also have the piston pin that came loose with me but i left it at the dealer.
Lex 12-01-2008 06:17 PM
A wrist pin coming loose will score the cylinder wall - not cause a catastrophic failure. I have a hard time seeing the wrist pin coming loose made it go boom unless you had this happen for a while and there were other engine issues as a cause of it (burning oil etc).
I don't understand what too much pressure down low will pop the pins out is supposed to mean ...
blackmica08 12-01-2008 06:19 PM
thats exactly what im going to do put the car back to stock, sell every aftermarket part on it and use that money for a down payment for another car, theres no potential for this car, i had it.
phailerider 12-01-2008 06:32 PM
am i correct in understanding he was running a gt3071 with a cobb ap tune? a stock turbo cobb ap tune?
lol...no surprise here if this was the case. actually its kinda cool it lasted a couple months.
Laloosh 12-01-2008 06:41 PM
if the car had the correct af ratios and wasnt knocking, running it with a bigger turbo shouldnt matter
Haltech 12-01-2008 06:46 PM
Common sense obviously doesn't apply in this situation.
phailerider 12-01-2008 06:47 PM
what leads you to believe that the a/f ratios were "correct"?
Laloosh 12-01-2008 06:49 PM
you figure some1 that is running a bigger turbo plus bolt on's knows what to look for...than again with some of the ms3 owners ive met...all bets are off
Haltech 12-01-2008 06:52 PM
isn't that a true, understatement! +1 Take for instance those who run high boost without adding higher octane fuel to boot. Yet, they look at you cockeyed when you tell them, they should be running alky injection. " That's $400 man! ". $400 is much cheaper then $8000.
ElBartoRex 12-01-2008 06:54 PM
exactly, I don't know why everyone is blaming the car...
...gospel.
phailerider 12-01-2008 07:01 PM
i think considering he ran an ap tune with his gt30..... well, maybe he can weigh in here. but im not thinking thats the slickest idea around here. if he was smart enough to monitor all of that i doubt he would have considered it in the first place considering the alternatives. it sounds like a guy who got flashed, decided to go big turbo and never pulled his tune off or considered an alternative.
plus...not to sound like im flaming him...but the dealer is warrantying this with an ecu flash and a gt3071 on the car? does his uncle own the dealership?
this whole thing sounds fishy. maybe the OP can shed some more light on the sit-you-ate-chun.
Haltech 12-01-2008 07:05 PM
Well, those raise interesting questions. For starters, the dealers can't authorize the warranty to work on a blown engine without someone from Mazda getting involved. We all know, you blow an engine and the red flag is raised. No one at Mazda is going to let an aftermarket big turbo car, fully bolted with a modified ECU program, get a warranty claim. So, how does one get warrantied without an inspector from Mazda NA themselves, coming out to look at the car? We have seen from previous threads like these, Mazda requests photographs, etc.
If i was going big turbo, you bet your ass im going with a custom tune. An off the shelf tune is far from sacred and you are playing with fire. Whos also to say, this car didnt suffer from the famous ATP boost creep syndrome?
smakdown61 12-01-2008 07:08 PM
Wait, so the OP was running a STOCK turbo OTS map on that turbo? Wow....
Haltech 12-01-2008 07:11 PM
Supposedly, looked like that info was left out of the initial post.
Laloosh 12-01-2008 07:17 PM
its kinda hard to go custom tune when that option is not yet available lol
PerlMazdaSpeed3 12-01-2008 07:22 PM
First of all sorry for what happened bro. Maybe once the engine is tore down and you can get some pics, we'll be able to get a better idea of the root cause.
I am still new to the MS3 world, about a month as an owner, but I've been lurking around for a bit. I still have hope for this car, as long as normal tuning logic is applied, then you would hope that the engine would treat you good. But then again, there is no true security once a faulty OEM mechanical failure happens. I have about 1220 miles on her right now and I just hope she is tough enough for once I start throwing parts at it. We'll see!!!
Thanks again for sharing and keep us posted.
phailerider 12-01-2008 07:24 PM
http://www.mazdaspeedforums.org/foru...0whp-club.html
a gt2871, followed by a gt3071, followed by cobb stockturbo ap tunes, boost cut defenders, full boltons....
this car has been tough as shit.... sorry to see it finally go.
