Like Tree9Likes
 Old 04-13-2015, 09:07 AM   #81
Jtaylor's Avatar
Posts: 656   (View Stats)
Jtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the world
What adjustment are you referring too?
08 MazdaSpeed3
| Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 |
| AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM |
| Black Powdercoated Stockers | Built Motor |
| Mahle 88mm Pistons | Manley H-Beam Rods |
Jtaylor is offline   Reply With Quote
 Old 04-13-2015, 09:08 AM   #82
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
To the pedal.-
How To: Clutch Pedal Adjustment
 Old 04-13-2015, 09:14 AM   #83
Jtaylor's Avatar
The clutch can only be adjusted on the 6, our cars don't have any adjustment to my knowledge.
08 MazdaSpeed3
The Following 3 Users Say Thank You to Jtaylor For This Useful Post:
Easter Bunny (04-13-2015), silvapain (04-13-2015), someguy (04-13-2015)
 Old 04-13-2015, 09:14 AM   #84
someguy's Avatar
Posts: 914   (View Stats)
someguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the world
Groans: 24
Groaned at 166 Times in 32 Posts
Isn't that speed 6 only?
- 2010 Mazdaspeed 3 Black Mica -
- Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 -
- SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace -
- CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint -
someguy is offline   Reply With Quote
The Following User Says Thank You to someguy For This Useful Post:
Jtaylor (04-13-2015)
 Old 04-13-2015, 09:16 AM   #85
Raider's Avatar
Groans: 856
Fuck, yeah forgot. Probably needs more bleeds
 Old 04-13-2015, 10:44 AM   #86
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
go with the Bendix CQ pads, very affordable and great performance for a DD
I hugged rfinkle2
Mauro_Penguin (04-13-2015)
 Old 04-13-2015, 11:02 AM   #87
Spec's Avatar
Posts: 4,472   (View Stats)
Unless you're afraid these will hurt your gimpy knee too.
The Following 2 Users Say Thank You to Spec For This Useful Post:
Easter Bunny (04-13-2015), Mauro_Penguin (04-13-2015)
 Old 04-13-2015, 11:08 AM   #88
Raider's Avatar
Groans: 856
Inb4theban.
I actually have a set of Bendix in my garage a local gave me after he sold his MS3. Unused. Well, they are missing clips, won't work.
Looking to do a Corksport pad and Stoptech steup. Or maybe some Autozone blanks.
Spec (04-13-2015)
 Old 04-13-2015, 11:23 AM   #89
Spec's Avatar
I'd try the stop tech, the vatozone will work but always seem like they lose a lot of material. Good size lip on the rotor after a pad change and that was also with the little bull shit pads they sell. Not sure how aggressive the CorkSport pads are, I can only imagine it would be worse.
 Old 04-13-2015, 11:35 AM   #90
Raider is mah Homie
Groans: 2,978
The bendix pads are $22. worth a shot. They have the same initial bite as the stock pads which is very important to me. Also very little dust my wheels have gotten cleaner since the change without washing.
I hugged rfinkle2
 Old 04-13-2015, 11:36 AM   #91
Jtaylor's Avatar
Don't go with the autozone pad, last time I purchased they had the MZ3 pad cross referenced with the MS3.
08 MazdaSpeed3
 Old 04-13-2015, 11:39 AM   #92
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Jesus. Your pilot bearing was seriously fucked.
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following 2 Users Say Thank You to Cataphract_40 For This Useful Post:
Mauro_Penguin (04-13-2015), Raider (04-13-2015)
 Old 04-13-2015, 11:39 AM   #93
Spec's Avatar
That seems to always be an issue with parts stores.
 Old 04-13-2015, 01:45 PM   #94
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Fuck autozone
it's fun to do bad things
 Old 04-13-2015, 01:46 PM   #95
Raider's Avatar
Groans: 856
Got Corksport pads on the way.
 Old 04-13-2015, 02:46 PM   #96
Raider's Avatar
Groans: 856
More clutch bleeding got more air out of the lines. Pedal is a lot lower than factory. But since the flywheel was not as thick as oem, maybe it's a lower pedal? Will drive more, bleed again tomorrow. It's at least up off the floor. Anyone else with stage 2 daily driver have the same experience?
