Built motor startup fail, HELP!!! 1 Attachment(s) Got my built motor installed last weekend and upon trying to start it up at almost midnight on Sunday, this epic fail happens. We called it a night after this due to lack of sleep and having to work at 6 am. Didn't think to try and get any codes from the AP going to look at that tomorrow and start troubleshooting. We verified timing 3 times before fully assembling the block, there was just a hair of play in the chain. After the attempted start up the shit is way tight from what I can feel through the oil cap, could it be a tight spot in the chain due to valve springs? I am also thinking crank position sensor possibly? Any ideas? |
did you try turning the motor over by hand? |
That's on the list of things tomorrow after checking the ap for codes. I know the battery needs a charge...fucking just got the thing 3 months ago and it was only out of the car for week. :mad: :wtf1: |
Check all of your electrical connections. |
If this is the same guy on the facebook group, which I'm about sure it is. He would have avoided this problem by cranking it by hand. I think he took off the valve cover and the clearance for the cams and buckets wasn't correct, which in turned ruined pretty much everything in the head. |
I found this out the hard way myself a few days ago. 200 miles on a fresh motor with very tight clearances. It ran, had good compression in 3 cylinders. |
6 Attachment(s) Pics of fail. Lesson learned. |
| All times are GMT -7. The time now is 07:10 AM. |
