Clutch Fluid Bleeding Going to bleed the brake system with ATE Super Blue brake fluid, and since the clutch resevoir is shared with the brakes, the clutch has to be done too. Any tips on bleeding the clutch as I have never bleed a cluch cyliner? :thinkerg: Thanks in advance. |
It comes,out waaay faster than the brakes. |
Buy a $40 power bleeder from ebay or harbour freight. You'll be happier with the results in the end. |
I took a hole saw and cut a nice hand sized hole in the undertray that i can pull open to get to the reservoir, its on the drivers side of the oil filter i did it 2 days ago, used a vacuum bleeder |
Bleed Clutch Then Brakes, Bleed furthest to closest to master cylinder. Use a power bleeder to save time. |
| All times are GMT -7. The time now is 08:10 AM. |
