![]() | | #1 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
(Thread Starter) | Not Ranked : 0 score Again when we torqued the cam bolt down there was oil on the friction washer. Is this a problem? The cam bolt lives in an oil environment but when torqued down oil will not get between the bolt and cam. I was wondering what your knowledge is regarding the friction washer and if oil getting on the friction washer is a problem or am i worrying to much about this and it shouldnt be a problem? My engine is in my car but there is no fluid in it and i still have a good handful of things to assemble to it before i finish the install. If I need to pull the valve cover and try to clean the cam friction washer now would be the time. Please let me know your thoughts on this! @Lex @atvfreek @Alpha @SPEED6 KILLAH
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
| Not Ranked : 0 score You want that washer and mating surfaces CLEAN and DRY.
__________________ |
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | Alpha (11-18-2013), Easter Bunny (11-19-2013), El_Diablo (11-18-2013), Realgib3 (11-18-2013), Sid3wayS (11-19-2013) |
(Thread Starter) | Not Ranked : 0 score Any particular reason why it needs to be clean and dry? What are the drawbacks of it with a little oil on it? I've talked to a few people including atvfreek and they all said it shouldnt be a problem or make a difference. We torqued it down pretty good and the engine turns in the direction we tightened it so its not working against itself. I'm still a little on edge about it but cannot find any concrete information online about what could/would happen with oil getting on a friction washer.
![]() | | #4 | ![]() |
| Not Ranked : 0 score Oil isn't compressible, and the washer holds based on friction. Anything on the surfaces will reduce that friction.
| The Following 10 Users Say Thank You to silvapain For This Useful Post: | Alpha (11-18-2013), Crarrs (11-19-2013), Easter Bunny (11-19-2013), El_Diablo (11-18-2013), JeffroMS3 (11-21-2013), Lex (11-18-2013), Realgib3 (11-18-2013), Roddiy (11-19-2013), Sid3wayS (11-19-2013), ZoomZoomEd (11-19-2013) |
![]() | | #5 | ![]() |
| Not Ranked : 0 score Correct. Any substance that reduces the static friction coefficient will make it more prone to slipping. Whether it will actually slip or not in your application is a different question. Better safe than sorry.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
![]() | | #6 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score I always wipe everything clean before assembly, but I'm sure if there was a tiny bit of residue that it shouldn't affect anything
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 2 Users Say Thank You to atvfreek For This Useful Post: | Easter Bunny (11-19-2013), LumberJack (11-18-2013) |
![]() | | #7 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson | |
| The Following User Says Thank You to El_Diablo For This Useful Post: | Realgib3 (11-18-2013) |
![]() | | #8 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm just going to run with it like this. ATVFREEK, Pablo and a few trusted local mazda mechanics i talked to said it will be ok.
| The Following 2 Users Say Thank You to Matrix311 For This Useful Post: | atvfreek (11-18-2013), SPEED6 KILLAH (11-18-2013) |
![]() | | #9 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
Groans: 52
| Not Ranked : 0 score As nice as it would have been for the surfaces to be perfectly clean, you may be fine since the cams aren't what slips on these motors, at least I've yet to see one that did. There is just a LOT more stress put on the crank sprockets, which I've seen slip many times, due to improper cleaning or torquing issues. With that said, THE MINUTE you see/feel something wrong in a log, check your mechanical timing. |
| The Following 4 Users Say Thank You to Realgib3 For This Useful Post: |
![]() | | #10 | ![]() |
(Thread Starter) | Not Ranked : 0 score Crank was perfectly clean with 3 brand new washers. We torqued to 76lbft then did 90* turn. We then checked to see where that might be for total torque and it was still clicking at 160lb ft so we know it's beyond that. The crank should not slip. Will certainly keep an eye and feel on the upper washer during initial startup and driving. The exhaust cam called for like 51-56lbft and we did it by feel and it should be well beyond that since we couldn't get a torque wrench on it with the timing cover on. Sent from my SCH-I535 using Tapatalk
| The Following 3 Users Say Thank You to Matrix311 For This Useful Post: |
![]() | | #11 | ![]() |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
| Not Ranked : 0 score Matrix clean the Surface area off really good before Installing the washer also note at the end of the day the washer still get oil on it just saying guys..