JimmyMac 12-01-2008 07:43 PM
Sorry to hear about the pop. Clip on the piston coming loose huh? I remember I mentioned something about maybe the pins not getting enough oil (in another thread somewhere), which could cause the rod to bend/break. I have yet to take my engine apart. I have 2 1/2 weeks left for this semester in school. Then I should have free time to do some snooping around.
Brain storming here.... if the clip falls out of the piston and falls into the BS assembly... Is that possible? Was the clip found? Has anyone, who has blown a motor, inspected the BS assembly afterwards?
Anyways... lemme get back to my homework. I'll add this to the blown resource thread tomorrow.
SharkDiver 12-01-2008 08:04 PM
I didnt notice he was running a GT3071 with a AP ots tune..I feel a little better now about my car but I still wish this car came with forged internals.
lestat13 12-01-2008 08:13 PM
Subbing to see what dealer is replacing the motor under warranty...... Just in case I blow I will know where to take my almost full bolt-on car to. No offense, I can't see them giving you a new motor, but here's wishful thinking!!
ptperformance 12-01-2008 08:32 PM
Wow, guy pops his motor and gets flammed. Shit even pictures don't make people happy anymore.
I am only talking to a very few of you that seem to know better then he does, yet some of you are running turbos so low in there eff range that they are not even making the power of a modded stocker. I guess we all have our different ways of doing things.
Laloosh 12-01-2008 08:36 PM
yea but at least they are not failing like your pos modded stockers. You want to start with me? I will bury you in 2 weeks LOL
If the tunning was out to allow me to run more boost in the cold weather, i wouldnt have to run my 35 at 17 psi.
Im sick you saying im working on this working on that i have a solution fo rthis and that....and yet you make midpipes that are too short, turbos that fail and...oh wait thats about all you make outside of a mm that no1 runs
Haltech 12-01-2008 08:37 PM
It is available...
Laloosh 12-01-2008 08:39 PM
Where? Cause the ap sucked on my car and cpe doesnt have their flashes ready yet.
Lymerock 12-01-2008 08:54 PM
I feel for the OP, no matter what mods you run, popping an engine sucks big.
However, I am NOT going to let a blown engine spoil my fun. Tonight I ran around for well over two hours datalogging, racing anything I could find and beating the absolute shit out of my car, and it always cuts slightly at 5k rpm in 4th which isnt necessarily "safe"
anyway, I drive my car like I am trying to break things almost every day and it has yet to skip a beat.
if the time comes for me, it will come, but until then I am not going to be a pussy and put my car back to stock so I can buy another lemming tuner.
cant wait to put my flywheel in asap so I can beat the shit out of my car even more than I currently do.
again, OP, sorry it went down like that
and a quick question, what oil were you running? when was the last time you changed it? what oil filter do you run?
Lex 12-01-2008 09:03 PM
Once again, a wrist pin will not fall out unless the piston itself is out of the bore ... thats what bothers me about the diagnosis.
smakdown61 12-01-2008 09:08 PM
Have you not seen enough blown motor threads to be skepticle by now? We hear about blown engines, but 90% of the time never get the whole story about what happened, or we find out later they were doing something stupid....as what seem to be in this case. Blowing your motor running a cobb OTS tune NOT designed for your mods will yield no sympathy from me.
Haltech 12-01-2008 09:10 PM
Sucked on your car because you allowed it to suck. You gave it about as much time as i did this morning taking a shit.
Darksun280 12-01-2008 09:12 PM
People are going to make themselves feel like what's happening to the people with blown motors can't possibly apply to them. If I was to blow up tomm the same way as others I wouldn't stand a chance against the members on this site. Hell they'd probably even say I deserve to blow. Open your eyes people its not a tunning issue its a manufacturing flaw so people better start thinking out side the box for the answer to this puzzle cause we are ALL up for the chopping block on this one it seems.
mrlilguy157 12-01-2008 09:23 PM
sucks. i wouldn't point to the tune at all. not going to blow under no boost (regardless of turbo) + the AP.
anyone who says that is clueless.
No boost is no boost. gt35r, or gt12.
