 Old 12-02-2008, 06:37 PM   #241
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
meth alone wont change that....it a combo of when to spray the meth and when to begin to add fuel. To many poeple tune with the standback late in the voltage range. This whole thing with piggybacks working only at wot throttle....i dont think that holds true when it comes to this car. I can change my idle timing and ltft by adding or subratcting fuel in the maf table/ignition tables.....and the shit holds for days
I have retarded timing at idle to the point of the car stalling and throwing fuel....tech that shouldnt be possible with a piggy back. Stock timing is 9-11 degrees at idle, ive ran 17 for over a week and nothing changed it back to 9-11.....
The Following 2 Users Say Thank You to Laloosh For This Useful Post:
bf360 (12-02-2008), Darksun280 (12-02-2008)
 Old 12-02-2008, 06:41 PM   #242
phailerider's Avatar
Posts: 4,639   (View Stats)
phailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the world
Groans: 49
Groaned at 179 Times in 125 Posts
Man my wallet is in intensive care right now but I gotta get that FT flash your right.....
Some one Sponsor me damn it!!! lol
what can you afford? pick a number.
phailerider is offline   Reply With Quote
 Old 12-02-2008, 06:42 PM   #243
ispypsi's Avatar
Posts: 303   (View Stats)
ispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the world
oh lawdy, and i thought nissan owners couldn't get along.
OP, sucks about the car. i'm not sure how the clip holding the wrist pin could get out if it was basically against the wall of the cylinder. seems as if it were an oiling problem, and there was some form of seizing going on at the rod/piston wrist, and as the piston broke, the pin happened to fall down and be at the bottom of the pan, intact. the piston would have to have broken for the pin to fall "inwards" toward the center of the cylinder without scrambling the sidewall of the cylinder (have you seen those yet? are they scored up badly?)
so when does the AEM EMS come out for the MS3? i want my 5 minutes back.
Dan - '08 MS3, some kinda silver
ispypsi is offline   Reply With Quote
 Old 12-02-2008, 06:45 PM   #244
Groans: 49
i agree. ive been getting a ton of fuel in partial spoolups right where we added it wot. makes the car gurgle/pop a little more than it used to during shifts out of those rpm ranges. you think thats related or not?
 Old 12-02-2008, 06:45 PM   #245
Laloosh's Avatar
Groans: 57
sounds like a deal to me
 Old 12-02-2008, 06:45 PM   #246
crazyitalian041's Avatar
Posts: 611   (View Stats)
crazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the world
crazyitalian041 is offline   Reply With Quote
 Old 12-02-2008, 06:47 PM   #247
Laloosh's Avatar
Groans: 57
absolutly it does....look at the cpe vta tune....high rpm LOW THROTTLE VOLTAGE, pull -81 percent of fuel. That means when your off the gas at a high rpm, almost all the fuel is pulled. If piggybacks didnt work in closed loop...their vta tunes would not work
The Following User Says Thank You to Laloosh For This Useful Post:
phailerider (12-02-2008)
 Old 12-02-2008, 06:52 PM   #248
Groans: 49
Originally Posted by crazyitalian041 View Post
are you getting help on your prices robbie? or sponsorship even? your car is gonna be the main beta car for most of the stuff i hope to eventually have. i hope theyre looking out for you.
 Old 12-02-2008, 06:53 PM   #249
TiZi's Avatar
Posts: 87   (View Stats)
TiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond repute
Meth FTW? lol
Agreed 100%. BTW after reading these forums for close to two years now, I can confidently say that this smackdown dude is the most fucked up shithead I have ever seen post. Pardon me, I meant confused gentelman.........Cheers all!!!
07 Speed3 - CP-E Meth Controller..CP-E FC&Cut Flash..CP-E FMIC..CP-E Downpipe..CP-E Standback v2 tuned @20psi..CP-E Fuel Pump..CP-E HKS BOV..Cooling Mist Meth Kit..CP-E Motor mount..RPMC Inlet..DNP Manifold..PG Reworked Turbo..HKS Dual Ignition..Injen CAI..Denso Plugs..Hotchkis Sway Bars..Cobb Springs..GT Spec brace set..Prosport guages..AEM Wideband..TWM Short Shifter..BSD..VCTS delete..Perrin OCC..and NOW DOWN & OUT
TiZi is offline   Reply With Quote
The Following 2 Users Say Thank You to TiZi For This Useful Post:
bf360 (12-02-2008), mdogg (12-03-2008)
The Following 2 Users Say NO Thank You to TiZi For This Un-useful Post:
 Old 12-02-2008, 06:59 PM   #250
Well Randy, to be honest I dont know shit about my car. I havent seen it since i gave the keys to them all those months ago.. I know I am probably getting a pretty good price on some of the parts but most I had already before hand. Sponsorship I have no idea, I think cp-e will sponsor me and p3 and street unit already does but thats nothing big to me. I dont know, guess we will see.
