Notices
 Old 06-17-2009, 07:07 PM   #1
etant333's Avatar
Posts: 75   (View Stats)
etant333 will become famous soon enough
Default catch can... and nothing
i just installed a catch can and second pcv 2 weeks ago and i have been checking the can and i am getting nothing out of it. i removed the hose from the engine side and not a trace of oil in it. any thoughts of why i am getting nothing and others are getting a ton??
08.5 ms3 white: corkspot tbe, cut injen cai, inlet pipe, forge bpv, cooling mist meth kit with cp-e pro fuel controller, trz mm, dh, hpfp, exhaust depot fmic, cpe sb, catch can, prosport boost gauge.
etant333 is offline   Reply With Quote
 Old 06-18-2009, 04:15 AM   #2
buddhabum's Avatar
Posts: 254   (View Stats)
buddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond repute
Where is your catchcan mounted? Above or below the PCV on the block?
'06 MS6 Black Mica
Street Unit Block, CP Pistons (9.0:1), Pauter Rods, CPBoost Top-mounted Turbo Exhaust Manifold w/ Tial 38mm External Wastegate, Custom 3", CP-E FCF (No Boost cut, 3.25" MAF), CP-E PnP Standback V2, CP-E HPFP, CP-E FMIC Core w/ Custom piping, Denso Spark Plugs, Custom Inlet w/ 3.25" MAF Housing, VCTS Delete, EGR Block-off, Saikou Michi OCC, Fidanza Flywheel, HD Signature 18x8" MSR Wheels, HTR Z III's 235/40/18, BS Delete, TWM Stage 2 SS Kit, Dashhawk, Perrin EBCS.
buddhabum is offline   Reply With Quote
The Following User Says Thank You to buddhabum For This Useful Post:
94jedi (06-18-2009)
 Old 06-18-2009, 06:13 AM   #3
eddelgado's Avatar
Posts: 84   (View Stats)
eddelgado will become famous soon enougheddelgado will become famous soon enough
How many miles have you run it?
I am catching about two to three ounces every 1000 miles.
Ed
eddelgado is offline   Reply With Quote
 Old 06-18-2009, 06:07 PM   #4
etant333's Avatar
below the pcv. run it like 400 miles but not even any oil traces in the hose
 Old 06-18-2009, 07:41 PM   #5
eddelgado's Avatar
Sounds to me like something is wrong.
Are you sure you have the PCV valves installed properly? You should be able to take the piece of hose that is the vacuum source- the one that goes to the top of the engine - and suck on it and pull air from the bottom crankcase area through your new second PCV valve.
If this is not hapenning then you probably installed the PCV valve incorrectly.
Ed
 Old 06-18-2009, 08:49 PM   #6
PaPaSpeed's Avatar
Posts: 602   (View Stats)
PaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the world
Sounds to me like the factory PCV is not functioning. Thats the one that is connected to the long hose that runs to the "in" or top fitting on the Saikou OCC. So thats the PCV that would allow the junk the enter the catch can.
CP-E Nano, CP-E Turbo inlet, CP-E TurboBack, CP-E Full Control, CP-E CDFP, CP-E Standback, Cobb RSB, ETS TMIC, SU Boost Tubes, SU MM, SU Shifter Bushings, Forge BPV, Eibach Pro Kit, Saikou Michi OCC, Denso ITV 22, Redline Hood Lifts, Redline (shift boot, armrest, e-brake cover), Amsoil 5w-30, Amsoil 75w-90, TWM A-6, Black badges, SU black side markers, 40% Tint, Rota Torques Gunmetalic.
PaPaSpeed is offline   Reply With Quote
 Old 06-18-2009, 10:25 PM   #7
SPD6Tuner's Avatar
Posts: 391   (View Stats)
SPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant future
Yea you probably just installed your second pcv wrong. Try flipping it.
SPD6Tuner is offline   Reply With Quote
 Old 06-19-2009, 03:20 PM   #8
kgb
kgb's Avatar
Posts: 779   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 68
That's what happened to me originally. Flip it and catch away......
