Like Tree3Likes
  • 1 Post By Carskick
  • 1 Post By Whitebullet
 Old 12-30-2017, 01:49 PM   #1
LenSpeed6's Avatar
Posts: 110   (View Stats)
LenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to behold
Default Clutch Options
So... trying to weigh my options for clutches while I'm waiting for parts to be delivered for my engine. Now there is some grey area when it comes to this, I have not decided on what turbo I am going to run, that is cause for a different thread that will be coming up very shortly. But, what is going to happen is forged pistons, h-beam rods and arp main studs, so I guess for all inventive purposes lets just say a CorkSport turbo will be fitted as I feel that its in the middle for size and power output for what I am looking for. So if I had to make an non educated guess I'd say 300-350 CRANK HP is a number, I can tell you guys that a K04 is not going back into this car if that helps.
What can the stock clutch hold for power? And what is a good option that isn't $1k?
I would rather use the stock dual mass flywheel to save some dough-ray-me if possible, this car is not going to be a full on racecar, I need to live with this thing for a daily driver.
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump
The Following User Says Thank You to LenSpeed6 For This Useful Post:
Whitebullet (12-13-2018)
 Old 12-30-2017, 01:59 PM   #2
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
I will complete a similar built next summer. However, I ran k04 for a bit. On e85 mix my nearly new OEM clutch started slipping in 4th gear. I am installing intake and CS turbo in a few months.
I have talked to a tuner and he said that CS is a 450 whp turbo. I'm hoping to land close to 390whp on stock fueling.
I have been reading about clutches and want a pedal that is not too heavy, close to stock. I have read that spec stage3+ is about as heavy as the stock clutch. Therefore, that is what I'm going to pick up.
I'm pretty sure you will slip on stock clutch....some people get lucky. You should replace that flywheel as replacing it later when it turns out to vibrate or cause issues is a pain in the ass. I just did a clutch on my Mazda 3 and putting it back sucked big time.
2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE
2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
 Old 12-30-2017, 02:17 PM   #3
LenSpeed6's Avatar
Buddy of mine has an 06 speed6 with CS turbo with supporting mods and a freektune, tune and have experienced no clutch slip so far, maybe he is lucky.
I see what you are saying on pedal feel, but my mentality is that with a hydraulic actuated clutch, you should be able to run something fairly aggressive and not have a huge left calf. I come from the world of 70's cars that are mechanically actuated, I have a Mcleod diaphragm clutch in my 72 Javelin AMX and its really not that bad, I can drive that every day with no issues other then a huge fuel bill, now if it had an old three finger pressure plate then I'd be walking funny as my left leg would look like a body builders and the right as a regular guy.
ACT street clutches look ok to me, I know they come with a different flywheel but as long as others have had good luck with them and they can hold up it might be a viable option.
06 Speed6
 Old 12-31-2017, 11:04 AM   #4
Fstrnyou's Avatar
Posts: 2,149   (View Stats)
I've read the stock clutch starts to give out in the mid-to-upper 300's WTQ.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 12-31-2017, 02:19 PM   #5
LenSpeed6's Avatar
@Fstrnyou; with the motor that you are building for your car, which sounds somewhat similar to what I am doing, what were you planning on running for a clutch? I am temped to run the stock one if mid to upper 300 wtq is realistic but I don't want to be on the harry edge of the limit either.
@stockms3; 450 whp but at what psi? 30? 40? Is it that figure maxing out the CS turbo?
My buddy is running 20-21 psi with his, he is also on stock internals which in my opinion is a ticking time bomb but with no ill effects as of yet. With the internals that I am going to run I should be able to push 26ish easy if not more but 26 would most likely be the most my car would see.
06 Speed6
 Old 12-31-2017, 02:49 PM   #6
Fstrnyou's Avatar
Currently building for around 450whp...I could get away with the stock clutch if I tune the torque to stay below 400. But my current clutch is practically brand new. A seasoned clutch may not fare so well.
I have picked out, at EdgeAutosport, the ACT HD sprung 6-puck with streetlite flywheel. Just waiting on funds to click buy. I have very little experience with aftermarket clutches.