__________________ [SIGPIC][/SIGPIC] |
| The Following 3 Users Say Thank You to SPEED6 KILLAH For This Useful Post: |
![]() | | #12 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 2046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 32
Groaned at 19 Times in 15 Posts
| Not Ranked : 0 score DISCLAIMER: This is just a thought I'm throwing out there for discussion - don't do stupid shit! Could it be beneficial to use some high-temp threadlocker/retaining compound on the friction washers?
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon |
![]() | | #13 | ![]() |
| Not Ranked : 0 score I have used high-temp threadlocker doesn't really help from what I have seen tho.
| The Following User Says Thank You to SPEED6 KILLAH For This Useful Post: | JMEngineer (11-18-2013) |
![]() | | #14 | ![]() |
I can't pull that cam bolt without removing the timing chain right? I had to take a bunch of stuff apart this evening as I had a cracked coolant hose, the one that comes out of the t-stat and crosses over the engine near the EGR valve, so this required me to remove the intake manifold. Since I'm this far into removing stuff, I suppose I could remove the valve cover if you find it necessary. I dont have the timing plate anymore that I borrowed from a friend or the TDC stud either. I'm assuming i would need these items if i were to break that cam bolt loose and try to clean the washer as I dont think I can replace it due to the timing cover and chain attached. I'm assuming this should be ok since Pablo said the washers do see oil during its lifespan and there have been no reports of anyone spinning a cam only the crankbolt I believe.
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package | |
![]() | | #15 | ![]() |
Groans: 793
| Not Ranked : 0 score Does the washer get oil between mating surfaces durning normal use? Shouldn't. I would calculatedly and meticulously clean with all the diamond washers, keeping even oil residue from my fingers away from them using nitrile gloves. @phate; @silvapain; You can get the cams out without pulling the timing cover. DJ wrote a how when he retorqued his head studs. Also, if no one is slipping the cams, why are people paying to have them pinned?
| The Following 4 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #16 | ![]() |
| Not Ranked : 0 score The timing chain is squirted with oil from a nozzle in the block/head to keep it lubricated and reduce wear and remove heat. The timing chain area is not submerged in oil under pressure. I find it unlikely that parts machined to as tight of tolerances as the cams and sprockets will have gaps large enough to allow oil to seep in under normal operating conditions. I don't remember there being any oil on my old friction washers when I pulled them out.
| The Following 4 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #17 | ![]() |
Groans: 769
| Not Ranked : 0 score Properly installed, with the washers biting as they should you shouldn't have any oil getting between the washers and sprockets.
![]() | | #18 | ![]() |
Groans: 793
| Not Ranked : 0 score that's what i figured as well.
| The Following User Says Thank You to Tokay444 For This Useful Post: | Realgib3 (11-19-2013) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok well I had a setback last night and had to rip the intake manifold off to fix a cracked coolant line. I'm going to take the valve cover off now to gain access to that friction washer. My question is can I replace that washer without removing the timing chain? Do I need to have the tdc bolt in place and the timing plate on again? If I have to remove the timing chain can I just loosen the cam bolt and clean the washer best I can with brake cleaner and degreaser and dry it with compressed air and then button it back up? My biggest concern is regarding the timing plate and tdc as I borrowed those from someone and do not have them right now. Sent from my SCH-I535 using Tapatalk
![]() | | #20 | ![]() |
| Not Ranked : 0 score Here is a picture of a high mileage camshaft that never had the vvt replace can see oil marks on it and get a understand how much it affect the washer ![]() ![]() ![]()
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score Wow thats a lot of oil, more then I would have thought. It never slipped i take it?
![]() | | #22 | ![]() |
| Not Ranked : 0 score yup and it never slip too..
