 Old 11-02-2011, 08:40 AM   #41
deuce_WI's Avatar
Posts: 234   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
Trans is out, axles still in knuckles. Stock clutch and flywheel are out too.
This was my solution on my old ZX-poo. Tranny was out multiple times on that car (I swear the diff was made of plastic on that pos), and after the first time fighting with the axles and giving up I just went straight to pulling them out with the knuckle. I thought it made things easier to just get it all out of the way.
deuce_WI is offline   Reply With Quote
 Old 11-02-2011, 08:45 AM   #42
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
yeah. As long as I can grind down the end of the axle that I hammered flat so that I can get the axle nut back on it, lmao.
07 MS3
The original Genpoo Hater
 Old 11-04-2011, 08:04 PM   #43
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
weight reduction!
you hammered it so hard it mushroomed? and it still didnt budge? lolwtf?
The Following User Says Thank You to socks For This Useful Post:
Chimmike (11-04-2011)
 Old 11-04-2011, 08:05 PM   #44
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Originally Posted by socks View Post
weight reduction!
seriously. Ask tech/sales@em , he came over the other night and helped me manhandle the trans kinda back into position. I thought the axle spine portions were hardened steel? lmao.
tomorrow it gets ground down to allow the nut back on. haha.
I was only using a 3lbs sledge.
07 MS3
 Old 09-07-2012, 12:25 PM   #45
greg08's Avatar
Posts: 480   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 22 Times in 15 Posts
Originally Posted by laxplayermjd View Post
the way i did my speed 6 was i dropped the whole subframe out. To not have to deal with tearing boots or pressing out the joints on the knuckle. I disconnected everything on the subframe side with the bushings. Ive always found this was easier except that you need to tighten all those bolts back up with the suspension loaded or your bushings with wear out quickly.
To get and axle out ive always just used a prybar between the trans and axle shaft. If it doesnt pop out give a slight tap on the axle with a hammer while prying.
I left my transfer case and passenger side axle attached.
Im pretty sure not having a transfer case will make it much easier for you.
Speed6 axle nut is 35mm, another most common size is 32mm
yup speed 6 is 35!!
greg08 is offline   Reply With Quote
Transmission swap / clutch install advise Tomas MazdaSpeed 3 - Engine, Transmission & Driveline 2 07-19-2011 07:46 PM
ACT Street Clutch Install... need help MS3 Ventura MazdaSpeed 3 - Engine, Transmission & Driveline 6 01-15-2011 11:23 PM
Please Help: DIY Clutch install Dobo MazdaSpeed 6 - Engine, Transmission & Driveline 12 04-13-2010 07:19 PM
Any ACT clutch not fit during install? gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-12-2009 03:16 PM
Clutch install time PDXImportRacer MazdaSpeed 3 - Engine, Transmission & Driveline 22 03-04-2009 06:39 PM
Page generated in 0.26474 seconds with 23 queries