The other option is Southbend. I was looking at their Stage 3 Endurance, but the Southbend kits cost a few hundos more than the better known ACT brand.
Other rides:
History:
 Old 12-31-2017, 03:17 PM   #7
MoMS3's Avatar
Posts: 233   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
I've got the Stage 3 Endurance, in an MS3 granted, but I've got about 10-15k miles on it and it is awesome. Takes a week to get used to the heavier pedal, but past that it is super smooth. As in smoother engagement than stock. With all motor mounts there is some chatter at idle but nothing too obnoxious, mostly when A/C is on.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
 Old 12-31-2017, 03:21 PM   #8
Fstrnyou's Avatar
Any mild aftermarket clutch should be smoother than the on/off switch of the stock clutch.
Other rides:
History:
 Old 01-01-2018, 02:46 AM   #9
tegxsi's Avatar
Posts: 1,235   (View Stats)
Groans: 87
My clutch recently started to slip at peak torque. I have about 41k miles on the stock clutch. About 10k of those miles with the CS turbo. I don't feel like spending money on the car so I detuned the car for now.
I've been looking at Southbend stage 2 daily... I don't need anything aggressive. Something that is good enough to hold the power and not make the pedal too heavy.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 01-01-2018, 04:21 PM   #10
stockms3's Avatar
Groans: 74
I am not sure what PSI, I believe some people run it around 28. I don't think my tuner would push the turbo beyond its limits. Even CS list 250-450 hp on their site.
 Old 01-01-2018, 05:07 PM   #11
Fstrnyou's Avatar
I'm pushing 18psi thru my CS turbo on stock internals. My ambitious guess is just shy of 300whp. I load tune, so, for reference, the ambient temps were around 70F.
I've seen multiple stock block members pushing mid 300's up to 400whp in unicorn cases. I don't have the balls to push my old motor any harder than I am. 148k miles as of today.
Other rides:
History:
 Old 01-01-2018, 05:43 PM   #12
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
I just had a SB Endo stage 3 clutch installed. My mechanic and I estimate torque about 450 at the crank. So far, the clutch feels good and barely feel chatter with the A/C on. I can't remember what the OE clutch feels anymore because I had a CP-e stage 1 in there. SB is a lot lighter than the CP-e one. I heard ACT 6 puck is a good clutch. I am hoping that the SB will last longer than the ACT one. Still breaking in the SB. GL with your decision.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 01-02-2018, 12:49 PM   #13
LenSpeed6's Avatar
@Poohster; about how long did your ACT clutch last? how much abuse did you throw at it?
@Fstrnyou; yeah my buddy is at 21psi on stock internals with around 109K, I told him 19 before should do it but it has been surviving so far... time will tell.
Im guessing I should be able to do 23-26 with my set up on the high side with no issues witht he motor, then everything else breaks but my decision on that isn't final, I might go lower just because.
06 Speed6
 Old 01-02-2018, 02:54 PM   #14
Thor Hammer's Avatar
Posts: 1,766   (View Stats)
Groans: 198
I did a fair amount of reading before deciding on my South Bend Stage 2 Endurance. It was heavy at first, but has since become lighter, or my leg is stronger?
Its a great setup. But yeah, it was over $1K. Considering it took two days to replace I don't mind spending more so I don't have to do it again anytime soon!
I wouldn't reuse the stock flywheel. The internal springs fatigue over time and I don't know of any shop that would resurface it.
The least expensive option for our cars is the Fidanza flywheel with Luk clutch. Lots of threads on it.
 Old 01-02-2018, 02:55 PM   #15
Fstrnyou's Avatar
Long term, i plan on pushing the CS turbo as high as it will go or until I run out of money to support how high it will go...lol. Once the motor is built, I'll be limited by my stock TMIC. Once I'm overy that hurdle, I'll be limited by fuel system. Once I'm over that hurdle, my stock exh mani and stock cat-back will be the issue. And I'm sure even soft launching it, I will eventually snap an axle.
