 Old 01-26-2009, 10:49 PM   #1
speed_3's Avatar
Posts: 345   (View Stats)
speed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant futurespeed_3 has a brilliant future
Default Boom this shit sucks
Last night I loaded up the new 103 map onto my car did about 60 miles 4 key cycles and did a few data logs. Car ran great no cut afr's in the 12s little .4 to .7 knock that i always see. I drove to school today did my work and on the way home I went to my favorite spot by my school to do a 3rd gear data log.
Heres what happened I'm in third waiting for my dashhawk to give me the go. It starts recording so I slowly start to accelerate all the sudden at 3900k or so I hear this really loud poof and then some bad noise. I immediately pull over and turn the car off, I thought I threw a rod. After looking under the hood and under the car no oil no holes. I try to start the car it starts, with a really horrible choppy idle with some noises that are hard to explain. Almost like theres something rattling around. I also got a 3rd cylinder misfire cel.
and this was with meth spraying out of my d03 nozzle. My controller was set to start at 12psi and full at about 17 18 psi.
If I blew a rod could it not have gone through the block, maybe my piston ring is fucked? I will most likely start pulling the motor. Thanks for any help.
Heres the data log sorry it's a little blurry it's the only way I could get it up here.
2007 silver ms3
speed_3 is offline   Reply With Quote
 Old 01-26-2009, 10:54 PM   #2
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
Im no good at reading these things but that fuel pressure is all over the place. What happened with the rpms too?! And that knock? Jesus thats a crazy log. I dont know if you should turn it back on but a video of the sound might help ID the problem.
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline   Reply With Quote
 Old 01-26-2009, 10:55 PM   #3
numbnuts22715's Avatar
Posts: 904   (View Stats)
numbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the world
Groaned at 9 Times in 6 Posts
Just pull off the head. I dunno how hard itis on disi vs regular engines, but it should be a lot easier to just pull off the head.
numbnuts22715 is offline   Reply With Quote
 Old 01-26-2009, 11:09 PM   #4
speed_3's Avatar
I'm going to pull the head tomorrow well see. The log was going for a while so I had to zoom in and it made it look like shit.
Ill try to take some video tomorrow and get it up here.
2007 silver ms3
 Old 01-26-2009, 11:13 PM   #5
Phantomspeeds's Avatar
Posts: 75   (View Stats)
Phantomspeeds is a jewel in the roughPhantomspeeds is a jewel in the roughPhantomspeeds is a jewel in the rough
Before you pull off the head, do a compression test might help you pin point the problem
Phantomspeeds is offline   Reply With Quote
 Old 01-26-2009, 11:18 PM   #6
phantom6294's Avatar
Posts: 255   (View Stats)
phantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the world
Not really... no offense to the OP, but the scaling on the fuel pressure just isn't great. Notice the lowest reading of the fuel pressure was 1650 PSI, the highest being around 1850 PSI. That seems fairly normal in my opinion...
The other PIDS are also poorly scaled. To the OP, try right clicking on the scales on either side of the graph and clicking "Zoom to Fit" -- it generally does a good job of scaling.
Also, is that the whole log? What bothers me is pretty much every other PID: The RPMS, at least in the graph, violently goes up and down, you get a knock retard of 6° at high boost, and your AFR goes pretty high.
Oh, not that the PID you're logging is bad, but if look under the Mazda PIDs, there should be a Actual AFR PID. I log this for AFR... maybe it doesn't matter.
If you need someone to host the image, PM me; I've got lots of web space. Or, if you need help with formatting your graph, let me know. I've spent more time in the DashHawk Data Logger View than I should probably admit.
phantom6294 is offline   Reply With Quote
The Following User Says Thank You to phantom6294 For This Useful Post:
Demi (01-27-2009)
 Old 01-27-2009, 07:30 AM   #7
Boonestafa's Avatar
Posts: 204   (View Stats)
Boonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the world
could it be a blown coil?
2008 True Red MS3 GT HKS ssqv black, JBR SRI, JBR TIP, CPE ToW PlatE.
JBR RMM, HPFP Internals, cobb AP in near future!
Boonestafa is offline   Reply With Quote
 Old 01-27-2009, 07:37 AM   #8
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
could you have blown a hose?
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline   Reply With Quote
 Old 01-27-2009, 07:47 AM   #9
dadasracecar's Avatar
Posts: 741   (View Stats)
dadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the world
Groaned at 70 Times in 44 Posts
Do a compression test. That's the first step. If you're going to pull the head, you might as well pull the motor. Pulling the motor takes about 3 hours and will make the tear down sooo much easier.
