| MSMS3 | 01-12-2011 04:41 PM | 1 Attachment(s) Quote:
Originally Posted by Kdawg207
(Post 685552)
wastin yur $ on the cbe
keep it stock | Agree. OP: Look at my sig, and also check out my posts on this issue. My experience is that the stock CBE is going to flow better than the stock K04 turbo's maximum exhaust discharge rate. Those severe exhaust restrictions are all upstream of the CBE, as you have already figured out.
I can't tell you if a catted dp into an open rp into the stock CBE will drone. I can tell you that my completely catless dp/rp into stock CBE had a terrible drone at 2,500 rpm, which I fixed with the big 3 inch straight through reso in my rp section.
My suggestion is to try your catted dp mated to the rp and stock CBE and see if you get drone. The cat may tone it down some. If you can live with it, leave the rp alone.
I see you are already one reso delete. Don't think that is going to help the problem, but not sure. Might want to have it welded back in after you see how the dp sounds.
If you are still unhappy, go to Amazon and order the reso in my sig. I think you can get it for about $80, way cheaper than a CBE that might not fix your problem anyway. Pulling the rp off to make this mod and putting it back is very easy. Not like trying to remove and replace the whole damn CBE, which you are likely to have to cut to get out anyway. Worked great for me. Vibrant part number is 1142. See photo below Just a thought . . . |