__________________ [SIGPIC][/SIGPIC] Last edited by SPEED6 KILLAH; 11-19-2013 at 10:54 AM. |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Looks like oil never got on the inside of the washer; just around the outside. With it torqued down I doubt you will see oil cover the entire face.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I don't even know how much oil got on the washer. All I know is I saw a small bit of oil that seeped through the bolt head as there was a small drip just below the cam sprocket. For all I know it could have seeped out the edge instead of directly over the washer. My car is back together and I'm about to do the initial startup. ![]() ![]() Sent from my SCH-I535 using Tapatalk
| The Following 7 Users Say Thank You to Matrix311 For This Useful Post: | ArmanRus (11-20-2013), atvfreek (11-19-2013), Lex (11-19-2013), Realgib3 (11-19-2013), silvapain (11-19-2013), SPEED6 KILLAH (11-19-2013), superskaterxes (11-20-2013) |
![]() | | #25 | ![]() |
![]() Join Date: May 2012 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Welllll? Sent from my SCH-I605 using Tapatalk
__________________ Fuck MSF |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oil leak on the turbo feed line and my aux fan wiring is not turning on the fan and my clutch is having engagement issues. Aside from that she fired right up on the first attempt after I primed the oil and fuel. Once I hammer these 3 issues out I should be good to go Sent from my SCH-I535 using Tapatalk
| The Following 4 Users Say Thank You to Matrix311 For This Useful Post: | atvfreek (11-20-2013), El_Diablo (11-20-2013), SPEED6 KILLAH (11-19-2013), superskaterxes (11-20-2013) |
![]() | | #27 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score glad to see things are working! you should bleed the clutch slave just to be safe
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oh man I spent a good 30 minutes with my wife bleeding the clutch line and it finally works as it should. I was worried for a while that we put the clutch disk on incorrectly when we reinstalled the clutch because there was no resistance and the clutch wasn't popping out on its own. After constant bleeding and nearly an entire bottle all the air is out of the system and the clutch and brakes are working as they should. Now its about time to tackle this oil feed line leak and then i can enjoy the car and work on getting miles put on it and then start tuning with Justin.
| The Following 2 Users Say Thank You to Matrix311 For This Useful Post: | Easter Bunny (11-20-2013), Realgib3 (11-20-2013) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score For bleeding brakes and clutch I will not use anything else than this. Makes the job so much easier and pays for itself instantly. Motive Products #1 Selling DIY Brake Bleeder
![]() | | #30 | ![]() |
Sent from my SCH-I535 using Tapatalk Here is a shot of the clearance I have with the full race manifold. ![]() Sent from my SCH-I535 using Tapatalk
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package Last edited by Matrix311; 11-20-2013 at 11:19 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Must feel so great to have this back together and almost ready to rock. Congrats!
| The Following User Says Thank You to Lex For This Useful Post: | atvfreek (11-20-2013) |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
Groans: 793
| Not Ranked : 0 score i've replace front sway bar bushing 3 times. once a year seems to be sop. same with rear dampers. i replaced 3 rear dampers this past summer. time for real dampers i'd say.
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
Groans: 793
| Not Ranked : 0 score i just pick them up at mazda. they're 12 bucks.
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 11-20-2013 at 02:16 PM. |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cool Sent from my SCH-I535 using Tapatalk
![]() | | #37 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
| Not Ranked : 0 score exhaust clamp on TIP? nice, looks like that would work very well |
![]() | | #38 | ![]() |
Groans: 769
| Not Ranked : 0 score Uhh, no..... That would be a T-Bolt clamp.
![]() | | #39 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
Groans: 52
| Not Ranked : 0 score Fwiw using an arp bolt I just torqued 85 ft lb on crank pulley then 90 and another 45. I don't know how much torque that is but I never want to slip I did basically the same thing two years ago with oem bolt and never had the crank slip and I ran the shit out of my car before turbo took A shit |
![]() | | #40 | ![]() |
Groans: 793
| Not Ranked : 0 score Wow.
| MS6 washer nozzles | paveltol | MazdaSpeed 6 - How-To's | 14 | 02-19-2012 01:14 PM |
| Friction Modifier | FULLBLOWN | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 01-06-2010 08:32 PM |
| Tranny fluid.. MT-90 GL4 or GL5? Friction Modifier? | speed3 | Mazdaspeed3/6 General Discussion | 34 | 06-17-2008 08:07 AM |