Even though overpowering the stock clutch is quite a ways down the road, I don't want to have to deal with a clutch change mid progression. The ACT HD 6-puck is "rated" at 530TQ. That should cover anything I intend to do.
Other rides:
History:
 Old 01-02-2018, 03:01 PM   #16
Fstrnyou's Avatar
Entry level upgrade, I completely agree. It crossed my mind to due that setup a few months back when my original clutch broke apart. But I got a sweet deal on new Luk kit that included the flywheel all the way to the slave cylinder. However, the Fidanza won't provide any additional holding power over stock. It's just a little lighter.
Other rides:
History:
 Old 01-06-2018, 07:31 AM   #17
Poohster's Avatar
Sorry, I have been out of pocket. I did have the ACT clutch. I had a stage 1 CP-e clutch. I don't think I abused it and it only lasted around 20K miles. The clutch was at heavy as hell. I believe I completely wore it out.
I read ACT lasts about 20-30K miles but would like to hear from an ACT owner. I went with Southbend because I believe it would last longer.
 Old 01-06-2018, 07:26 PM   #18
shaneski's Avatar
Posts: 481   (View Stats)
Plus one for the SB stage 3 endurance, 40,000 miles on mine and it still feels bullet proof, and that's heavy daily traffic and beat on with full slicks at the drag strip running 11 sec times.
ACT seems to be hit and miss some last and others have had them completely fall apart at 10,000 miles
 Old 01-07-2018, 05:41 PM   #19
LenSpeed6's Avatar
Unfortunately I think that a SB stage 3 endurance is going to be a little out of my price range. It seems like if South Bend is the clutch to get, a stage 2 daily is more in my range, I'm going to say that my car isn't going to make anymore then 400 HP/TQ at the absolute most at the crank so with taking 20% of that for drivetrain loss I'm theoretically at 320ish WHP and would guess that the torque figure would be around the same and SB rates the stage 2 daily at 350 ft/lbs, now weather that is at the crank or wheel is the question.
So I'm guessing that there isn't much chatter or other negative things with South Bend clutches, I aspect that there is going to be some chatter with an aftermarket clutch.
It ACT is hit or miss then I'm going to stay away from them, I really don't want to have to rip this car apart again in 10K-30K for a clutch.
06 Speed6
 Old 01-07-2018, 05:45 PM   #20
Fstrnyou's Avatar
At 320whp, get a stock clutch with maybe a Fidanza flywheel.
Other rides:
History:
 Old 01-07-2018, 05:55 PM   #21
stockms3's Avatar
Groans: 74
My stock clutch slipped at that power level, and it was brand new too. I would not risk putting a stocker and replacing it shortly after.
 Old 01-07-2018, 05:58 PM   #22
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
There is a guy in NY, falcon clutch I think its called, replaces friction disk on stock clutch with Teflon, rebuilds and resurfaces the stock dual mass flywheel so there is no chatter. Should handle a good amount of power. He quoted me like $600 with a few days turn around.
Just another option
Sent from my SM-N950U using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 01-07-2018, 08:23 PM   #23
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,896   (View Stats)
Groans: 539
luk/fidanza combo here. 40k miles fully bolted with bnr s3, at least 15k miles on e85 at 350+ awhp, dozens of launches, lots of flat foot shifting. pedal feels good, clutch doesn't slip and shifts well, but i would never install this combo as it is the worst noise i have ever heard a car make.
94 M
06 MS6
The Following User Says Thank You to Pu Manchu For This Useful Post:
Tomas (12-18-2018)
 Old 01-07-2018, 08:26 PM   #24
Fstrnyou's Avatar
Ah...flywheel too light? Guess I better stay away from ACT Prolite eh?
Other rides:
History:
 Old 01-07-2018, 08:35 PM   #25
Pu Manchu's Avatar
Groans: 539
it's a great option if you don't mind your car sounding like an old busted tractor. i've really only got a rmm, so i'd hate to hear what it's like on a fully mounted 6.
94 M
06 MS6
 Old 01-12-2018, 01:04 PM   #26
LenSpeed6's Avatar
Just another option
Good Call!