 Old 12-02-2008, 07:03 PM   #251
Groans: 49
lol... coming from tom this is the funniest post of 2008. btw... smakdowns ok... hes just ranting alittle here today. As we all are i suppose. Everybodys selling their damn ride and pulses are up.
 Old 12-02-2008, 07:06 PM   #252
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
For normal people this shit is too expensive. Between rent car note and insurance I don't know how people do this shit. If I moved back home this probably wouldn't be so bad. Cp-E's a good company to be sponsored by even cobb is cause they are producing a full range of products for the car.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 12-02-2008, 07:12 PM   #253
yep... im gonna be heh.
 Old 12-02-2008, 07:26 PM   #254
2nr
2nr's Avatar
Posts: 486   (View Stats)
2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world
I'll tell ya though, it has been great not having to worry about the motor popping anymore
2nr is offline   Reply With Quote
 Old 12-02-2008, 07:35 PM   #255
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
i dont even worry about my engine popping.I beat the piss out of my car everyday and no problems.Hell i even did a 5TH gear datalog for the hell of it lol.If it pops it pops.
Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW!
Grim is offline   Reply With Quote
The Following User Says Thank You to Grim For This Useful Post:
Lymerock (12-03-2008)
 Old 12-02-2008, 07:37 PM   #256
Groans: 49
whatd you get again? i cant keep track any more.
 Old 12-02-2008, 07:40 PM   #257
2nr
2nr's Avatar
well being as far as I was, popping the motor for driving under normal conditions isn't something that I was looking forward to.
 Old 12-02-2008, 07:41 PM   #258
He has an evox, look at his avy
The Following User Says Thank You to crazyitalian041 For This Useful Post:
 Old 12-02-2008, 07:41 PM   #259
2nr
2nr's Avatar
08 Evo X GSR... soon to have another full slew of cp-e parts on it
The Following User Says Thank You to 2nr For This Useful Post:
 Old 12-02-2008, 07:47 PM   #260
jtspells's Avatar
Posts: 634   (View Stats)
jtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the worldjtspells is the leader of the world
Jesus people what is the real issue anyway? Just relax drink a beer and chill out
jtspells is offline   Reply With Quote
 Old 12-02-2008, 07:53 PM   #261
Groans: 49
i just made a thread for all you guys. Post up there and let us have it!!
 Old 12-02-2008, 08:06 PM   #262
2nr
2nr's Avatar
already did
 Old 12-02-2008, 09:38 PM   #263
k0m
k0m's Avatar
Posts: 134   (View Stats)
k0m has a spectacular aura aboutk0m has a spectacular aura about
hmmm im just curious about something i dont have an ap nor am i running a mbc but, why would u not want to run these together? sorry if its a noob question
k0m is offline   Reply With Quote
 Old 12-02-2008, 10:13 PM   #264
bf360's Avatar
Posts: 2,069   (View Stats)
the op is a retard what did you expect running a bt with an ap and a mbc
and enough with the arguing and sooo many threads going to shit lol
 Old 12-02-2008, 10:13 PM   #265
bf360's Avatar
Gotta think more out side the box. I was only netting 1-3 hp per psi over 22psi. What ever hopefully we can race some time while I'm still on stock turbo cause god only knows how fucked up my car may be once i try to throw this 60-1on . My cars changing pretty quick though I have a real 3inch exhaust now as of sunday and a TXS fmic. I'm semi curious to go dyno again and try to take back my highest stock turbo dyno from Chris. 7 hp shouldn't be so hard to make up. Might even go for Tizi's SS turbo numbers. I did the math and the stock topmount was what was stoping my numbers from going up. It just can't flow the air I was trying to stuff through it.
let me kno if you wana dyno before you do bt il take a ride
 Old 12-02-2008, 10:30 PM   #266
ptperformance's Avatar
Posts: 4,123   (View Stats)
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
Dont blame loosh likes hes pot this kettle that.... these companys themselves are responsible for exactly what theyve ended up getting. loosh has simply stated/ tested what works and stated/ tested what hasnt. And hes done it for EVERYBODY. Since when is that supposed to be a bad thing. If anything it lends credibility to what he supports, and what he doesnt.
But wait, he has bashed me and my product (or lack there of) for many months now? I guess I am the exception to that comment you made. How can you support something you have never even seen little alone ran on your car? Nuff said.
ptperformance is offline   Reply With Quote
 Old 12-02-2008, 10:49 PM   #267
Groans: 49
hes desperately wanted to run "something" from you for months now. i think specifically engine mounts, maybe? he bashes the fact that to date there hasnt been anything. until you make something you ARE the exception. you fall into a different category of loosh bashing....lol "the lack thereof" IS what he is bashing. It wouldnt be a problem except for the promises broken.
that said... good luck with the mounts. im looking forward to kevins writeup and impressions and im still in the market for something of the sort myself. i wont hold it against you. if theyre as good as they sound id gladly fork the dough over and run the hell out of em.
 Old 12-03-2008, 01:00 AM   #268
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
As soon as i receive the mount, its going in with a write up to boot, fairly quickly. These stock mounts are shit and John came up with a clever way to address this problem.
