 Old 06-16-2011, 02:43 PM   #41
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Anyone else cleaned their valves with the head on the car? Need more idea...
Thanks.
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
 Old 06-16-2011, 04:54 PM   #42
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
Originally Posted by laxplayermjd View Post
The best way to do it is using a sand blaster with walnut shells media. Hard enough to get the carbon off without damage to the aluminum. As im sure no body has a sand blaster or anything. There is no easy way.
Next best thing is to soak with seafoam,or a fuel injector concentrate of some sort of tool/brush or whatever you can some up with to get down the ports and scrub.
Everything must be done a cylinder with closed valves or you cause big problems
brake parts cleaner will get that shit off
2015 MUSTANG GTPP
gtlaw is offline   Reply With Quote
 Old 06-17-2011, 09:40 AM   #43
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
I'm gonna go ahead and try this stuff:
Originally Posted by C.W. View Post
Has anyone used the 3M DIY Fuel System Tune Up Kit? How does it compare with Sea Foam? The 3M process seems safer (no hydro lock risk).
YouTube - &#x202a3M
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
Are Your Intake Valves All Guncked Up? SpdFreak MazdaSpeed 6 - Engine, Transmission & Driveline 131 07-31-2010 08:24 AM
Cleaning of intake ILoveSpeed 2010 MS3 - Engine, Transmission & Driveline 7 06-12-2010 05:22 PM
Cleaning air intake filter Night Wolf MazdaSpeed 3 - Engine, Transmission & Driveline 2 03-16-2010 03:54 AM
CPE Xcel Air Intake --Cleaning vballbwing MazdaSpeed 6 - Engine, Transmission & Driveline 6 12-09-2008 12:46 PM
Page generated in 0.26512 seconds with 22 queries