Haltech 12-01-2008 09:28 PM
Originally Posted by Darksun280 (Post 115628)
People are going to make themselves feel like what's happening to the people with blown motors can't possibly apply to them. If I was to blow up tomm the same way as others I wouldn't stand a chance against the memebers on this site. Hell they'd probably even say I deserve to blow. Open your eyes people its not a tunning issue its a manufacturing flaw so people better start thinking out side the box for the answer to this puzzle cause we are ALL up for the chopping block on this one it seems.
Well i would agree with you to a point, but... what people fail to remember is, this car is built to only withstand a certain amount of cylinder pressure, before your bottom end goes. People always want to point blame at the manufacturing side of this car. Do you think Mazda engineers said, " shit, we need to allow 50% on the table incase people decide to mod this car with bigger turbos. " No, they did not. They designed the car to operate within its advertised limits of horsepower. If you have the balls to buy big turbos, you better have the balls to accept full responsibility by not building your engine. Everything is a risk, which the same goes for having a bad tune. Ive seen 03 Cobras, which are fully built forged from the factory, blow because of a stupid aggressive tune, not enough fuel, and a big supercharger. Is that FORDS fault? At what point, do you feel its the owner who needs to accept responsibility here?
Ill give a person sympathy for blowing up their engine. What i will not give sympathy for, is doing something STUPID that caused your engine to blow. What pisses me off is everyone crying fowl Mazda fucked them by denying their warranty with a BT strapped to the car. It fucks everything up for all of us who have actual, warranty claims for stuff thats not even performance related, only because we have bolt on's on the car.
ptperformance 12-01-2008 09:28 PM
You must not have wipped much.
Haltech 12-01-2008 09:32 PM
I like dingleberries on mondays
ptperformance 12-01-2008 09:33 PM
Trust me I am but why is it not every single motor? Why does the AP help with it? Is it knock? Is it faulty parts? Can we nail this down to a date of MFG? Darksun has been asking for something to let go on his motor, still nothing. Yet guys with just an intake and exhaust have there motors pop? I have a very good idea what it is and its either coming from down below or up top from the DI. I also have my issues with the turbo manifold feeding into a non merge colector at the turbo, but I will keep quiet about that.
ptperformance 12-01-2008 09:34 PM
:eek:
gtlaw 12-01-2008 10:10 PM
that is a good point, but I have to figure most people don't feel like posting every last detail after thier shit blew up.
the OP said the setalership had 3 cases of this happenng I doubt all of them were big turbos
bova 12-01-2008 10:11 PM
so if its not available it sure is weird there are ms6 guys running custom AP tunes for a GT28 turbo :Thinkingof_:
MS6 Alan 12-02-2008 02:19 AM
ptp, why even make comments like that, it seems that's all we ever see from you now....its getting old.
"...i know what the fix is, i just cant discuss it..."
we are all here to figure this out and share experiences....if its all about the money for you, then just dont say anything and "fix" it for us......
Best of luck to the OP in getting back on the road.
ElBartoRex 12-02-2008 05:15 AM
This guy is just like 90% of the other blown MS3 engines, shady details and no responsibility accepted.
I call complete BS on the dealership honoring warranty on that motor, I will believe it when you scan the work order.
Laloosh 12-02-2008 05:19 AM
oh please, cut the custom ap bt tune SHIT.
I gave christian more then enough time to tune the car. The only way ill ever run a flash on my car is if i can do it myself, cause his tatits resulted in a 40whp loss and about ohhhh lets see 55 on a bt car that i know
smakdown61 12-02-2008 05:25 AM
Idiot. You did an EMAIL tune from christian using dashhawk logs. Look what tim bailey did with gt08's car.....300whp on a mustange dyno and ZERO knock. Try getting a REAL custom tune IN PERSON and stop whining all the time about your own damn retarded choices.
smakdown61 12-02-2008 05:28 AM
Thats not entirely true. Detonation during high boost will weaken parts in the bottom end making them fragile enough to break at low boost. Its called metal fatigue.
mdogg 12-02-2008 06:14 AM
Did Tim Bailey physically touch the ECU and program the ECU directly with 0s and 1s? No, he likely altered some values outside of the ECU onto a map canvas and then uploaded it to the ECU.
