-   -   Clicking when A/C is ON from passenger side (http://www.mazdaspeedforums.org/forum/f10/clicking-when-c-passenger-side-90909/)
Fobio 09-05-2011 08:21 PM
Today, I was idling in the underground garage and had the A/C on while I took a look and I heard an off-best ticking noise from the passenger side of the engine, I suppose the valve cover but more on the chain side only. I was concerned, but I tried it with the A/C off and it went away.
My car just rolled over 100,000km...is this the dreaded VVT failure?
easy 09-10-2011 02:11 PM
a/c clutch going bad maybe? ... it is constantly spinning with the crank and a/c clutch engages to run the compressor. Or maybe just worn bearings.
Raider 09-10-2011 05:05 PM
VVT will have major rattle at startup, goes away. Timing chain loose, rubbing valve cover is another. Can you post a video?
greenespeed 09-10-2011 05:35 PM
My car does this also, sounds like a bearing clicking around in there, but mine is only noticable really on low power setting, not so much at full blast and when a/c is off it goes away.
apena85 09-11-2011 09:33 AM
Its the tensioner plate. My car has this even after dealer replacement.
Here is a youtube of mine when it first happen before dealer replacement.
greenespeed 09-11-2011 05:47 PM
Yup, that is exactly what mine does. If you don't mind me asking what was the cost to fix that.
apena85 09-11-2011 08:19 PM
it was under warranty.
Whats funny is I change the drive belt today and the sound went away. I had to change the drive belt because a small pebble got in there and chewed up on of the ribs, so I changed it before it gave me any type of issues.
s1xstringmayhem 09-17-2011 12:36 PM
Has anyone fixed this problem on their own? Did you need to just replace the tensioner plate or is there more?
Zelliott15 09-24-2011 04:08 PM
I am having the same problem, my car has about 62k miles on it and I took a vid from the engine bay and fp wheel
yfrog Video : http://yfrog.com/msz3nz - Uploaded by zelliott15
yfrog Video : http://yfrog.com/n257601056z - Uploaded by zelliott15
apena85 09-26-2011 06:31 AM
It's been two weeks since I changed the drive belt and it seems to have completely nullify the sound. Haven't heard it since.
Page generated in 0.18736 seconds with 11 queries