2008 BMW 335i 6MT black on black
www.p3performance.net
dadasracecar is offline   Reply With Quote
 Old 01-27-2009, 07:48 AM   #10
Superstretch18's Avatar
Posts: 318   (View Stats)
Superstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond repute
Huge KR right before your rpms started leveling off. Fuel pressures are fine; just the scaling is odd, so it looks funny. Interested in seeing if you had any damage (hopefully not!).
Old - 2007 CX-7 Sport FWD
New - 2010 WRX Hatch
Originally Posted by martyxattack View Post
who has the most care? me 0 care.
Superstretch18 is offline   Reply With Quote
 Old 01-27-2009, 07:59 AM   #11
Hmmm - maybe the timing chain came loose or skipped a tooth. Where is the noise coming from?
 Old 01-27-2009, 08:26 AM   #12
matt8679's Avatar
Posts: 58   (View Stats)
matt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of light
FRONT CRANKSHAFT BOLT SERVICE WARNING. Could it have something to do with this. Maybe your timing is off.
matt8679 is offline   Reply With Quote
 Old 01-27-2009, 08:30 AM   #13
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
it almost sounds like you blew a hose off and thats the reason for your choppy idle, i would check all your connections.
 Old 01-27-2009, 08:35 AM   #14
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
look at your rpm and boost your rpms go up and your boost falls down maybe you blew a hose?
 Old 01-27-2009, 08:44 AM   #15
andre0121's Avatar
Posts: 347   (View Stats)
andre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond repute
blew a hose is what it sounds to me
andre0121 is offline   Reply With Quote
 Old 01-27-2009, 08:51 AM   #16
bova's Avatar
Groans: 45
i've had a boost leak before that caused a misfire so i'm almost betting this is what happened. it is idling rough because of the leak so in boost you are losing the air and in vacuum you are pulling in unwanted air.
 Old 01-27-2009, 08:53 AM   #17
Problem is, to me, the boost scale is too blurred to read well, but it looks like he spikes to about 20 PSIg, and then drops off a little bit. The bottom of the boost scale is maybe 18.5 PSIg it looks like? Isn't that kind of spike pretty much normal for a stock/lightly modded car? Unfortunately, since the scaling is so off, we don't know what happens once it drops below 18.5 PSIg -- does it drop through the floor, does it taper off?
It's hard to analyze the log because the scaling is terrible and the resolution to far too low. Respectfully ask the OP to provide a better scaled graph and higher resolution screenshot.
 Old 01-27-2009, 08:58 AM   #18
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
that is a lot of knock retard
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline   Reply With Quote
 Old 01-27-2009, 09:36 AM   #19
dcs191919's Avatar
Posts: 73   (View Stats)
dcs191919 is a jewel in the roughdcs191919 is a jewel in the roughdcs191919 is a jewel in the rough
Check hoses, do compression check, pull oil pan..
dcs191919 is offline   Reply With Quote
 Old 01-27-2009, 09:38 AM   #20
speed_3's Avatar
Heres a better log rescaled. I checked all the hoses everywhere, on the out side the motor is fine I started it this morning and it started right up just ran real choppy and has that noise on the left side of the motor maybe timing related idk? Im taking to my shop now to pull the plugs and do a compression test i'll keep you guys updated.
2007 silver ms3
 Old 01-27-2009, 09:42 AM   #21
pressure test the entire system from the intake filter to the TB
if its ok do a compression test, if not fix the problem
if ok pull the pan and check your rods, if not pull the motor
 Old 01-27-2009, 09:45 AM   #22
the log looks normal minus the crazy knock. when u heard the crazy noise at 3k rpms did u just let off?
 Old 01-27-2009, 09:45 AM   #23
bova's Avatar
Groans: 45
you might have even put a hole in one of the couplers, i would inspect all hoses very carefully. when you say left side of motor do you mean driver side or passenger side cause it depends on which way you are looking at it.
maybe you did something to a sparkplug as well. never know.
 Old 01-27-2009, 09:49 AM   #24
speed_3's Avatar
passenger side of motor. I left off right away and at that time this noise came about and then I pulled over and turned it off. Im leaving for my shop now so ill let you guys know what I have found. Don't have much time I also have to go to class in a few hours. Thanks for all your help.
