![]() | | #121 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 810
Groans: 60
| Not Ranked : 0 score
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks |
![]() | | #122 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score I havent really been paying attention to this thread, but I did look it over. Ide personally call a timing problem, it is definitely not a ring or ring land or crack piston from the description given. You guys also failed to mention that the timing gears are not keyed and the chain does not have to jump, it only has to work the bolt loose and spin the gear a bit. My DH is set to go off at 6 KR and it has never once gone off, 6 KR is not normal. The cool thing is that a bent valve is ALOT cheaper to fix than a bent rod. The bad part is that every exhaust or intake valve will have to be replaced along with the guides on cyl 3, thats about $200 in parts +$100 labor. Add in $350 for the tools to reset the timing, $160 for a gasket set, $400 in alcohol and profanity, and it comes out to $200 cheaper than a really really cheap long block. EDIT: on second thought, there should be no knock on an engine with a bent valve, when you bend a valve there is no noise at all... I would know =P Now the broken rocker that broke at the same time made noise, the valve made none when it hit the piston.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 02-04-2009 at 04:06 AM. Reason: Second thought |
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | Darksun280 (02-04-2009), speed_3 (02-04-2009) |
![]() | | #123 | ![]() |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score well we wont fully know till he has the car checked that kr spike don't mean to much to me in his log it was a single gear log that had a blip. not like it leveled off and held that way the whole time which means to me like Lex said that the blip was not the cause of the failure but a result of the failure.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
![]() | | #124 | ![]() |
| Banned ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
Groaned at 33 Times in 22 Posts
Maybe my comment of normal is the problem. How about we change it to 6 Deg of KR is common on the MS3 vice normal. On a side note: I lived in Corpus Christi for 6 years when I was in the Coast Guard. Love the place, miss the fishing, miss Waterburger and have very fond memories of Spring Break parties on the beach The only thing I wished Corpus had was trees over 6ft ![]() Oh and I forgot: The women. Corpus has some of the most beautiful women in any city I have ever seen. I swear there is something in the water there. OMG I miss that place even more now | |
![]() | | #125 | ![]() |
![]() Join Date: Sep 2008 Location: Long Island
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
(Thread Starter) | Not Ranked : 0 score Thanks for the information 06speed6. I have seen 6 deg of knock many many times under normal driving conditions. Of course if you change the way you drive you can almost elimiate all the knock in daily driving situations. Of course as soon as you approach 3k and over there it is. What are the differences in the speed6 motor to the speed3?
__________________ 2007 silver ms3 |
| Upgraded CDFP boom? | Demi | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 39 | 12-07-2008 09:10 AM |
| boom boom she goes | blackmica08 | MazdaSpeed 3 - Engine, Transmission & Driveline | 287 | 12-03-2008 10:33 PM |
| Will forged rods definitely keep the boom away? | soul.survivor | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 11-27-2008 12:46 PM |
| Small-car boom misses Chrysler | Haltech | Automotive News | 0 | 07-13-2008 10:10 PM |