MazdaSpeed CBE - CNT Downpipe(diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK Stock Plugs |
Cp-e
RMM (75)
- Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - JBR Rear Cambers - JBR 5mm Wheel Spacers - Clutch By-Pass |
JBR EGR Delete - TB Coolant Bypass - Air Reroute to SRI |
Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated
- DSC LED Rerouted |
US Amp (in Series w/ Stock Amp) - Orion Gen.2 H2O 12” Sub (Custom Box) - Stock Speakers Mids & Highs Only |
UnderGlow Red Led’s - Interior Red Led’s - Engine Blue Led’s -
Car-Wide Tinting - Gun Metal Stock Wheels - Ventshade Deflectors - Home Depot Mod |
kgb is offline   Reply With Quote
 Old 06-19-2009, 07:24 PM   #9
etant333's Avatar
shouldn't it be installed in the same direction as the stock one to allow flow into and then out of the can in vac but not pressurizing the can.
i can suck but not blow through the one coming from engine and can blow but not suck from the one going to the intake. pretty sure that it is correct
 Old 06-19-2009, 07:29 PM   #10
SPD6Tuner's Avatar
Yea thats how its supposed to be. Then you have another problem. Your can is probably to high.
 Old 06-20-2009, 10:24 AM   #11
etant333's Avatar
the bottom of it is against the splash shield is not getting lower
 Old 06-20-2009, 01:47 PM   #12
SPD6Tuner's Avatar
So you'll have to move it. I cant think of any other reason.
 Old 06-20-2009, 02:00 PM   #13
J-villa's Avatar
Posts: 354   (View Stats)
J-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the world
Groans: 46
Groaned at 13 Times in 7 Posts
sounds to be the most legit reason
Om Nom Nom
[Flickr]
J-villa is offline   Reply With Quote
 Old 06-20-2009, 02:02 PM   #14
bnoon's Avatar
Posts: 1,762   (View Stats)
What kind of catch can is it? Is it a cheapie Ebay one or one with actual collection grid/media in it? If it's a cheap POS, then you may not get a drop out of it no matter where it's mounted. If it's something as good as a Saikou, then I have no ideas as to why you're not getting anything...
2008.5 MS3 GT - Sold!
2011 Ford Flex LTD Ecoboost
1986 Porsche 944 Turbo
bnoon is offline   Reply With Quote
 Old 06-20-2009, 03:22 PM   #15
eddelgado's Avatar
Another possibility is the hoses. Our cars put in quite a bit of vacuum and the hoses are pretty long. What kind of hose did you use? I am using a marine grade gasohol proof hose with a Saikou Michi can and not having any problems. The hose that I am using is very stiff and will not collapse under vacuum. If you are using one of those lightweight, clear, and not oil/fuel proof hoses it may be collapsing and not pulling a lot of air from the crankcase.
Ed
 Old 06-20-2009, 05:10 PM   #16
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,738   (View Stats)
Groans: 66
Either your hoses suck, or the factory PCV is bad.
Current Fail:
2006 Mazdaspeed6 Building, soon DD, future track whore
1986 Porsche 944 turbo Listed
2007 Kawasaki ZX-6R DD/Beater
MATT DAMOND is offline   Reply With Quote
The Following User Says Thank You to MATT DAMOND For This Useful Post:
J-villa (06-20-2009)
 Old 06-20-2009, 07:36 PM   #17
etant333's Avatar
i can suck through the factory pcv but not blow so it should be working the hose i bought from the speed shop is vac resistant hose and was 50 buck for 10 foot so i dont think it is the problem and no its not an ebay can it is baffled inside and such
 Old 07-18-2012, 11:24 AM   #18
Hit Redline's Avatar
Posts: 70   (View Stats)
Hit Redline is a splendid one to beholdHit Redline is a splendid one to beholdHit Redline is a splendid one to beholdHit Redline is a splendid one to beholdHit Redline is a splendid one to beholdHit Redline is a splendid one to beholdHit Redline is a splendid one to behold
Any update to your issue? I am having the same results, 1,000 miles and not a drop.
08 Speed3 -AP Tri-Point Tune, CS intake, CS TMIC, Autotech internals, Cobb DP, JBR RSB w/ Tri-point endlinks, Koni Yellows, H&R Springs, JBR short shift, JBR OCC, Bose Delete
85 Mazda RX7 -3rd gen motor, single turbo, built by Rotary Shack
04 BMW 745Li
1997 Mustang Cobra Vert- WMS intake, Shorty headers, Bassani CBE, Bassani X-pipe, Steeda rear lower control arms, Steeda shifter
Hit Redline is offline   Reply With Quote
 Old 07-18-2012, 11:38 AM   #19
zatara's Avatar
Posts: 1,408   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
Atleast you searched. This is a 3 year old topic though
2010 Mazdaspeed 3 Black Mica
CorkSport SRI/ TIP-- CorkSport TMIC-- Cobb DP-- CorkSport CBE-- Cobb AP Stratified Lex Tune-- Autotech Internals-- Denso ITV22's-- JBR EGR Blockoff-- JBR OCC-- JBR 88 Chrome-Molly RMM-- JBR 80 PMM-- JBR 88 TMM-- Corksport Skidplate-- JBR RSB
Red JBR shift knob-- VG Sharkfin--CS LED interior lights-- Hardwired Valentine 1 Radar detector-- 5K HID lows-- 3K HID Fogs-- 30% tint front, 20% tint rear
zatara is offline   Reply With Quote
 Old 07-18-2012, 11:38 AM   #20
Scammer Hunter
Raider's Avatar
Posts: 15,269   (View Stats)
Groans: 460
Groaned at 108 Times in 91 Posts
Holy dead thread revival.
