-   -   Can this head be salvaged (http://www.mazdaspeedforums.org/forum/f10/can-head-salvaged-80961/)
ms3-87 05-17-2011 06:58 PM
ok so abt 2 years ago i threw a rod and the block has been setting outside for a While...
this is the only cylinder with bent valves the rest are fine and there is quite a bit of extensive rust but can this head be re worked?
rodrigo 05-17-2011 07:32 PM
i cannt seee shit man.
if valves is bebt thewn valve needs replacing along wit valbe guide....
if vlave seat is damamges u migh need to cut it and press in a new esearksdjqfjq seat!!! fuck en keubouar
rust???? on aluminum???jajajajajajajajajajajajaja
sand blastjh that swhit nioggah!!!!
sent via
vic a talk
I Love Brownies 05-17-2011 07:37 PM
losing weight= lenny being a cheap date
socks 05-17-2011 07:46 PM
yea, that rust is probably just surface rust on the carbon buildup. alu has a hard time rusting. clean it up, repair the bent stuff.
rodrigo 05-17-2011 08:00 PM
donrt get ut?
huh???
borught to u
via vic a talk
I Love Brownies 05-17-2011 08:03 PM
vicodin ftw. did you snort them??
Raider 05-17-2011 08:08 PM
Only way to know is at a machine shop to check for warping and cracks. Blasting too.
phate 05-17-2011 08:11 PM
It could be repaired. Much, much worse can be repaired. It's just a matter of "is it worth it". Get a quote from a good shop, it may be more cost effective to get a different head.
http://www.youtube.com/watch?v=JBkgJNEStxo
rodrigo 05-17-2011 08:17 PM
omg....hea d it ok
unles the surgace has a chink missing its ok
jesus
vic a talk
MS3inDC 05-17-2011 08:24 PM
Lenny, we love ya...
But
Detox for coherence
Fuck that, never mind. I just need to get on your level...
Oxy talk coming soon...
rodrigo 05-17-2011 08:27 PM
im fudkne up!! but i stuill know wut i taking boutz nig
that ehead neesds work thats alll....untless the valve or piston head dented the sureface everythng els is easuly fixed
via vic a tlak
fyon 9o= oxy)
Page generated in 0.17244 seconds with 11 queries