 Old 12-03-2008, 06:18 AM   #269
blackmica08's Avatar
Posts: 60   (View Stats)
blackmica08 is just really niceblackmica08 is just really niceblackmica08 is just really niceblackmica08 is just really nice
hey turd face who told you i was running a mbc, dont drink and read.
[SIGPIC 2008 ms3 traded for a 2009 mazda6 gt
1994 mustang gt 331 stroker/ 478rwhp/537 tq on 125 shot
blackmica08 is offline   Reply With Quote
 Old 12-03-2008, 06:53 AM   #270
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
Originally Posted by blackmica08 View Post
first of all i had my wastegate ported out to avoid ant boost creep, also i was running a custom veta map 93 oct set at 18psi, which it never saw more than 17 psi because i had set my turboxs boost controller at 17psi. like i said i was out of boost when it happened 2nd gear 3500rpm . when the car was put at the lift and the black plastic cover taken out there were pieces of the block and the piston pin resting on the cover, also the piston clip came off without breaking, the tech is a personal friend and he said that clip is not enough to hold that piston, he had done a couple of ms3 which had problem on cylinder 4 which mazda knows theres a problem with cylinder 4. i will get all of you doubters more pictures of the car with full bolts on at the dealer as it is.
you said right here you are using a boost controller.
mdogg (12-03-2008)
 Old 12-03-2008, 07:07 AM   #271
i thought he meant a map clamp, whats wrong with using a boost controller to turn down the boost.
 Old 12-03-2008, 07:38 AM   #272
Groans: 49
lol... you need to retract the "dont drink and read turdface" comment above id say
 Old 12-03-2008, 07:39 AM   #273
Fux Wit It
Darksun280's Avatar
Groans: 175
I'm starting to get the feeling he doesn't know how this car works there for the popped motor is looking more and more like his fault.
The Following 3 Users Say Thank You to Darksun280 For This Useful Post:
mdogg (12-03-2008), phailerider (12-03-2008), spek1098 (12-03-2008)
 Old 12-03-2008, 08:39 AM   #274
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
the mazdaspeedgt08 AP car 314whp 338tq
I thought he did 305/325
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 12-03-2008, 08:43 AM   #275
Fux Wit It
Darksun280's Avatar
Groans: 175
he says he did 314 @ 18 psi but for safety reasons he got bumped down to the numbers you stated.
 Old 12-03-2008, 08:45 AM   #276
true that, hey can you explain to me whats the deal of using a mbc with the ap, cause darsun280 is ready to put the blame on me.
 Old 12-03-2008, 08:47 AM   #277
Fux Wit It
Darksun280's Avatar
Groans: 175
true that, hey can you explain to me whats the deal of using a mbc with the ap, cause datsun280 is ready to put the blame on me.
Hey I was trying to defend you but the more you type the more holes you punched in the boat. This is the exact reason peoples lawyers tell them to not say anything with out them present lol.
 Old 12-03-2008, 08:59 AM   #278
SLS MS3's Avatar
hey can you explain to me whats the deal of using a mbc with the ap.
That really is the kind of question you should ask before you blow your motor.
 Old 12-03-2008, 09:06 AM   #279
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
http://www.mazdaspeedforums.org/foru...e-11-26-a.html
He did 285 on 16 psi and 300 on 18 psi according to the dyno charts. It was bumped down to 16 psi until he installs a catch can. Did he state somewhere else in the thread the other numbers? I didn't feel like reading the other posts lol.
smakdown61 is offline   Reply With Quote
 Old 12-03-2008, 09:08 AM   #280
all i asked is whats the harm of using a mbc with the ap, will you clarify it for me if it doesnt bother you sir.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/boom-boom-she-goes-16343/
OMG!! 12s Si (All Motor) - Page 23 - 8th Generation Honda Civic Forum This thread Refback 03-26-2010 01:17 AM
OMG!! 12s Si (All Motor) - Page 21 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 06:39 PM
OMG!! 12s Si (All Motor) - Page 20 - 8th Generation Honda Civic Forum This thread Refback 03-25-2010 03:04 PM
Day of 12/2/2008: Top 50 of 255 Referring Pages This thread Refback 12-03-2008 09:24 AM
Upgraded CDFP boom? Demi MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 39 12-07-2008 09:10 AM
Will forged rods definitely keep the boom away? soul.survivor MazdaSpeed 3 - Engine, Transmission & Driveline 22 11-27-2008 12:46 PM
Small-car boom misses Chrysler Haltech Automotive News 0 07-13-2008 10:10 PM
Garmin Wired Headset w/ Boom Microphone $0.99 ($6.99 Shipping for 3) at PCMall Haltech Hot Deals Section 0 04-11-2008 11:00 AM
Plantronics Voyager 855 bluetooth stereo headset w/boom microphone $69 Haltech Hot Deals Section 0 04-07-2008 05:21 PM
Page generated in 0.59423 seconds with 37 queries
