Like Tree9Likes
 Old 01-07-2013, 03:26 PM   #41
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the world
Groans: 28
is the cobb downpipe any more/less restrictive then the cnt? Other then the 2.5 bottle neck.
Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned.
Freektuned e85 Focus st as the daily.
boostdmazda3 is offline   Reply With Quote
 Old 01-07-2013, 03:47 PM   #42
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Originally Posted by 86azms3 View Post
Yep it's super restrictive...I only made 390whp @ 23psi.....
I forget where I read it.
Ill try to find my source.
Your hp numbers don't lie though
@helmetface; I know that you have had experience with the catted dp, and had even said that you were going to gut the cat at one point. Can you add anything to this?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 01-07-2013, 03:54 PM   #43
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
While I have some data, but nothing to substantiate such a claim: I had the CNT Catted DP and I was experiencing a bit of a flow cap that other K04's at the time were able to surpass with their stock DP.
Essentially, I gutted the DP myself and no more restriction(duh) However, while the Cat was still intact- it was incredibly clogged only after only ~6months on a tuned K04(IE- not running overly rich)
The Following 2 Users Say Thank You to helmetface For This Useful Post:
pzr2874 (01-07-2013), smoogs12 (01-07-2013)
 Old 01-07-2013, 03:57 PM   #44
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Which brings us back to not all cats are equal.
The Following 2 Users Say Thank You to pzr2874 For This Useful Post:
Pseud0logik (01-08-2013), smoogs12 (01-07-2013)
 Old 01-07-2013, 03:59 PM   #45
smoogs12's Avatar
Groans: 423
Didn't someone do some dyno testing or something? I would swear I remember seeing a dyno comparison of the two.
I would swear that lex did something. Could be wrong though.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 01-07-2013, 04:10 PM   #46
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Corksport cat less dp and test pipe here. Love at first drive.
tappy-tap-tappytalk
Mods: stock
The Following User Says Thank You to faeker For This Useful Post:
agentgordon27 (01-13-2013)
 Old 01-07-2013, 06:16 PM   #47
SC08Speed3's Avatar
Posts: 298   (View Stats)
SC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the world
Ok, so know that I've got the DP and CBE ordered and on their way i need to make sure I've got everything ready. I will be ordering some stuff from edge to go on at the same time as DP/CBE and wondered if the turbo/downpipe studs and nuts they have on their site would work with the stock turbo? Only reason i ask is because i saw it said ATP somewhere.. I just want to have them in case something breaks, i can't have my car down!lol
08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K
SC08Speed3 is offline   Reply With Quote
 Old 01-07-2013, 06:18 PM   #48
Spec's Avatar
Posts: 4,472   (View Stats)
Did you get the hangers exhaust hangers too?
 Old 01-07-2013, 06:21 PM   #49
SC08Speed3's Avatar
 Old 01-07-2013, 06:42 PM   #50
Spec's Avatar
Corksport makes PU ex. Hangers. I've read a few places about some cbe rubbing and I think causing shifting issues if I remember correctly.
 Old 01-07-2013, 06:47 PM   #51
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
For what it's worth I've been running a CBE for a little over 30k miles and I have no issues with them moving or sagging. You can see at the end of the video I posted that the exhaust tip stays pretty firm. I wouldn't say you need to buy them right away.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
The Following User Says Thank You to ABSpeed3 For This Useful Post:
SC08Speed3 (01-07-2013)
 Old 01-07-2013, 06:50 PM   #52
SC08Speed3's Avatar
^ I have not yet, but i have been thinking about getting some urethane ones. And they do have them for the gen 1's as well!
 Old 01-07-2013, 06:50 PM   #53
smoogs12's Avatar
Groans: 423
If you are referring to the cnt cat back, yes the tip will rub.
Only way I could get it not to is to tie it off to the car using steel wire as seen here
How to install a CNT Racing CBE
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following User Says Thank You to smoogs12 For This Useful Post:
 Old 01-07-2013, 06:54 PM   #54
ABSpeed3's Avatar
Groans: 133
Oh I didn't know the CNT had known rubbing issues, if that's the case nevermind what I said.
08.5 CWP MS3 GT
 Old 01-07-2013, 06:55 PM   #55
SC08Speed3's Avatar
I have that thread saved on my computer!lol I thought about trying to heat it up and bend it a little. There is a shop right next to mine that does some good exhaust work. They should be able to do it, if not than i will use the wire trick!
 Old 01-07-2013, 06:55 PM   #56
Etipp98's Avatar
Posts: 1,947   (View Stats)
My CNT CBE has had no fitment issues.
Etipp98 is offline   Reply With Quote
The Following User Says Thank You to Etipp98 For This Useful Post:
 Old 01-07-2013, 06:59 PM   #57
SC08Speed3's Avatar
I hope mine doesn't either!lol
 Old 01-07-2013, 10:31 PM   #58
alexryan's Avatar
Posts: 642   (View Stats)
alexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the world
Originally Posted by SC08Speed3 View Post
That sounds awesome!lol I can't wait!
yea man youre gonna love it
//2012 Black Mica Mazdaspeed 3//
//Sure Torq R3//Cobb AccessPort//Autotech Internals//Ultimate Racing Axelback//Resonator Delete//Ebay Catless DownPipe
//TR8L & Protege Garage piping//Devils Own Stage 1//NGK One Step Colder(failed) Denso ITV22//GoFastBits Blow Off Valve//Ksport Coilovers
//GTX 2867r//Protege Garage Externally Gated Manifold//Precision Turbo Wastegate//Bosh 3 Bar Map//HTP 3.5" Full Intake
//Grimmspeed 3 Port//Cobb Wastegate Lockout//Selfmade Screamer Pipe//ACT 6 puck w/ streetlite flywheel
// R3X Tune in Progress (self tune) 310whp 354wtq (CF 1.01) w. DO7 KO4
......GTX2867r 22psi: 357whp 353wtq (CF1.01)
Needs installing: JBR BSD kit, OCC
alexryan is offline   Reply With Quote
The Following User Says Thank You to alexryan For This Useful Post:
SC08Speed3 (01-08-2013)
 Old 01-08-2013, 11:46 AM   #59
SC08Speed3's Avatar
Yessir! I can't wait!
