 Old 10-04-2012, 04:22 PM   #1
MCGUFF's Avatar
Posts: 19   (View Stats)
MCGUFF is on a distinguished road
Default Clutch slipping n 5th and 6th gear when getting on the gas
Hey got a question, When i am in 5th or 6th gear on the free way and i gas it pretty hard my RPM will go up then down a little then up and down a little. I am assuming its the clutch that is slipping it has the OEM clutch. Figure i need to get this fixed asap just wondering if my guess is right and what parts would i need (clutch kit, or just flywheel?) please let me know of thoughts and part recomidations. This is not a track car i drive it around 70 miles a day.
Thanks.
2008 Black MS3
Streetunit | RMM Turbosmart | Duel Port BOV
SURE | Aeros SURE | Anchors
SURE | Counter Shifter SURE | Return
SURE | Sidewinder SURE | Shortcut
MCGUFF is offline   Reply With Quote
 Old 10-04-2012, 04:32 PM   #2
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
1. Please use the Search button.
2. Please Donate.
3. Since I am in a good mood today and I am in a similar situation, here you go:
http://www.mazdaspeedforums.org/foru...clutch-102245/
Pickles Tune in progress
 Old 10-04-2012, 04:33 PM   #3
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
Same thing started happening to me back in...like June. It's getting worse and worse. I have an ACT clutch kit sitting here waiting to go in.
You will probably need the whole kit. Our flywheels can't usually be resurfaced, and OEM ones are REALLY expensive.
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
The Following User Says Thank You to Stealth01 For This Useful Post:
taf0422 (10-04-2012)
 Old 10-04-2012, 04:36 PM   #4
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
As said above. And no reason to restate.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 10-04-2012, 04:50 PM   #5
himurax13's Avatar
Groans: 255
If you are going to buy a new clutch, contact @eric@edgeautosport for a good deal. If you are not BT, you can go with the regular ACT clutch instead of the 6 puck. You also need to order 6 new OEM flywheel bolts.
Last edited by himurax13; 10-04-2012 at 04:52 PM. Reason: MSF Database - Automerged Doublepost
EdgeAutosport.com (10-04-2012)
 Old 10-04-2012, 04:51 PM   #6
MCGUFF's Avatar
2. Please Donate.
Link does not work. Search didnt come up with anything.
2008 Black MS3
 Old 10-04-2012, 04:53 PM   #7
himurax13's Avatar
Groans: 255
Sorry it is in the VIP section .
Its a big Pain in the ass. I would find someone who has done a few clutches and has a lift to install it.
 Old 10-04-2012, 04:56 PM   #8
taf0422's Avatar
Groans: 192
oh looks like you will have to donate for that one...
Well played sir..Well played. I forgot that is one of the only how to's that is locked in VIP and will probably never be released.
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
Will a DIY clutch adjustment help a slipping clutch? Greekfreak MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2012 05:53 PM
Could a slipping clutch cause KR? AntiStock MazdaSpeed 6 - Engine, Transmission & Driveline 2 07-01-2010 02:23 PM
My clutch is slipping ms3jake MazdaSpeed 3 - Engine, Transmission & Driveline 29 03-03-2009 05:37 PM
Page generated in 0.28458 seconds with 23 queries
