![]() | | #41 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
(Thread Starter) | Not Ranked : 0 score Sent from my SCH-I535 using Tapatalk
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
![]() | | #42 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
Groans: 52
| Not Ranked : 0 score I just found the thread where I did it two years ago I did 90 ft lb on oem bolt then about 120 degrees I ran the shit out of it with 25 boost never slipped |
![]() | | #43 | ![]() |
Groans: 793
| Not Ranked : 0 score Don't do anything to that crank bolt that isn't outlined in the manual.
| The Following User Says Thank You to Tokay444 For This Useful Post: | phate (11-20-2013) |
![]() | | #44 | ![]() |
Groans: 52
I estimate my bolt is around 315 ft lb right now Fuck the manual the only times it worked right for me is going over the spec. To each.his own but the manual is for stock power setups You guys do what you want but I can't afford crank slip The only difference this time between last is I used arp bolt instead of oem and I used arp lube instead of red loctite Last edited by Nitr0EngiE; 11-20-2013 at 03:35 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #45 | ![]() |
Groans: 793
| Not Ranked : 0 score Stretching that bolt farther than you're supposed to, can result in less clamping load.
![]() | | #46 | ![]() |
Groans: 52
| Not Ranked : 0 score Well honestly none here can tell me or you what the torque spec should be for the arp bolt anyways, the paper says 140 which is laughable If the arp bolt is a complete piece of shit then we will find out because the oem bolt held up fine to just as much as what I just did and it's supposed to be 220k vs oem 145k |
![]() | | #47 | ![]() |
Crank slip? maybe easy fix. and The most awaited build in MSF history It seems like your conjecture of what is "better" than the Mazda procedures has gotten you into some trouble quite a few times with this engine. Why not just use what is proven to be good?
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
![]() | | #48 | ![]() |
Groans: 52
And secondly there are several people who in those threads have gone over the torque and did something different successfully and Idid not see you give them shit for trying things different just because they are on the band wagon out gear heads If it fails it's my fault none elses and I will own it | |
![]() | | #49 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
| Not Ranked : 0 score |
![]() | | #50 | ![]() |
| Not Ranked : 0 score TTY bolts are meant to be loaded to their yield point; going higher reduces the clamping load. http://web.mit.edu/course/3/3.11/www/modules/ss.pdf
__________________ |
![]() | | #51 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score An exhaust clamp wouldn't provide as much clamping force as a T-bolt clamp in this application.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nope its a tbolt clamp. Htp provides to tbolt clamps for the install. It was a major pita to put this intake on let me tell ya. Sent from my SCH-I535 using Tapatalk
| MS6 washer nozzles | paveltol | MazdaSpeed 6 - How-To's | 14 | 02-19-2012 01:14 PM |
| Friction Modifier | FULLBLOWN | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 01-06-2010 08:32 PM |
| Tranny fluid.. MT-90 GL4 or GL5? Friction Modifier? | speed3 | Mazdaspeed3/6 General Discussion | 34 | 06-17-2008 08:07 AM |