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
 Old 07-18-2012, 11:47 AM   #21
zatara's Avatar
I should probably check my OCC now that I think about it. Checked it last week and nothing came out.
 Old 07-18-2012, 12:24 PM   #22
jack_hammer's Avatar
Posts: 4,315   (View Stats)
Groans: 413
Groaned at 106 Times in 62 Posts
it's fun to do bad things
 Old 07-18-2012, 12:35 PM   #23
I <3 your mom
Dash08's Avatar
Posts: 6,945   (View Stats)
Groans: 293
Groaned at 128 Times in 88 Posts
Some threads should be revived if someone has a problem that relates.
That's why they're here in the first place.
You guys tend to forget that there are tons of great, informative threads from even 3 years ago.
this forum serves 2 purposes
Dash08 is online now   Reply With Quote
jack_hammer (07-18-2012)
 Old 07-18-2012, 12:44 PM   #24
Scammer Hunter
Raider's Avatar
Groans: 460
The OP has not logged in here for almost 3 fucking years, Dash08. Posting asking for update is what is getting the guy the shitstorm.
The Following 2 Users Say Thank You to Raider For This Useful Post:
Dash08 (07-18-2012), jack_hammer (07-18-2012)
 Old 07-18-2012, 12:48 PM   #25
Groans: 413
hey man, i'm all for reviving old threads over starting new ones. but the guy was asking for updates from 3 yrs ago. basically, everything raider already said.
The Following User Says Thank You to jack_hammer For This Useful Post:
Dash08 (07-18-2012)
 Old 07-18-2012, 01:08 PM   #26
BeanerS3
LatinKraze's Avatar
Posts: 434   (View Stats)
LatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the world
Just for reference: my occ was "dry" for the first 1,500 miles. Now I get fluid every 1,000
2007 MS3 GT: BNRs3 and a bunch of other shit
K04 E26 PERM Tune 315hp/355tq @20psi
BNRs3 91 Self-Tune 309hp/371tq @19psi
BNRs3 E25 Self-Tune In Progress 348hp/376tq @22psi
LatinKraze is offline   Reply With Quote
The Following 2 Users Say Thank You to LatinKraze For This Useful Post:
Dahouse702 (07-18-2012), mxlplx71 (07-18-2012)
 Old 07-18-2012, 09:00 PM   #27
I <3 your mom
Dash08's Avatar
Groans: 293
My bad. I didn't catch that. Have at it, boys.
 Old 07-19-2012, 05:39 AM   #28
eddelgado's Avatar
I havent gotten anything from mine for about 5000 miles. I used to get a couple of ounces every 2500 miles or so....
 Old 09-02-2012, 01:12 AM   #29
world famous z's Avatar
Posts: 55   (View Stats)
world famous z will become famous soon enoughworld famous z will become famous soon enough
Groaned at 42 Times in 8 Posts
could it be simply that not every engine will produce blow by? I've tons of experience working on a variety of Nissans and I would run into the issue on the VQ engine platforms quite often where some will produce tons of blow by caught in the OCC while others (installed the same on the same motor of a different car) will produce next to nothing. It's odd I know but no two engines are exact. The Nissans and Infiniti engines did have some recall issues with oil blow by / burning in some cases, but again even on models whos vin fell into the valid recall / TSB range many did not produce the oil blow by issues.
world famous z is offline   Reply With Quote
Oil Catch Can Kit PDXImportRacer MazdaSpeed 3 - Engine, Transmission & Driveline 48 09-16-2009 08:18 PM
oil catch can? nyghtryder MazdaSpeed 3 - Engine, Transmission & Driveline 10 06-07-2009 06:17 PM
Oil Catch Can? bova Mazdaspeed3/6 General Discussion 11 12-06-2008 08:04 PM
$20 catch can yay or nay? kraz3y MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-30-2008 03:58 AM
Page generated in 0.46051 seconds with 35 queries