Just got off the phone with Marc from Falcon Clutch, very nice guy to deal with, looks like this is the route that I'm going to pursue. Quoted me $625 for the job to dude up the flywheel, pressure plate and clutch disk, should hold 425-450ish torques.
06 Speed6
 Old 01-12-2018, 01:11 PM   #27
MoMS3's Avatar
Just another option
Teflon, as in Kevlar? Can't imagine he's making non-stick friction disks haha.
Also another thing to consider is failure of the dual mass flywheel, they do happen, I'd imagine at a more common rate with AWD launches, unless he also does new springs and the friction ring inside the flywheel. Just some food for thought OP.
 Old 01-12-2018, 01:14 PM   #28
tmillner's Avatar
I think he includes a new pilot and throw out bearing. Glad I could help
Yeah duh, ill blame it on autocorrect.
Last edited by tmillner; 01-12-2018 at 01:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-12-2018, 01:58 PM   #29
LenSpeed6's Avatar
@MoMS3;
I understand your concern but if this thing sees the drag strip it will be lucky to see it two or three times at the most, have a car for that already. I'm not planning on 6k launches anyway.
@tmillner;
Yes exactly, seems like a great deal, not knocking other clutches out there.
06 Speed6
 Old 12-13-2018, 10:42 PM   #30
Whitebullet's Avatar
Posts: 16   (View Stats)
Whitebullet is an unknown quantity at this point
Been reading the cluth threads; would a Southbend Stage 2 Daily (Or endurance) make sense with a dual mass flywheel? I don't want the rattle of the SMF but i want a better grab with the SB S2.
My build is a BNR S4, TMIC, 3" intake, Tuned, ATP downpipe (with cat)
I am seeing online the SB only comes as a kit with the flywheel...
Maybe the Luk cluth and Luk flywheel kit is a good fit for me with these build specs, will they hold with HP and Torque? It's $700 on Rockauto
thanks
Whitebullet is offline   Reply With Quote
 Old 12-14-2018, 02:41 PM   #31
Groans: 198
thanks
Ditch the DMF. The springs fatigue over time and then its junk. Usually around 80-90K miles. A new one is just as expensive as the SB Stage 2 Endurance (what I run).
Go with Southbend for your mods. I don't know what HP/TQ you're tuned to however I'm sure the SB Stage 2 Endurance can take it.
Don't have experience with the luk clutch and flywheel but certainly not rated to handle what the SB can take.
Over 60K miles on mine and no issues. All you hear at idle with the car running in neutral and clutch out is a little transmission gear noise. NBD. How often are you at idle with the clutch out and in neutral anyways???
Whitebullet (12-14-2018)
 Old 12-17-2018, 10:12 PM   #32
Carskick's Avatar
Posts: 280   (View Stats)
thanks
I have the SB S2 Endurance and there is very little SMF chatter/vibration. The set had a break in period for me, but it settled nicely and I'm happy with how it turned out.
Sleepin6 likes this.
2009 Mazdaspeed 3 Sport (Original Owner) - 93k miles and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC | SpeedDaddy TP | AT HPFP | Damond RMM | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | Koni STR.T Shocks | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold Fronts | Focal Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: Low Note Additional Horn
Mods Awaitting Install: Bilstein B16 Coilovers (Back Ordered) | Whiteline Bushings, Anti-Lift, & Bump Stops | Whiteline Endlinks | JBR 125 Sway Bars & upgraded bushings/mounts | DM RMM & PMM | JBR TMIC Red Boost Tubes | DM OCC w/VTA
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM
The Following User Says Thank You to Carskick For This Useful Post:
Whitebullet (12-17-2018)
 Old 12-18-2018, 07:33 AM   #33
Jeff23spl's Avatar
Posts: 1,631   (View Stats)
I agree with Thor, get rid of that DMF piece of crap. That thing can chatter more when it get loose than a smf....Peoples are often afraid of it like i was before i did try...You will hear it probably the first week because you pay attention and then you will forget about it...Hard transmission mount would be many times worse!!!
