 Old 12-10-2013, 04:47 PM   #1
Nate010's Avatar
Posts: 126   (View Stats)
Nate010 has much to be proud ofNate010 has much to be proud ofNate010 has much to be proud ofNate010 has much to be proud ofNate010 has much to be proud ofNate010 has much to be proud ofNate010 has much to be proud ofNate010 has much to be proud ofNate010 has much to be proud ofNate010 has much to be proud of
Default Clutch stuck to floor, hydraulic fluid leaking
So it's been -8 degrees in Colorado the past few days and my clutch stopped working. The first day I noticed problems the clutch was grabbing gear right off of the floor and was very spongy. Parked the car for the weekend and went snowboarding. 2 days later came back, went to fire her up, and the clutch fell to the floor with barely a touch. The car started, but I couldn't get it in gear. Got underneath the dash to take a look and found hydraulic fluid leaking from clutch line into the firewall. So.... is it my master cylinder, slave cylinder, or something else? Its really cold outside and I don't have a garage so I trying to avoid spending time outside as much as possible, otherwise I'd just rip shit out and figure it out myself. If anyone has any ideas let me know.
The yellowish shiny stuff is the hydraulic fluid. Its even dripping down onto my floor matt.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
/CP-e Catless DP/CP-e TMIC/CP-e Xcel Nano/CP-e RMM/Autometer V/B Gauge/Cobb AP Safe Mode :-(/Koni Yellow's/ITV22/Hawk HPS F/R/
Nate010 is offline   Reply With Quote
 Old 12-10-2013, 05:45 PM   #2
jm211's Avatar
Posts: 943   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
Groans: 52
Its been negative up here too and my clutch was terrible after not driving 4 days. Super slow to return for 20 minutes of driving.
Thats your master cylinder. Check from engine bay to see if your leaking there too.
Likely a rebuild or replace. Id do the slave and rubber clutch line ar same time.
Black Mica 2006 Speed6 GT | 62,000 Miles
Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
The Following User Says Thank You to jm211 For This Useful Post:
Nate010 (12-10-2013)
Clutch pedal stuck to floor, won't come back up. spied 2010 MS3 - Engine, Transmission & Driveline 13 12-18-2014 01:34 PM
Leaking transaxle fluid? kyle53 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 08-18-2013 03:40 PM
Clutch hydraulic system 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 18 08-13-2012 07:30 PM
rear shock leaking fluid.. SharkDiver MazdaSpeed 3/6 - Suspension & Brakes 19 02-09-2012 05:08 AM
Brake fluid reservoir leaking? Hank3 MazdaSpeed 3/6 - Suspension & Brakes 4 08-11-2009 05:37 AM
Page generated in 0.24443 seconds with 21 queries