 Old 01-08-2013, 12:05 PM   #60
GODspeed7's Avatar
Posts: 3,456   (View Stats)
tappy-tap-tappytalk
Ordering my catless DP to go with my TP tomorrow. Sound clips of full catless corksport?
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
 Old 01-08-2013, 01:24 PM   #61
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I think you are referring to this conversation:
Battle my Virtual Dyno
smoogs12 (01-08-2013), Speed3eak (01-10-2013)
 Old 01-08-2013, 01:30 PM   #62
trf5000's Avatar
Posts: 2,290   (View Stats)
Do you have the V1 corksport with 1 resonator or the v2 with 2 resonators?
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 01-08-2013, 01:50 PM   #63
faeker's Avatar
Groans: 731
All I have is this video of a cold start w/o a resonator. i fucking hate it.
Mods: stock
 Old 01-08-2013, 01:54 PM   #64
atvfreek's Avatar
Posts: 7,787   (View Stats)
I can try and get a catless corksport wot on the way home tonight. It might be dark but you'll get the idea. Lol
Sent from your couch
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following User Says Thank You to atvfreek For This Useful Post:
rfinkle2 (01-08-2013)
 Old 01-08-2013, 03:12 PM   #65
GODspeed7's Avatar
Yes please!
 Old 01-08-2013, 04:32 PM   #66
atvfreek's Avatar
Yes please!
Here is the vid. I got your PM. Didn't realize your were looking for the catless corksport DP. This is catless, but with CS exhaust. lol
BNR stage3 Catless TBE (night video and only sound) - YouTube
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
kmpeeps (01-08-2013), rfinkle2 (01-08-2013)
 Old 01-08-2013, 04:40 PM   #67
GODspeed7's Avatar
Holy shit that is loud! Lol is that in car windows down or what?
atvfreek (01-08-2013)
 Old 01-08-2013, 04:42 PM   #68
atvfreek's Avatar
Lol, that is suction cupped to my bumper
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 01-08-2013, 04:50 PM   #69
Spec's Avatar
That sounds perfect.
The Following 2 Users Say Thank You to Spec For This Useful Post:
atvfreek (01-08-2013), kmpeeps (01-08-2013)
 Old 01-08-2013, 04:57 PM   #70
Jhornbrook's Avatar
Posts: 708   (View Stats)
Groaned at 6 Times in 4 Posts
Sex
The Following User Says Thank You to Jhornbrook For This Useful Post:
 Old 01-08-2013, 05:06 PM   #71
GODspeed7's Avatar
Ok well that's not SO bad. If that was inside with windows down, I was gonna rethink my purchase. Lol!
The Following 2 Users Say Thank You to GODspeed7 For This Useful Post:
atvfreek (01-08-2013), rfinkle2 (01-08-2013)
 Old 01-08-2013, 05:08 PM   #72
faeker's Avatar
Groans: 731
Bad sex. I'm looking into making mine quiet.
tappy-tap-tappytalk
Mods: stock
 Old 01-08-2013, 05:10 PM   #73
atvfreek's Avatar
Ya that's about the loudest place to put the camera but wanted the full effect. It's not that bad in the car. It seemed loud at first but I'm used to it now. Lol.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 01-08-2013, 05:18 PM   #74
GODspeed7's Avatar
I got the wife used to full JBR mounts and a corksport test pipe with resonator delete. What's a catless downpipe matter, right?
 Old 01-08-2013, 05:20 PM   #75
atvfreek's Avatar
Exactly! My wife didn't know the difference. My daughter did though. Lol
SC08Speed3 likes this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
Micha (01-11-2013)
 Old 01-08-2013, 06:13 PM   #76
SC08Speed3's Avatar
That sounds awesome man!
The Following User Says Thank You to SC08Speed3 For This Useful Post:
 Old 01-11-2013, 05:54 PM   #77
SC08Speed3's Avatar
I just got my DP today so i figured i would post some pictures! Sorry for the shitty cell phone pictures. It is being a PITA for some reason and keeps messing up when i try and upload pictures. Ill try again in another post!
 Old 01-11-2013, 06:03 PM   #78
SC08Speed3's Avatar
Ok, i give up!I will try to post the rest later! lol
 Old 01-11-2013, 08:08 PM   #79
SC08Speed3's Avatar
Well i got one more to upload!lol I'll try again tomorrow, if anybody wants to see any specific parts/angles just ask!
 Old 01-11-2013, 08:41 PM   #80
Ranyard's Avatar
Posts: 146   (View Stats)
Ranyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond repute
ok, link to this item on ebay please
"The eagle never lost so much time as when he submitted to learn from the crow" ...nobody
Ranyard is offline   Reply With Quote
In stock now CNT Racing Mazdaspeed 3 catted and non Catted downpipe ERZperformance ERZPerformance 325 08-04-2013 05:13 PM
CA laws, DP, catted/non catted galens47 Gen2 MS3 General Discussion 15 06-19-2012 06:59 PM
Catted downpipe + catted racepipe mituc MazdaSpeed 3/6 - Turbo Induction 65 11-29-2011 04:43 PM
catted DP or cattless DP? black-speed3-gt Miata - Engine, Transmission, Driveline 1 04-12-2009 11:22 PM
Page generated in 0.58566 seconds with 36 queries