 Old 04-13-2015, 02:47 PM   #97
Spec's Avatar
I always hated that, it's like a gamble it seems.
Did you compare the old and new clutch fork?
The Following User Says Thank You to Spec For This Useful Post:
Mauro_Penguin (04-14-2015)
 Old 04-13-2015, 04:15 PM   #98
EvoFire's Avatar
Posts: 389   (View Stats)
EvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the worldEvoFire is the leader of the world
Corksport pads are like little fluffy kittens. I've had them for 18 months and there's barely any wear on the rotor.
2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob
Dyno'ed at 277whp/290lb-ft on 91 piss
EvoFire is offline   Reply With Quote
The Following User Says Thank You to EvoFire For This Useful Post:
 Old 04-14-2015, 07:08 AM   #99
Raider's Avatar
Groans: 856
I wanted to,0 but had to go in the house to get a kid fed and down for a nap. When I came out, new was in. Let's just say it was bent and good thing I swapped. Shifts are better tho.
That is good! I plan to get rotors ordered today. My guy is coming by again today for more bleeding. It is a lot better today, but more play than I am used to.
The Following 2 Users Say Thank You to Raider For This Useful Post:
Mauro_Penguin (04-14-2015), Spec (04-14-2015)
 Old 04-14-2015, 10:22 AM   #100
EvoFire's Avatar
If you don't have steel braided lines already, get them. Make a huge difference on the CS pads, gets some of the mushiness out.
 Old 04-14-2015, 10:44 AM   #101
Raider's Avatar
Groans: 856
SS helps for any pads, but not in my budget right now. Stoptech blanks and CS pads will be the formula for now.
 Old 04-14-2015, 10:46 AM   #102
Spec's Avatar
Do they make a braided ss line for the clutch line on ms3?
 Old 04-14-2015, 03:33 PM   #103
Raider's Avatar
Groans: 856
Well, slave cylinder just shit the bed on my driveway. FML.
 Old 04-14-2015, 03:55 PM   #104
Shwaykid's Avatar
Posts: 646   (View Stats)
Shwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the world
From what I've read, the MS3 has a hard line from the factory, no rubber.
2008 Mazdaspeed3 GT
JBR TRU 3.5 Aluminum WP // Corksport TBE // JBR OCC Stage 2 // AP v3 (Tweaked [by me] E40 Tune) // Autotech Internals // Stratified EBCS // TWM Full Replacement w/ Type R Knob // CP-e Stage 2 RMM // JBR/Damond Full EGR Delete // Synchronic DV // NGK 6510s // FMIC [TR8 w/ JBR Pipes] // CorkSport Adjustable Struts/Lowering Springs // Progress RSB
Jet Black Wax (06/24/2017)
Better compression than Silaramic (02/20/2016)
Shwaykid is offline   Reply With Quote
 Old 04-14-2015, 03:57 PM   #105
Raider's Avatar
Groans: 856
It is rubber at the wheels.
And my local dealers are on 3 week back order. Classic in Orlando was out. Edge Autosport called their dealer-had one. Ovenright parts from Denver. Yay.
 Old 04-14-2015, 03:58 PM   #106
Spec's Avatar
Get the one with the orange boot!
Nah, once you unbolt it from the trans you can swinh it out the way. I just don't know if it's rubber
Last edited by Spec; 04-14-2015 at 03:58 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-15-2015, 11:34 AM   #107
Raider's Avatar
Groans: 856
Spring went across the garage
The point of failure
Waiting to be bled.
The Following 3 Users Say Thank You to Raider For This Useful Post:
Cataphract_40 (04-15-2015), Mattyhawk1 (04-15-2015), TiGraySpeed6 (04-15-2015)
 Old 04-15-2015, 12:35 PM   #108
Raider is mah Homie
Groans: 2,978
Wouldn't that just be shitting the driveway
I hugged rfinkle2
 Old 04-15-2015, 01:31 PM   #109
Raider's Avatar
Groans: 856
Urban Dictionary: shit the bed
Clutch has been bled and OMFG LOVE THIS CLUTCH!
