![]() | | #41 | ![]() |
![]() Join Date: Apr 2010 Location: Hermosa Beach, Ca
Rep Power: 225 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
(Thread Starter) | Not Ranked : 0 score 1) AP is not broken 2) Car is not cutting and as from what I can see in the logs nothing is out of the ordinary what do you guys thing Maybe @ 11.79 sec the fuel pressure is an issue? Car hasn't cut out since flashing the ecu - i know people said not too but it was the only way i could log at current time. Could it have been cutting because of lack of tune? I am montitoring everytime i drive and afr/disi fp look ok
__________________ 07 Speed 3 COBB AP / Sure Aeros SRI / HTP TIP / PG Pipes/Godspeed Type C Core / Autotech Internals / PTP Injector Seals / CNT Catless TBE / Sure TIG / CP-e 75A RMM / SU PMM & TMM / JBR SSP / JBR Heavy Shift Knob / KSport Kontrol Pro CO / JBR RSB / HTP Battery Tray / Prosport Boost Gauge Permed CORN Fed 25% - SOLD[COLOR="Blue"][CENTER]2012 Speed 3 - Sold |
![]() | | #42 | ![]() |
![]() Join Date: Mar 2011 Location: Trailerville, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 414
Groaned at 15 Times in 12 Posts
| Not Ranked : 0 score I don't see any cutting issues, but you are still getting too much knock over 5000 RPM, switch to 91 ocatane map or get ATR.
__________________ Cool sig coming soon. |
![]() | | #43 | ![]() |
![]() Join Date: Oct 2009 Location: Gilbert, Az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 347
Can you add in Long Term FT as a logged parameter? Checking that your LTFT is correct is usually the first basic step in making sure things are "okay". Also add "Calculated Load" as a parameter. Besides that, your BATs are pretty high: ~150-160 You're getting KR in the 5-6 range around 5k rpms (a known "trouble" area for KR) which is pretty bad. Are you logging WOT runs after driving in stop & go traffic? Steps I'd recommend: Add in LTFT, check driving conditions. If you're going right into boost after stop & go traffic: don't! If you live in a hot climate, you might need to eventually alter your map to pull a lot more timing under hot conditions (either set the timing values around 5k manually, or adjust the Ign BAT vs ECT Comp tables). Keep monitoring the BATs with the AP, and if it's over 155 or so you should stay out of boost until you can get a custom de-tuned map in there. Your engine should correspondingly thank you by not blowing up. | |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score ATR came via email yesterday, but I cannot open it with a mac. Is it mac compatible?
![]() | | #45 | ![]() |
| Not Ranked : 0 score I dunno, probably not since macs are fucking gay.
![]() | | #46 | ![]() |
![]() | | #47 | ![]() |
![]() Join Date: Apr 2009 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 677
Groans: 320
Groaned at 78 Times in 45 Posts
| Not Ranked : 0 score use vmware fusion, I use that for the dashhawk software which is PC only..works just fine for pulling logs.
__________________ when was the last time your speed reeled in this many bitches? ![]() ![]() |
| The Following User Says Thank You to Manny For This Useful Post: | stokes620 (06-06-2011) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/car-hitting-brick-wall-80157/ | ||||
| Car is hitting a brick wall - AP log attached | This thread | Refback | 05-18-2011 12:49 PM | |
| Detroit's weak spot -- or a brick wall? | Haltech | Automotive News | 0 | 03-06-2011 10:10 PM |
| Brick By Brick: James May's Lego house comes down | Haltech | Automotive News | 0 | 09-23-2009 06:40 AM |
| VIDEO: Dodge Challenger hits brick wall, sees five stars | Haltech | Automotive News | 0 | 11-04-2008 02:20 PM |
| Buy a brick from a fallen Flint assembly plant | Haltech | Automotive News | 0 | 06-20-2008 08:30 AM |
