 Old 05-01-2010, 08:58 AM   #41
Jarods7920's Avatar
Posts: 1,415   (View Stats)
I pulled the pan and changed the squirter. My final conclusion after looking at it and having it looked at by a few engineerig frieda of mine was that the brazing on the squirter failed and it just broke apart. There was no evidenvce pf contact on the broken squirter.
When I installed the new one I turned the engine over several times to be sure it was not contacting the rod and or piston
Jarods7920 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jarods7920 For This Useful Post:
Darksun280 (05-01-2010), djuosnteisn (05-01-2010)
 Old 05-01-2010, 10:28 PM   #42
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Did you do the engine assembly yourself jarod? Are you positive it wasn't over torqued in any way?
Cruzito had the same issue as you, and i just want to know if this is one of the things to look out for. May be best to torque to the low end of the spec and use a dab of lock tight. Dunno.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 05-01-2010, 10:37 PM   #43
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
spnkr21's machine shop had to tweak his oil squitters so they wouldn't hit the pistons/rods. my oil squitters were actually touching the skirt of the pistons and chopped them off. when they installed new squitters they had to tweak them a bit to avoid contact with the pistons.
both spnkr21 and I are running the same Wiseco piston as the OP.
11cruzito11 is offline   Reply With Quote
 Old 05-02-2010, 09:43 AM   #44
Captain
Groans: 79
Oh, so this is a wiseco piston issue? Damnit.
How did they tweak em cruzito? Just bend em a bit?
www.permtuning.com
 Old 05-02-2010, 10:12 AM   #45
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Default Re: Changed oil...look what i found attched to drain plug...
Yes I believe they did just bend them a little. I'm not sure if they knew they were touching by turning the motor over or if wiseco said to do it somewhere. Ruzito knows what happens if you don't do that .
2012 WRX HB w/mudflaps yo!
The Following User Says Thank You to spnkr21 For This Useful Post:
djuosnteisn (05-03-2010)
 Old 05-02-2010, 04:35 PM   #46
they bent them just a bit, i couldn't really tell though.
when they install your wiseco pistons keep an eye on this.
The Following User Says Thank You to 11cruzito11 For This Useful Post:
 Old 05-02-2010, 08:46 PM   #47
Jarods7920's Avatar
I did not do the assembly on my bottom end. However there was no mention of having to tweak the squirters. When i installed the new one and turned the motor over it did not contact the piston in anyway. I am not sure that its a wiesco issue for sure. The machine shop that did the assembly said they did not have to tweak them either.
The Following User Says Thank You to Jarods7920 For This Useful Post:
 Old 05-03-2010, 09:23 AM   #48
Captain
Groans: 79
I'll be doing my own assembly, so i'll keep a damn close eye on it, and take some pictures for all of us. Would be nice to nail down the mystery of dropping squirters.
www.permtuning.com
 Old 05-03-2010, 09:28 AM   #49
spnkr21's Avatar
Groans: 105
I don't think it's much of a mystery. If you bend them first you won't find them in your oil pan. That's just me though.
« Axels | plugs »
oil drain plug crush washer karl-hungus MazdaSpeed 3 - How-To's 18 06-10-2017 06:43 PM
Drain plug for oil? Wrxified 2010 MS3 - Torque Specs & information 35 04-02-2011 09:54 AM
Magnetiic Oil drain plug Jarods7920 MazdaSpeed 6 - Engine, Transmission & Driveline 21 08-20-2009 06:44 AM
Magnetic Drain Plug KayWhy MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-11-2009 12:45 AM
Magnetic Drain Bolt. Yes or No? desertrat Mazdaspeed3/6 General Discussion 14 10-09-2008 06:19 PM
Page generated in 0.28844 seconds with 23 queries