What does "in person" have to do with anything? It's tuning.... you don't have the physically see the engine - you only need to know what it's doing and how it's reacting. In fact, seeing the engine "in person" will show you absolutely nothing about the way the engine is running.
No offense, but mail-in flashes have been happening for years on other cars and they are widely accepted... I'm not saying that they are the best thing, but they are proven to work. Not to mention, that is pretty much how Christian has been doing the beta thing for a while now, right? Working on many cars, in many locations, and making changes via EMAIL.
If someone is tuning a BT car over the course of 6 weeks, I would think the tuner has had more than enough opportunity to make power (IF THE TUNING METHOD WORKS).
redrocketz 12-02-2008 06:41 AM
inherant design flaw like I've said before even regular 2.3'sare not getting sufficiant oiling to the number 2 cylinder and causing rod knock or worse think about it.
blackmica08 12-02-2008 06:43 AM
first of all i had my wastegate ported out to avoid ant boost creep, also i was running a custom veta map 93 oct set at 18psi, which it never saw more than 17 psi because i had set my turboxs boost controller at 17psi. like i said i was out of boost when it happened 2nd gear 3500rpm . when the car was put at the lift and the black plastic cover taken out there were pieces of the block and the piston pin resting on the cover, also the piston clip came off without breaking, the tech is a personal friend and he said that clip is not enough to hold that piston, he had done a couple of ms3 which had problem on cylinder 4 which mazda knows theres a problem with cylinder 4. i will get all of you doubters more pictures of the car with full bolts on at the dealer as it is.
Lymerock 12-02-2008 06:44 AM
Ive heard the story from you, and I heard christian's take as well. from what I understand you asked for certain things to be done a certain way. Im not going to claim the AP would have acted differently if you let him continue to work with you because that would be speculation, but on the other hand it is impossible to agree completely with your story since you did not give it a real chance. To the casual observer, it looks like you didnt want the AP to work.
regardless, burn enough bridges and nobody will want to work with you. I dont dislike you laloosh, not a bit, but I dont hesitate to call it like I see it, right or wrong.
blackmica08 12-02-2008 06:48 AM
if you take your time to read what i posted before you will see that i was closely monitoring my afr, kn reading and fuel trims and all of them were fine, i aint no noob with heavily moddified cars , 2 s/c gt, a nitrous srt8 and a head and cams ls1, also i was closely working with fynetune which they have a great knowledge of imports.
Darksun280 12-02-2008 07:11 AM
He wasn't directing that at you it was a general statement. He's right too
smakdown61 12-02-2008 07:45 AM
Tim Bailey used a hex editor to tune. Thats all I know. Whether he was actually changing values in the ecu or doing the method you said I don't know.
Yes, mail in flashes have been done before and have worked...but they are obviously not working all that great on THIS car. The ms3 is a whole new ball game as far as tuning goes if you've been keeping up. And yes, Christian does OTS tunes via email but those are OTS tunes. They are designed to to work on multiple cars with different mods, etc...Even right now with 1.03 ots tunes there are still problems with stage 2 maps. Seriously use some logic before you type shit like that. Both Christian and Tim Bailey are amazing tuners, and Tim was able to tune 300whp stage 2 with ZERO KNOCKING in PERSON. I'm sure Christian could do the same. Have you ever been to a dyno tuning session? It helps a bit to be able to log more than 5 parameters which is what you are limited to with a dashhawk. Also, who the fuck knows what beta testers have been sending christian with all sorts of mods, driving conditions, temps, etc...
When accesstuner race comes out this month for free, the only "shit" tunes that people will be bitching about will be their own lol.
Bottom Line: If you think email tunes using a dashhawk can be anywhere close to a custom dyno tune with Tim or Christian, you need to sell your car now before you blow it up.
Darksun280 12-02-2008 08:15 AM
Wow what bubble are you living in? When the accesstuner race comes out basically thats cobb washing its hand of trying to produce off the shelf maps that are actually good and dropping the blame on the "Tuners".