This is a great clutch so far. Drive it a mile or so and pedal is great, it is a good thing. Highly recommend.
TiGraySpeed6 likes this.
JgamB (04-15-2015), TiGraySpeed6 (04-15-2015)
 Old 04-15-2015, 01:37 PM   #110
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
SO the slave cylinder musta been on the way out since reassembly, causing the funky pedal feel?
Glad to hear you're buttoned up & a happy camper!
340hp / 371tq
 Old 04-15-2015, 01:39 PM   #111
Raider's Avatar
Groans: 856
Yeah, I think it may have popped out during removal, who knows. So glad it happened now, and not next week.
 Old 04-15-2015, 01:46 PM   #112
Spec's Avatar
When I take my slave off, I zip tie the plunger down to keep it from over extending. Now that you have one in peices, does it have a grenade pin?
Easter Bunny (04-15-2015)
 Old 04-15-2015, 01:47 PM   #113
Jtaylor's Avatar
Now you have me debating on whether or not to keep the Luk stock replacement and fidanza or go with the southbend setup
08 MazdaSpeed3
 Old 04-15-2015, 02:03 PM   #114
Raider's Avatar
Groans: 856
If you got it, keep it. But so much OEM stuff to swap too, IMO. I updated the OP to show all the crap I replaced based off of the first 2 pages of posts.
 Old 04-15-2015, 02:23 PM   #115
Groans: 30
Glad you like it.
Where's your pedal engagement point?
1995 Miata
 Old 04-15-2015, 02:28 PM   #116
Raider's Avatar
Groans: 856
Originally Posted by Cataphract_40 View Post
Glad you like it.
Up where it should be. Near factory, not noticeable at all. It is stiffer than factory, but I expected it. Not tough at all, and I read it settles too.
 Old 04-15-2015, 02:58 PM   #117
Raider is mah Homie
Groans: 2,978
Did you mean to include hood struts and engine oil in the parts list?
I guess the oil is needed if you change the rear main seal
I hugged rfinkle2
Last edited by Easter Bunny; 04-15-2015 at 02:58 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-15-2015, 03:12 PM   #118
Raider's Avatar
Groans: 856
Yup. Fuck the prop. Made the install easier.
 Old 04-27-2015, 05:09 PM   #119
Raider's Avatar
Groans: 856
1700 miles later, I am happy with my decision. Took Tail of the Dragon great. Clutch knee only really hurt after my drive home. And it went away. But lots of shifting and no complaints.
The Following 8 Users Say Thank You to Raider For This Useful Post:
Cataphract_40 (04-27-2015), Cevaes_64 (04-28-2015), JgamB (04-28-2015), Mizzle (06-28-2015), phate (04-27-2015), someguy (04-27-2015), Spec (04-27-2015), TiGraySpeed6 (04-28-2015)
 Old 04-27-2015, 10:01 PM   #120
Groans: 30
Great to hear you're liking the decision. My stage 3 enduro is now almost like stock, firmness-wise. Southbend sure is good at what they do.
1995 Miata
The Following User Says Thank You to Cataphract_40 For This Useful Post:
Raider (04-28-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/clutch-opinions-gen1-mazdaspeed-3-not-like-183871/
FS: Stoptech Sport Kit for MS3 '07-'13 - DFW Mazdas This thread Refback 04-13-2015 11:45 AM
Clutch Issues - Harder to press as I rip through the gears phate MazdaSpeed 3 - Engine, Transmission & Driveline 34 04-06-2015 06:51 PM
Need new clutch opinions... Clutchmasters fx300 shit the bed thespeedingjib MazdaSpeed 6 - Engine, Transmission & Driveline 11 01-22-2015 06:09 PM
What uprated clutch to buy for a ms3 gen1? Frottage75 MazdaSpeed 3 - Engine, Transmission & Driveline 10 05-24-2014 09:12 PM
Clutch opinions xI Leveler Ix MazdaSpeed 6 - Engine, Transmission & Driveline 34 11-10-2012 01:34 AM
Page generated in 0.55538 seconds with 30 queries
