 Old 01-05-2012, 02:47 AM   #1
taotaogalu's Avatar
Posts: 3   (View Stats)
taotaogalu is an unknown quantity at this point
Default bottome end noise
I should take the time to introduce my self but I got a problem i currently own a 07 mazdaspeed 3, and recently changed out my VVT actuator since the original was damaged and also changed out the timing chain and tensioner since actuator was being install.Anyways with the original acutator i had a terrible tick, but still had smooth idle to compression lost and still had very good oil pressure my mechanic removed the oil pan and found to spun rod bearings.They finished my car today after waiting a month and a half and they said the top end noise is gone but there's still a knock coming from the bottom end and he said something about a thrust washer and main bearings being replace and play exceeding the .55 mm limit.Help need advice car has a corksport full turbo back exhaust kn intake and thats it.
taotaogalu is offline   Reply With Quote
 Old 01-05-2012, 02:52 AM   #2
zlatan's Avatar
Posts: 166   (View Stats)
zlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the world
Groaned at 8 Times in 4 Posts
Learn to type.
Sounds like you need a new mechanic. Thrust washers and spun rod bearings are apples and oranges. It doesn't take 1.5 months to replace spun rod bearings.
That's just my take.
-Anon.
zlatan is offline   Reply With Quote
The Following User Says Thank You to zlatan For This Useful Post:
kmac (01-05-2012)
 Old 01-05-2012, 03:03 AM   #3
taotaogalu's Avatar
I live on Guam and the dealer was the only trustworthy shop to take my car..and there slow
took them that long to find the vvt problem, now got this problem.Just wanted to know what could be the problem now,where do I go from here.And the car has no spun rod bearings my mistake.
 Old 01-05-2012, 06:54 PM   #4
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
did they have the timing tools? They would have needed it to change vvt, chain, etc ...
GL, make them replace what ever they damaged
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 01-06-2012, 01:14 AM   #5
taotaogalu's Avatar
They should have it,I hope they used one there the only mazda dealership here on Guam.I will call and ask.
 Old 01-06-2012, 01:47 PM   #6
easy's Avatar
Groans: 27
oh its a mazda dealer? .. never mind then, thought it was just a independent shop
08 MS3
 Old 01-06-2012, 01:51 PM   #7
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Sounds like that dealer is on an island both figuratively and literally. Tell them to get their heads out of their asses and call some dealers on the mainland.
07 MS3
The original Genpoo Hater
Noise KR, what can i do? nextgenerationx1 2010 MS3 - ECU Computer Tuning 27 01-26-2012 08:15 AM
Yet another noise! forcedinduktion 2010 MS3 - Troubleshoot/Diagnostics 11 10-24-2011 11:23 AM
What's that noise? dbaker 2010 MS3 - Car Audio & Electronics 10 06-20-2010 09:03 PM
TOB Noise,, WTH ANMSPD3 MazdaSpeed 6 - Engine, Transmission & Driveline 3 04-05-2010 08:12 AM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 05:00 PM
Page generated in 0.27400 seconds with 23 queries
