 Old 10-12-2009, 08:59 PM   #41
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
I put in the CS DP with stock TP/CBE, little more growl and way less turbo lag. still sounds stockish though. put on the rest of the TBE and now anyone who doesnt know what a ms3 is asks if i swapped a STI motor in. its very deep rumble at idle, almost v6ish maybe? at WOT its definatly sex.... 10x better in person than video
reddeerspeed3 is offline   Reply With Quote
 Old 10-12-2009, 09:20 PM   #42
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
cs is the way to go. Best sound you can get by far. Also, I wanted to have it sorta quiet for normal driving then loud when I wanted it soooo I had a guy use one of my to cs test pipes to fab up a QTP e-cut out and... amazing. Back to stock for me though since the explosion. everything is for sale just been to lazy to make a thread. PM me if anyones interested.
 Old 10-12-2009, 11:06 PM   #43
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Hmm well shit lol and here i was thinkin the txs catback and everything was the loudest deal for our cars. Oh well lol
 Old 10-27-2009, 03:47 PM   #44
the518speedster3's Avatar
Posts: 32   (View Stats)
the518speedster3 will become famous soon enoughthe518speedster3 will become famous soon enough
i was just wondering with just adding a corksport dp, or any for that matter, how much louder will it be over stock exhaust?
the518speedster3 is offline   Reply With Quote
 Old 10-28-2009, 04:05 PM   #45
Realgib3's Avatar
Groans: 52
Not much louder, actually less of a droning in the cabin. It just gives it a more throaty sound.
CS DP/RP with stock catback IMO is the perfect sound.
The Following User Says Thank You to Realgib3 For This Useful Post:
IshiKage (10-31-2009)
 Old 10-28-2009, 08:24 PM   #46
martyxattack's Avatar
Posts: 924   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
corksport dp is great. easy install had no cels and adds great tone to the car with a tp. i did boost cut like a bitch thought when i got it. now cornerfreak is making great use of it.
know your roll
martyxattack is offline   Reply With Quote
 Old 10-29-2009, 12:48 AM   #47
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Ha, I didn't know that was your old DP. That thing went in so smooth. It was such an easy install. It practically jumped on the studs by itself. Everything lined up in one shot.
How long did you run that before selling it to Brian?
this forum serves 2 purposes
 Old 10-29-2009, 01:14 PM   #48
sorry for the dumb Q? but what do u mean u boost cut? im kinda new to FI cars and engines
 Old 10-30-2009, 09:57 PM   #49
your turbo hits 19psi because reduced backpressure = faster spool, and the ecu/ebcs cant compensate so it closes the throttle body to prevent a lean condition. its like hitting a brick wall, then boosting again, hitting wall, boosting, etc.
 Old 10-31-2009, 03:19 PM   #50
now what is a solution to this?? is there something that will help this boost cut out?
 Old 10-31-2009, 04:17 PM   #51
darth vader's Avatar
Posts: 665   (View Stats)
You can drive around the cut by getting into the gas a little slower. Whacking the throttle open almost guarantees it on a cooler day with DP + RP and intake mods.
Alternatively, you can put in a manual boost controller and set the boost wherever you want. There's enough wastegate on this turbo to avoid boost creep easily.
 Old 10-31-2009, 04:58 PM   #52
erod550's Avatar
Posts: 467   (View Stats)
erod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the world
Would a Standback or Cobb AP also be able to control the boost to avoid overboosting and getting boost cut?
erod550 is offline   Reply With Quote
 Old 10-31-2009, 08:51 PM   #53
yes, and its far better than a MBC. AP lets you control it in a similar to stock fashion with load tables, SB just acts as a MAP clamp and EBC
 Old 10-31-2009, 09:13 PM   #54
Always Blasted
DCLXVI's Avatar
Posts: 653   (View Stats)
DCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the world
Groans: 34
Groaned at 274 Times in 34 Posts
does the ATP CEL trick kit work as far as no cats go for the corkport?
07 Speed 6 GT Cobb AP Stage 2+TIHSF+TMIC 93 Octane, ETS 3.5'' TMIC, Cobb Short Ram Intake, Cobb Turbo Inlet Pipe, Turbosmart Dual Port Blow Off Valve, SU Test Pipe, Custom CPE/Magnaflow Exhaust, Corksport Strut Brace, TWM Stage 2 Short Shifter, TWM Weighted Desert Eagle Shift Knob, AWR Transmission Mount, SU Base Bushings, SU Rear Motor Mount, Optima Yellowtop Battery, PIAA Plasma Ion Fogs, EBC Red Brakes, Denso ITV22s .28 Gap, Prosport Boost Gauge, RPM Sport Springs, Bilstein Shocks, SPC Balljoints, Continental Extreme Contact DWS AAA XL, Pirelli Sottozero snow tires, 5zigen ProRacer GN+ 18x8.5.
DCLXVI is offline   Reply With Quote
 Old 10-31-2009, 10:03 PM   #55
the CS DP comes with a 02 sensor extender that does a very good job of keeping the CEL away. i'd say on average i get a "O2 sensor slow response" code once a month. clear it with the DH and carry on.
Need help choosing an OTS map... flz33
Cobb Access Port/Maps
2 08-12-2009 07:11 PM
Help choosing an exhaust mituc MazdaSpeed 3/6 - Turbo Induction 12 07-09-2009 09:41 PM
need help choosing 06speed MazdaSpeed 3/6 - Turbo Induction 4 03-15-2009 09:59 AM
Help choosing a new ap map. tburton101 MazdaSpeed 3/6 - ECU Computer Tuning 0 12-28-2008 02:40 PM
Page generated in 0.34352 seconds with 28 queries