301 dynos at 16psi 314 @18 psi with no knock? also no boost spike? And on a mustang dyno no less. If you do your ricer math that would put that guy over me and loosh's dyno numbers and I can bet there ain't a cobb tuned Ms3 running around on this plant thats gonna eat me up. I really wish one would materialize around the NY area and put me out of my misery cause I'm itching for a race. Plus the fact all these glorious dyno numbers are coming from the same dyno. MS3;s were doing a best of 280's whp with a custom tune on that mustang dyno in that shop now all in a sudden there doing 300-315. Seems shady to me. Sounds like someone got alittle too happy with the correction factors on that dyno to keep the customers happy. But hey some people are just happy with a dyno number and not proving its actually worth a damn. That 314whp car doesn't even have a fuel pump. I did 307 without a fuel pump and my car ran like TRASH on the street but could dyno a decent number. Lets wait to see when he ends up racing a car on the street and he gets chewed up.
bova 12-02-2008 08:21 AM
this is retarded. this guy engine blows and then the thread gets turned into a cp-e vs cobb battle. who fucking cares. if his engine blew and the dealer warrantied it even though he had a big turbo then more power to him. he has a loose piston ring and somehow the AP caused it. BULL SHIT! FLAME ON!
mdogg 12-02-2008 08:22 AM
I've been keeping up. Thanks.
so if he can tune for "multiple cars" via email by allowing room for inherent differences, why couldn't he tune aggressively (if that was his goal) for a SINGLE CAR, MOD COMBO, TEMP, ELEVATION, ETC. by email?
No offense, but I still haven't seen any compelling argument or logic from you. IN PERSON MEANS NOTHING.
Who cares about the OTS maps for a second - those are really just a more vague tune to allow for variations that will undoubtedly show up with their "stage" breakdowns. OTS allows (in theory) different people with the same or very similar mods to run the same tune. The theory is that they all will run nearly the same. Christian is tuning those via EMAIL. This means, by simple logic, that tuning is possible via EMAIL.
Now, yes I have been to an actual live dyno tuning session - many, thanks. The only difference, as you mention, is that with better equipment, you can track and trace more variables, inputs, outputs, sensors, etc. at the same time. This means that instead of 5 variables at a time with the DH - and taking around 4 or 5 datalogged pulls - you might get that down to 1 or 2 pulls on the dyno with better datalogging equipment. This is a time/efficiency thing - NOTHING MORE. It can take anywhere from 1-4 hours for dyno tuning, depending on the vehicle, mods, software, interface, tuner, etc. But, like I said, if a knowledgable tuner makes a commitment to tune a vehicle via email - using endless datalogs - there should be no appreciable difference in the results (assuming that the tuning equipment can do its job).
Assuming that they actually have control. Its amazing that JUST CPE'S FCF can outperform 6 weeks of COBB-DIRECT AP TUNING... I will leave it at that.
There's a lot you haven't caught onto yet..... if only you knew... I won't be buying a Cobb AP any time soon as it has been proven to be inconsistent (at best) on the stock turbo, and a complete drain of power for BT applications thus far. I plan on keeping my car for a while - and making it faster. Honestly, that is why I am sticking with CP-e - they are the ones figuring this out (rather than rushing to market with a crap product). I'll wait all day long for them to give me worthwhile mods.
smakdown61 12-02-2008 08:59 AM
Wow. Quit being a cock sucking fanboy and maybe you will see facts. We know what the AP can do with a custom tune in person. Tim Bailey has proved that. Show me a full control flash stage 2 dyno that makes 300whp and 330wtq. Show me a dyno of fcf that makes more power than stage 1+ 1.03 ots map. Oh wait you can't because there isn't any lol.
Email tuning is not Cobb direct tuning. For all of these beta testers, how do you know their car has the mods they say? How do you know there isn't a mechanical problem with their car? Boost leak? All of this can be verified in person with a custom tune. Don't make fucking excuses and be a little bitch about it.
Bottom Line that has been proven by FACT:
1. OTS tunes are good for some stages, not so good for others.
2. This car can be tuned with the AP by a good tuner to make good safe power (300whp stage 2).
Show me a cp-e tuned car stage 2 log that doesn't knock and has made 300whp on a mustang dyno.
smakdown61 12-02-2008 09:05 AM
Um last time I looked the surgeline tune made 285whp at 16 psi and 300whp at 18 psi. All dynos are different so its possibly your 307 whp on the surgeline dyno would be higher. Or your car/ecu is just trash thanks to mazda.