2007 silver ms3
 Old 01-27-2009, 09:58 AM   #25
johnnyspeed6's Avatar
Posts: 1,364   (View Stats)
johnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the world
Correct me here if Im wrong ..... of all the threads I have read about blown motors .... has ANY OF THEM not had any ECU tuning .... it seems to me there is a pattern here of motors blowing with the tunes on them .. just curious are there any blows without the tunes?
2008 HG Bullitt Mustang. Long Tube headers, SCT tuner,MGW short throw, FRPP hot rod cams high flow cats, charge motion plate delete
johnnyspeed6 is offline   Reply With Quote
 Old 01-27-2009, 10:00 AM   #26
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
i would check the turbo inlet, intake and the boost tubes. with meth flowing, you wouldnt even see KR for one. So, im going with the inlet or boost tubes.
 Old 01-27-2009, 12:06 PM   #27
speed_3's Avatar
I pulled my plugs and sure enough cylinder three the plug was saturated in oil. I took a drop light and looked into the cylinder and it was a reflection of my light so there is a good amount of oil in there.
2007 silver ms3
 Old 01-27-2009, 12:14 PM   #28
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
ouch that sucks
'08 CWP MS3 w/ T3 3071r
 Old 01-27-2009, 12:17 PM   #29
Eazy's Avatar
Posts: 1,539   (View Stats)
Eazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the world
Groaned at 32 Times in 14 Posts
This sounds similar to what happened to IDRVSLO..... I think he determined that he bent a rod causing the extra noise, then threw the rod out of the block a week or 2 later. Might want to go read that thread.
*edit*
here's the links:
http://www.mazdaspeedforums.org/foru...its-toast.html
http://www.mazdaspeedforums.org/foru...ame-noise.html
http://www.mazdaspeedforums.org/foru...she-blows.html
Eazy is offline   Reply With Quote
 Old 01-27-2009, 12:38 PM   #30
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
balance shaft still in there? how many miles?
Deadman is offline   Reply With Quote
 Old 01-27-2009, 12:41 PM   #31
speed_3's Avatar
Yea it looks like I have a bent rod explains the noise. I guess I'll pull the oil pan off and have a look then take it from there.
Meth was supposed to prevent this, looks like it just saved a hole in my block.
2007 silver ms3
 Old 01-27-2009, 12:46 PM   #32
speed_3's Avatar
I had 31500 and change, 1450 miles on oil change w/ Pennzoil platinum 10w 30.
2007 silver ms3
 Old 01-27-2009, 12:47 PM   #33
wisniaPl's Avatar
Posts: 933   (View Stats)
wisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond repute
wtf you bent a rod with meth.....that is fucked up now ther is a question who will be next :p for me its ap fault....
wisniaPl is offline   Reply With Quote
 Old 01-27-2009, 12:49 PM   #34
Eazy's Avatar
if anything it's NOT the ap, it's the tune.
 Old 01-27-2009, 12:51 PM   #35
Check timing components first.
The compression test will tell you if you dropped a valve - that would explain the oil.
 Old 01-27-2009, 12:54 PM   #36
gsrtype1's Avatar
Groans: 102
What? the ap is the tune..lol not sayen thats what cuase it..
 Old 01-27-2009, 12:55 PM   #37
bova's Avatar
Groans: 45
maybe it has something to do with where he loaded up the engine, according to the log it was down at 2k rpms.
 Old 01-27-2009, 12:58 PM   #38
speed_3's Avatar
If the seals were no good what what the compression test turn out? Vs The valve dropping.
2007 silver ms3
 Old 01-27-2009, 12:58 PM   #39
Eazy's Avatar
No, every AP has a tune on it.... the device isn't what's causing problems, it's the tune and the user.
 Old 01-27-2009, 01:00 PM   #40
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
if your meth was actually spraying, you wouldnt be seeing that crazy KR for one...
So, what is the turn on point for the methanol? What was the outside temps? Which map was it?
Upgraded CDFP boom? Demi MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 39 12-07-2008 09:10 AM
boom boom she goes blackmica08 MazdaSpeed 3 - Engine, Transmission & Driveline 287 12-03-2008 10:33 PM
Will forged rods definitely keep the boom away? soul.survivor MazdaSpeed 3 - Engine, Transmission & Driveline 22 11-27-2008 12:46 PM
Small-car boom misses Chrysler Haltech Automotive News 0 07-13-2008 10:10 PM
Page generated in 0.54901 seconds with 42 queries
