-   -   cobb intake f@#ked fuel trims (http://www.mazdaspeedforums.org/forum/f10/cobb-intake-f-ked-fuel-trims-73218/)
cbspeed3 02-23-2011 11:53 PM
had to take my cobb intake off,it was causing me to have 10+ltft at idle and 15+at heavy throttle.afr was still in the 13's when i was at 16 psi of boost,car did run like a bat out of hell and got just a little knock at 5000 rpm kr1.1 or less.put the factory intake back on and my trims are back below 5 all conditions.
silvapain 02-24-2011 12:07 AM
AFR's in the 13's at WOT is way too high. Sounds like you're pulling in unmetered air at WOT.
cbspeed3 02-24-2011 12:34 AM
yeah thats what i thought too,checked every clamp and hose,even cleaned my maf sensor.put the stock intake back on and all is good.afr drop fast to 11's,10's,9's.something with the cobb intake,guess i need accessport.
Page generated in 0.16960 seconds with 11 queries