The oem luk wont old torque from your S4, i don't know your tune and if it is a 3 or 6 but you need a kit that can hold 400lbs+. I didn't feel my oem wasn't holding it but when i switched to an ACT 6puck i understood it was sliping often.
I never tryied The sb s2 endurance but looking at the hybrid disk, it seem a good compromise between oem and 6pucks.
The 6pucks was a bit too much for my use. It was fun to make tires squeal while passing a car or for a burnout but when trying to make a soft and comfortable start from a traffic light, it was a bit tricky.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Whitebullet (12-18-2018)
 Old 12-18-2018, 07:44 AM   #34
Thanks for the feedback, i am leaning to SB Stage 2 Endurance. Edge Auto calls this best for racing which i plan to do little of, this will be my daily driver with traffic. Will this be a good fit as a daily driver?
 Old 12-18-2018, 12:22 PM   #35
Fstrnyou's Avatar
I daily my 6 with the ACT 6-puck. It DOES take a bit of getting used to the grabby nature if a puck clutch, but I've gotten fairly smooth with it now.
Other rides:
History:
 Old 12-18-2018, 12:46 PM   #36
Jeff23spl's Avatar
the sb stg2 should be smoother than the 6pucks. But you won't get a single disk clutch to hold BT power that remain as smooth as the oem.... i also had a 6puck and my gf was able to drive it so if you have problems to take of with the sb....it won't be the clutch
Wife drive 2010 CX7
 Old 12-18-2018, 01:06 PM   #37
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,768   (View Stats)
Groaned at 33 Times in 19 Posts
I use a spec stage 3+ with a findanza wheel. Torque rating 477. Has some chatter but nothing like what Pu Manchu mentions. It is a great set up and I like the self adjusting ratchet system of the OEM luk cover which is what spec uses since the only thing they do is resurface the disc with their copper alloy and give you an OEM cover plate painted blue. It is grabby when cold but at temp it gets better. You also notice the engine is rev happier with the findanza wheel which is a plus.
MAKE LOVE TO THE CANVAS
 Old 12-18-2018, 06:15 PM   #38
Carskick's Avatar
I was worried at first, just like you.
But the SB S2 is perfectly daily-able. I drive it every day and even in traffic it doesn't bother me. In fact, I find it easier to use than the stock clutch, though not quite as predictable sometimes, especially during break in.
I do recommend replacing your rear seal & slave cylinder while you're in there.
Just plan on a break in period, like anything else. As others said, motor mounts will make a bigger NVH diff than this.
 Old 12-18-2018, 06:47 PM   #39
Sleepin6's Avatar
Posts: 98   (View Stats)
Sleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to behold
Default Southbend stg 3 endurance
Southbend FTW!
MS6 GT...REBUILD IN PROGRESS
BOLTED AND BOOST PROVIDED BY...
SPEED1/CORKSPORT...
Sleepin6 is offline   Reply With Quote
 Old 12-18-2018, 09:36 PM   #40
shaneski's Avatar
I've had the Southbend S3 endurance in mine for ages and done around 60,000 and it still feels new. It's been dragged with slicks and also is used as a daily. The engagement feels smoother and more predictable than OEM
It did have chatter with a JBR tranny mount, swapped that for a Damond and only hear a tiny bit of chatter with Aircon on when at idle.
Looking at clutch options njdhartmann MazdaSpeed 3 - Engine, Transmission & Driveline 12 11-17-2016 02:43 PM
Big Turbo 6 Clutch options ChasingSafety MazdaSpeed 6 - Engine, Transmission & Driveline 6 06-18-2014 07:49 PM
Clutch replacement options seanmiller09 MazdaSpeed 3 - Engine, Transmission & Driveline 9 04-20-2014 01:58 PM
new clutch got smoked.options? rey_06 MazdaSpeed 6 - Engine, Transmission & Driveline 24 11-28-2013 11:20 AM
New clutch options subparpunk03 MazdaSpeed 3 - Engine, Transmission & Driveline 14 12-19-2008 10:42 AM
Page generated in 0.61549 seconds with 34 queries