You should look up the ricer term you use and realize it is more related to you than anyone else. "Come race me, come race me" How bout GROW THE FUCK UP. Holy hell.
smakdown61 12-02-2008 09:06 AM
Its always the same person that starts the cobb bashing that causes threads to turn like this. Laloosh.
Darksun280 12-02-2008 09:08 AM
lol your a joke. an NO the most recent car was 301 @16 psi and 314 218 psi. Do you even read up on the bullshit your talking about or not knowing whats going on talking tuff on the internet is all you know?
Darksun280 12-02-2008 09:10 AM
smackdown is basically saying all the cars that have blown up are cause they weren't Custom tuned. Good goob smackdown way to come into an intelligent thread and make your self look stupid. I'd say exit stage left before you do anymore damage to what little reputation you have.
mdogg 12-02-2008 09:13 AM
must be nice to live in ignoranceville
Let's suppose, hypothetically, that a BT guy were working with Christian/Cobb on tuning. Do you think Christian was tuning directly for the one BT guy and allowing the customer to flash the latest tune? Now let's say, hypothetically of course, that after some extended period of time - more than a month let's say for shits and giggles - the Cobb flash was determined to be "as good as it gets". Hypothetically, the tuner might have adjusted boost, timing, fuel - and there were no other "mechanical issues" as you and Christian like to say.
What would your conclusion be if, hypothetically, the simple FCF (throttle only, mind you) outperformed this "full custom tune"? :loser:
Darksun280 12-02-2008 09:17 AM
LOL your sounding stupider and stupider by the minute so please continue.
Who's friends with this smackdown clown? They need to go over to smackdown house and unplug his Ethernet cable out the back of his computer and tell him to sit in a corner.
Laloosh 12-02-2008 09:21 AM
Hey dick I didn't turn this into a cobb flamewar. I acually said if the af and knock was in check then the tune had nothing to do with it. Also running a mbc on a cobb ap car is dumber then all hell. Ill post when I get back to the hotel room
bova 12-02-2008 09:41 AM
i agree with why would anyone run a mbc with the ap? that is just stupid.
Haltech 12-02-2008 09:45 AM
So let me get this straight... you guys are calling bullshit on 314 hp mustang dyno numbers and think, your cars are still faster? Theres more than one magical 300whp running around. Now you want to blame correction factors and everything else. If you want to talk that shit, come to CA. My AP tuned MS3 awaits you and i bet, you are going to have a very hard time, shaking me. I wonder how long you guys are going to sit around with your thumbs up your ass as more and more MS3 AP cars continue to go higher in hp?
I've seen some stupid fuckin posts on this board, but this one is straight up fuckin denial.
4DRHTRD 12-02-2008 09:53 AM
I have one thing to say, dyno #'s are for tuning, track is where it's at.
Since it's FWD the ET will suck ass on street tires but the MPH will be there. Start comparing that with altitude correction and you'll have a decent idea of your comparisons across the country and between tuners.
bova 12-02-2008 09:56 AM
seriously there have been all these dynos yet no one goes to the track
Darksun280 12-02-2008 09:56 AM
No Im saying if the car did put down those numbers they should stop trying to state that since its on a mustang dyno thats a low number. And answer me why all in a sudden the HP numbers have gone from 280's to 300+ for no apparent reason. Go have that guy who dyno'd 280 with that custom tune dyno again and I bet money his numbers are now in the 300's all in a sudden. And I'm not sitting around with my thumb up my ass I know what my car is capable in a race since I race it weekly digs and rolls. Wheres the vids of the APs doing so well? I think SLS is probably your 1 in a million champion even though his car cuts out and runs funny on the street. I'm going to run into a full bolt on AP car eventually and we'll where the AP tunes stand.
y2kc0wb0y 12-02-2008 09:58 AM
Currently sitting mid row..with Large Popcorn and super sized Coke.
Darksun280 12-02-2008 10:02 AM
LOL now SLS is groaning me like is his job. What a baby LOLOLOL
Page generated in 0.29093 seconds with 11 queries
