Originally Posted by Ian
(Post 206838)
This worries me... Unfortunetly, this seems to be happening a lot lately. Hopefully somebody can figure this out. If my engine does blow, i am sure in hell NOT buying a 2010 because they look like shit... Did you notice anything odd about driving around before it happened? Shooooooot man sorry about it. |
We are working on it, I think we have a pretty good idea. Give us a week or 2 to figure it out.
Originally Posted by lidokrantz
(Post 206970)
guaranteed this cars damage was done prior to him popping. No way in hell it would pop from just cruising on the highway.
quote Phantom3 What exactly should Mazda be held accountable for?? There is no proof (as of yet) regarding a flaw in the engine. The car comes with a warranty under the premise that it will stay stock. If you are stock and you blow then it is covered. If you mod your car then it's your own damn fault. Why should Mazda pay for your fuck up? Mazda engineers don't sit around and design an engine with increasing the HP with aftermarket parts in mind. In fact it wouldn't surprise my if the engine was designed to pop on purpose... I"m just saying
You no i bet Mazda enigineers do no why some of these engines are popping and i bet it is not JUST from the BSD. and honestly Phantom theory is not so far out i bet the Mazda engineers took this car to the grenading point and probably have popped a few to see where the popping point is... and i bet its not to far off stock levels...Mazda clearly knows how much this engine/ecu can take before a failure happens,,,and indeed when a engine pops that has mods...Mazda is off the hook...and at this point they probably are happy when a cars has mods so they not held accountable..IMO it is a combination of all the mods putting the engine in stress because it was not designed to handle extra boost/power as well as the ECU not being able to compensate for the changes that the mods have created, especially when boost is increased..We no the car can handle a CAI and CBE as Mazda has them from the factory.....and i would bet a TBE may put this thing at its line for safe power upgrades...any more than that especially with boost over stock and it's only a matter of time..without meth...
Not trying to be negative about folks buying mods as many vendors make a living selling them, but this friggin platform can't handle more than a few light bolt-ons and stock boost. My recc is drive in balance, shift by 5500 tops, keep the boost at stock levels and do not over mod this thing...TILL it's built for more power first...otherwise stay close to stock levels. I am...and so far no issues.....I like my car and as much as this shit pisses me off i am keeping it and driving it a we bit more aggressive than normal....but not by much LOL |
Its not a matter of over boosting, or beating on the car. The problem lies eleswhere. We are looking for the problem now.
Originally Posted by Deadman
(Post 206972)
drive the hell out of it. Runs better that way. |
Yes it does, I think those that have beat on the car have had the best luck to date.
(Post 206978)
driving the hell out of it with too many mods is why this thing is popping...the damage is done when driving the hell out of it and it pops when you would never figure...it like Phantom right Phantom? |
Really, I cannot think of more then 2 motors that have popped under full boost and WOT. Most of the motors pop during cruise or right after getting off the freeway. Its a flaw.
Originally Posted by FORZDA 1
(Post 207054)
The definitive proof isn't in-hand yet, but the damage that causes these failures is most likely as someone mentioned earlier, a flaw... either in assembly, component manufacturing, or a control system(ECU) gremlin. My hypothesis is currently focused on the balance shaft/thrust clearance area until proven false with solid data.
Note to the OP, I'll pay shipping for your "blown" motor to get it in my hands for a teardown/analysis. If you're game, please PM me. |
I have checked 4 motors now, all have good near to stock thrust bearing clearance. I don't think that is the issue. I still think its a hydrolock issue or ECM gremlin that is causing the motors to blow. I have been checking these motors over very close, if you need any info please PM me or call us at the shop. I can dive into any of the questions you have on them.
Originally Posted by smakdown61
(Post 207067)
Since no one really knows whats causing the failures, it could have absolutely nothing to do with mods. We don't know yet until someone does a complete teardown. |
We have had the rare opritunity to check 2 motors now that have not gone boom. Both of them had bent rods and no visisible signs of detonation or pre-ignition. I still feel is a hydrolock condition in the motors.
Originally Posted by GQ_WhiteMS3
(Post 207104)
How do you know 99% of the cars popping are modded?
how do we know how many people blow this engine and AREN'T on the forums to tell us about it... and aren't modded. |
I would have to say 20% of the MS3 and 6 owners are on the site. Every time a blown motor shows up at any of the 3 local dealers, the parts managers call me. I head down, talk with the tech a bit and look around at what happened. They all appear to be bent rod problems, that appear to look hydrolocked.
Originally Posted by bf360
(Post 207163)
I still think were looking at a small percentage of cars that are blowing compared to the number that are modded, look at how many high hp/tq cars have stayed together with meth, i really think a lot of the blown motors are detonation caused. |
Yes a very small percentage, but if you look at other platforms... we have a very high amount of motor failures. Just like with the Neon clutch blowing up and cutting the trans in 1/2, we saw several that did this. Sure it was a very low % based on the number of cars that were out there, but none the less more so then any of platform out there.
Originally Posted by SharkDiver
(Post 207340)
Someone said mazda has a new part # for there thrust bearings so that may be part of our problem.. |
Yes they do, no, I don't think this is the cause of the blown motors.
Originally Posted by Funky
(Post 207363)
What's wrong is that everybody sits around these forums saying "I'm sorry to hear that" and others speculate on the reason... BUT NO ONE IS INVESTIGATING THE CAUSE CORRECTLY. Hell we should all pitch in and send a few of these blown engines to experts who can investigate and find out why this is happening.... It would be worth it, and I would not have any problem paying my share for it.
But no body does that. All everyone likes to do is GUESS... and that hasn't helped ONE BIT ever since the introduction of this car.
Every single case of incident (fatal, or just a minor one) in the aviation industry gets investigated to find the EXACT reason for why it happened, and most of the time they do find out the exact leading cause, or multiple causes of an accident. This can be a 30 second investigation, or a year long investigation, but the cause is almost always found.
This is a car people... not only that, its the engine in the car. I'm sure there is enough money in this community to investigate such a common problem with it.
Funky |
We are working on the problem now. If I could get people sending me there pistons, rods and numbering them in how they came out of the motor this would allow us to get a general status quo on what is happening. I would have to say that if motors are bending rods in the order of the intake valve opening events, that would lead me to belive that the motors are sucking something in from the intake manifold. The only thing that should be in there is air, other then that the PCV system could be filling them up with oil. This would cause the hydrolock in the proper squence (to match that of the intake opening events).
Originally Posted by Darksun280
(Post 207556)
If it was power or abuse related me and many others would be LONG ago blown up.
If it was tune related I would be blown up LONG time ago cause I've been on stock ECU this entire time.
boosted 30+ psi blew turbo and injector seals but still here
Boosted 27psi on the dyno 3 times still here
raced the car on 19-24 psi for over 9 months still here
Threw a 60-1 on the car cranked it up to 27 psi made no big power BUT still here.......
Trust me its not power or abuse related cause my motor would be the first one called home to mazda heaven if that was the case. That's why there's no sense fearing the thrown rod gremlins cause its all a gamble.
Enjoy your car mod it how you want to and drive it how you want to. When your time comes it will come. If you don't want it to come leave the car stock, stock the car out, or trade it in. |
Yep, you have the right idea. Now if we could just get your car to make some power...
Its a flaw somewhere and we are working with the intentions of finding what is going on. When we do, I will make sure to let everyone know what we found. Thanks.
